media elch
can you test what happens if you change line 3198 and 3223 from scale to stretch in includes_home.xml ?
if nothing happens can you change it anyway because here with aspect ratio 16:10 it better with stretch when a cover has the same with and high z.b. 300x300
scale
stretch
I can change to stretch yes, no problem
Envoyé de mon iPhone en utilisant Tapatalk
cool thanks
ok have found a solution for my conert
easy if you know it
change type of widgets in customizable widget (poster)
(2016-08-13, 00:43)ikaruz Wrote: [ -> ]cool thanks
easy if you know it
Yes it's an other solution.
yes but anyway strange
which is a kodi members thinking errors .
a concert has an artist and no actor . the construction must be like an album
artist / concert but with dvd or bluray posters and not with cd posters .
a concert is music and does not have to appear in the movies category .
It also has no movies structure , special one artist and album structure
Guilouz what appears to you under the artist and album ? in view_54_albumview.xml
I saw in the xml file it should be Artist - Album? in artist view and year - album in album view
or i am wrong?
here it show artist under artist and artist - album under album
or should it be so ?
I changed that and think you had it so intended . or ?
Now here it show Artist under the Artist Pictures and year<br>album under the album cover
i edit all 4 label and add the [CR] because if artist name or album name is to long i think it dont look nice and all 4 visible (!)
<control type="textbox">
<left>28</left>
<top>278</top>
<width>262</width>
<height>70</height>
<font>font12</font>
<align>center</align>
<aligny>center</aligny>
<label>$INFO[ListItem.Year,,[CR]][COLOR white]$INFO[ListItem.Label][/COLOR]</label>
<textcolor>$VAR[SkinColorVar]</textcolor>
<autoscroll delay="1000" time="1000" repeat="1000">true</autoscroll>
<visible>Container.Content(albums)</visible>
</control>
<left>28</left>
<top>278</top>
<width>262</width>
<height>70</height>
<font>font12</font>
<label>[COLOR white]$INFO[ListItem.Artist,,][/COLOR]</label>
<visible>!Container.Content(albums)</visible>
</control>
(2016-08-12, 23:24)Guilouz Wrote: [ -> ] (2016-08-12, 23:21)anhell28 Wrote: [ -> ]Plz add a setting to allow more posters, thumbs or icons to scroll through on home menu...I have a huge library and hate that i cant see them all on there.
plz plz plz
I have already do this, 25 items in my Mod, 10 items in original Estuary.
Can you please tell me which xml's do i have to edit to add more than 25?
(2016-08-13, 08:36)anhell28 Wrote: [ -> ] (2016-08-12, 23:24)Guilouz Wrote: [ -> ] (2016-08-12, 23:21)anhell28 Wrote: [ -> ]Plz add a setting to allow more posters, thumbs or icons to scroll through on home menu...I have a huge library and hate that i cant see them all on there.
plz plz plz
i think its includes_home.xml
search for
limit="25" there are 19 hits
you must look witch you want edit
(2016-08-13, 11:21)ikaruz Wrote: [ -> ] (2016-08-13, 08:36)anhell28 Wrote: [ -> ] (2016-08-12, 23:24)Guilouz Wrote: [ -> ]I have already do this, 25 items in my Mod, 10 items in original Estuary.
search for limit="25" there are 19 hits
And all playlists in playlists folder.
(2016-08-13, 06:49)ikaruz Wrote: [ -> ]Guilouz what appears to you under the artist and album ? in view_54_albumview.xml
or i am wrong?
<left>28</left>
<top>278</top>
<width>262</width>
<height>70</height>
<font>font12</font>
</control>
<left>28</left>
<top>278</top>
<width>262</width>
<height>70</height>
<font>font12</font>
</control>
Show Artist - Album in albums view was a request. So I don't remove this.
no problem
i have only edit because i see this lines
<label>$INFO[ListItem.Year,,[COLOR white] - [/COLOR]][COLOR white]$INFO[ListItem.Label][/COLOR]</label>
and i cant see a Year - Album so it dont work or have i a issue or do i misunderstood it ?
(2016-08-13, 14:32)ikaruz Wrote: [ -> ]no problem
Because this include is also use for another view.
There is no year for artist, it's normal
a understand now
ok than i think wrong :|
In 1.5.1. is it possible to move the rss feed back to the bottom instead of the top? If so what do I need to edit? Thanks in advance.
(2016-08-13, 18:15)Pasado Wrote: [ -> ]In 1.5.1. is it possible to move the rss feed back to the bottom instead of the top? If so what do I need to edit? Thanks in advance.
I have change this for next release. Available on git or wait for repository update.
