I have a 1st generation FireTV box (not stick). It appears that the DASH option of the plugin selects the highest frames per second for the bit rate. That selection causes an issue with this device. The box's specs say its capable of 1080p60, but either something is not quite right and the videos at 60 FPS stutter and drop frames. I have tried playing with the min/max bit rates, but I cannot seem to get it to select 1080p30. I either get 720p or 1080p60 depending on the values entered. Can the plugin be modified to specify max frame rate limit for a resolution? For example, allow 720p60, 720p120, 1080p30, 1080p60, etc.? Being able to limit FPS will also help for those of us that face bandwidth caps. Thanks!
(2017-11-21, 23:12)DarrenHill Wrote: [ -> ]The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
OK, i think that you have in mind Colossus and Smash repositories, which i have installed after reading that article
@Karellen-Link removed - just for testing and out of curiosity. Now, after some research i know why you are against it. I'm not interested in illegal stuff, and i have already removed these repositories from my Kodi.
(2017-11-21, 21:42)chrisub Wrote: [ -> ]Hi,
it's my first post, so in first i would like to thank for great plugin! I'm using it for playing 8-10h long videos like https://www.youtube.com/watch?v=jyEY6t_e...x&index=10
Unfortunately, after some time video simply stops - in most cases after 6h.
Here is the log: https://pastebin.com/is3PZTdi
As can be seen, Curl is saing that HTTP returned error 403 and InputStream Adaptive: url doesn't provide any data: invalid. Can it be related with limits in youtube API, or it's a kid of bug? I use custom keys to authorise.
thank you in advance!
As moderators requested, i removed banned repositories and here is new, "clean" log:
https://pastebin.com/28GJeKNF
I hope this time i can count on your support
Hello @
chrisub
If you are still requiring assistance, please submit a new debug log as we won't diagnose your previous one with the banned items.
does youtube search api allow filtering by duration like on the website? The <4min >20min part
(2017-11-22, 20:51)alan23 Wrote: [ -> ]I have a 1st generation FireTV box (not stick). It appears that the DASH option of the plugin selects the highest frames per second for the bit rate. That selection causes an issue with this device. The box's specs say its capable of 1080p60, but either something is not quite right and the videos at 60 FPS stutter and drop frames. I have tried playing with the min/max bit rates, but I cannot seem to get it to select 1080p30. I either get 720p or 1080p60 depending on the values entered. Can the plugin be modified to specify max frame rate limit for a resolution? For example, allow 720p60, 720p120, 1080p30, 1080p60, etc.? Being able to limit FPS will also help for those of us that face bandwidth caps. Thanks!
I'm running into the same issue you are. More control over what fps/resolutions are allowed/disallowed would be very helpful.
(2017-11-25, 01:54)randomuser Wrote: [ -> ] (2017-11-22, 20:51)alan23 Wrote: [ -> ]I have a 1st generation FireTV box (not stick). It appears that the DASH option of the plugin selects the highest frames per second for the bit rate. That selection causes an issue with this device. The box's specs say its capable of 1080p60, but either something is not quite right and the videos at 60 FPS stutter and drop frames. I have tried playing with the min/max bit rates, but I cannot seem to get it to select 1080p30. I either get 720p or 1080p60 depending on the values entered. Can the plugin be modified to specify max frame rate limit for a resolution? For example, allow 720p60, 720p120, 1080p30, 1080p60, etc.? Being able to limit FPS will also help for those of us that face bandwidth caps. Thanks!
The DASH frame rate selection is an option of the dash plugin. the youtube plugin has no control on how it is set up. All we can do is point you to the inputstream plugin and let you configure it.
Jeff
Suddenly my youtube addon v5.4.5 stopped working 2 days back on Kodi running on my Raspberry Pi 2. I tried re installing the addon but did not help. Any suggestions would be appreciated.
Its not able to play any youtube videos and this is the error logged:
xml:
1:27:00.928 T:1763701680 NOTICE: [plugin.video.youtube] Running: YouTube (5.4.14Bump) on Krypton (Kodi-17.3) with Python 2.7.9
21:27:04.989 T:1946157728 NOTICE: Previous line repeats 1 times.
