2016-04-03, 13:17
2016-04-03, 13:17
2016-04-03, 13:59
Is that debug info? I don't get that on mine, just annoying "fanart" images of the artists get overlaid blocking the visualisation for me
Looking at the bottom of this wiki page: http://kodi.wiki/view/Video_playback
I see that it is codec info that should go away with the O key.
http://kodi.wiki/view/Codecinfo
When I play tunes on KODI 16.1 RC2 the O key toggle clearly works.
Does the M toggle work for you? It should toggle player controls on and off the screen.
2016-04-03, 14:13
"M" key works OK, "I" key works OK, "O" key does not have any effect. I will try to reload Kodi 16.1 RC from scratch and kill current user profile. Will come back.
best, d.
best, d.
2016-04-03, 14:20
No point loading from scratch... this should be fixable. Let me go hack my settings file.... see if I can find something.
Do you have anything else that may have remapped the keyboard?
2016-04-03, 14:29
Yes that's it. There seems to be some setting in my user profile which was not compatible with Kodi 16.1 RC so it did not work. I deleted a profile and created a new one and now I can close down Codec Info with "O" key.
Best, d.
Best, d.
2016-04-03, 14:41
My best guess is still the debug info left partially on. Glad it was fixed without too much of a full reset
2016-04-03, 16:23
on personal PC I have Kodi more for experimental purposes and here it was not working. I would be more worried about my reset of user setting for HTPC where I have a lot of things configured and I would use there definetely a different approach to fix that problem. At HTPC I still use Kodi 14.2 as I don't like some bugs that 15 and 16 has.
best, d.
best, d.
