(2016-04-25, 21:53)Guilouz Wrote: [ -> ] (2016-04-25, 21:39)goibe Wrote: [ -> ] (2016-04-25, 19:15)Guilouz Wrote: [ -> ]When I reorder albums by years, my albums are displayed correctly by years.
Post screenshot please for TV channels number.
Yes the albums are displayed correctly by years, but that I mean is the possibility to add the original year instead of the media that you have (for example if you have a remastered or reissue album).
Here the screenshots:
http://i.imgur.com/JMTrS3H.png
http://i.imgur.com/ukSo7lS.png
Just tag your songs files with correct years.
OK, thanks for answer, I was looking for a solution without doing that because in some albums I have more than one different media for the same albums tagged correctly by the media released year, so thanks anyway.
And, ¿the 4 digit TV channels not displaying correctly can be fixed?
Thank you for your effort and your time.
(2016-04-25, 22:04)goibe Wrote: [ -> ] (2016-04-25, 21:53)Guilouz Wrote: [ -> ] (2016-04-25, 21:39)goibe Wrote: [ -> ]Yes the albums are displayed correctly by years, but that I mean is the possibility to add the original year instead of the media that you have (for example if you have a remastered or reissue album).
Yes it can be but since last Kodi build I have lost PVR functionnality, I see for that and I could fix it.
(2016-04-25, 21:55)Guilouz Wrote: [ -> ]No, not for all over the skin because there is infos on bars on others screens.
Ok understand. What about an option to set opacity of the info bars background ?
If opacity is set to 100 %, the bar is invisible but info is still shown. Will look much more cleaned up in my opinion
(2016-04-25, 21:51)Guilouz Wrote: [ -> ] (2016-04-25, 20:30)movie78 Wrote: [ -> ]@Guilouz
Nice job!!
Can the transparent blue over fanart be remove?
Thank!
It can, I will see for users can select color and opacity.
You did what i previously requested....
Quote:1-Movie the ClearLogo to the Left
2-Increase the size of Clearlogo
3-Add Studio flags
4-Remove the information bar Top/Bottom
Thanks!!!
Possibility to change background opacity on last git
Thanks for option of adding path. Missed that feature.
(2016-04-25, 19:17)Guilouz Wrote: [ -> ] (2016-04-25, 16:01)GEHowe1 Wrote: [ -> ] (2016-04-25, 12:18)Guilouz Wrote: [ -> ]Add : + !String.Contains(ListItem.Filenameandpath,.trailer-) + !String.Contains(ListItem.Filenameandpath,.trailer.) in DialogVideoInfo.xml at line 649 (in " ") and tell me if it's working.
EDIT: I just understand what do you mean (it's not the trailer button appears twice on video infos).
Kodi scanning all files in yours folders, that why it showing trailers too.
I realise Kodi is scanning all files and showing movie plus trailer - but wanted to avoid having trailer listed as well in primary listings - ok once selected movie to see choice of movie or trailer - or just pickup local trailer when selecting 'trailer' within 'information' - hope that makes sense.
It's not possible.
Please have a read of this thread - it seems that what I am trying to achieve maybe possible :
(i) Exclude trailers from listing
(2) Trailer matching
http://forum.kodi.tv/showthread.php?tid=206161
Thanks for great work.
(2016-04-26, 01:53)Guilouz Wrote: [ -> ]Possibility to change background opacity on last git
Excellent work there. From the default of 21% to 90% and "Hello background"
Having movie ratings is really useful.
What is the rating source?
Can you choose between different souces?
I am very sad and old enough not to see well my samsung 32 inch .... Guilouz you do something to enlarge the characters please!
(2016-04-26, 10:00)GEHowe1 Wrote: [ -> ]Having movie ratings is really useful.
Rating is from IMDB. It's default rating from Kodi.
(2016-04-26, 11:11)Palexxtra Wrote: [ -> ]I am very sad and old enough not to see well my samsung 32 inch .... Guilouz you do something to enlarge the characters please!
I can't, This will spoil all the skin...
I already told you you can edit Font.xml to change font size but me I have no plain to do this.