21:27:05.037 T:1946157728 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for https://r3---sn-q4flrn7y.googlevideo.com...1266486987
21:27:05.104 T:1946157728 NOTICE: VideoPlayer: Opening: https://r3---sn-q4flrn7y.googlevideo.com...1266486987
21:27:05.104 T:1946157728 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
21:27:05.308 T:1946157728 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for https://r3---sn-q4flrn7y.googlevideo.com...1266486987
21:27:05.309 T:1707336624 NOTICE: Creating InputStream
21:27:05.616 T:1707336624 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
21:27:05.617 T:1707336624 ERROR: CCurlFile::Open failed with code 0 for https://r3---sn-q4flrn7y.googlevideo.com...1266486987
21:27:05.824 T:1707336624 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
21:27:05.825 T:1707336624 ERROR: CCurlFile::Open failed with code 0 for https://r3---sn-q4flrn7y.googlevideo.com...1266486987
21:27:05.825 T:1707336624 ERROR: Open - failed to open source <https://r3---sn-q4flrn7y.googlevideo.com/videoplayback?ms=au&pl=22&mv=m&initcwndbps=388750&ipbits=0&source=youtube&dur=259.320&sparams=dur%2Cei%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cexpire&ip=122.172.42.126&key=yt6&signature=43218C82D617E4FC2D7531E9FBF95DB8E797CF8F.B22A0EF719450B79740B145AAEC735372897B780&mime=video%2Fmp4&requiressl=yes&ei=0DUcWv2REofqoAO20qyoBw&id=o-AExB7T4cK2DFNb4m_sAX7zVPJKQmuyGbKE8z7jj1jdvF&itag=18&mt=1511798109&mn=sn-q4flrn7y&mm=31&ratebypass=yes&expire=1511819824&lmt=1511651266486987>
21:27:05.826 T:1707336624 ERROR: CVideoPlayer::OpenInputStream - error opening [https://r3---sn-q4flrn7y.googlevideo.com...1266486987]
21:27:05.826 T:1707336624 NOTICE: CVideoPlayer::OnExit()
21:27:05.827 T:1946157728 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=AxWxJNHoLC8]
21:27:05.857 T:1946157728 NOTICE: CVideoPlayer::CloseFile()
21:27:05.857 T:1946157728 NOTICE: VideoPlayer: waiting for threads to exit
21:27:05.857 T:1946157728 NOTICE: VideoPlayer: finished waiting
21:27:05.858 T:1946157728 NOTICE: CVideoPlayer::CloseFile()
21:27:05.858 T:1946157728 NOTICE: VideoPlayer: waiting for threads to exit
21:27:05.858 T:1946157728 NOTICE: VideoPlayer: finished waiting
(2017-11-27, 19:22)ibshar Wrote: [ -> ]Hi,
YouTube (5.4.14Bump) looks like an unofficial version, so you probably won't get support for it here.
jonib
(2017-11-27, 20:36)jonib Wrote: [ -> ] (2017-11-27, 19:22)ibshar Wrote: [ -> ]Hi,
jonib
You're right, 5.4.14Bump isn't our version so you'll need to talk to the guy who modded the code or switch to the version from our repo or the official repository.
Jeff
@ ibshar
the 5.4.14Bump it's a FAKE version released and published above 2 months ago by a banned repo now offline for ever.....
Pass to the GitHub project page and pick last alpha..........
(2017-11-28, 04:22)DjDiabolik Wrote: [ -> ]@ ibshar
Sorry, I had 5.4.5 from the kodi repo, but once it was not working while trying to fix it i downloaded this one. I have removed it now and restored the original version. And it seems to be working again today after shutting down the pi for some time and then starting it again.
is it correct that you can stream only live content in 1080p? and you need DASH for 1080p and above for non-live content?
edit:
i tried to play a video with 2160p and 60 fps. 2160p is okay but only 30 fps are pssoible with DASH. anyone an ideao?
