Does this mod also support hiding watched media from the frontpage? I have this currently custom setup on a different skin, but if this can be supported out of the box it would be awesome
(2016-08-23, 03:55)Gracus Wrote: [ -> ]Seems like animated posters does not work with "in progress movies" widget (red) but works for other widget (blue)
If you browse TV show in wall wiew, it shows first season year instead of aired year for épisodes (works fine if you change to list view)
Same date issue when playing episode
I can't do nothing for that, it's the same code for both.
It's not an issue, it's year of the tv show, not of episode.
(2016-08-23, 11:00)Senaxx Wrote: [ -> ]Does this mod also support hiding watched media from the frontpage? I have this currently custom setup on a different skin, but if this can be supported out of the box it would be awesome
Yes you can, you just need to enable this setting in skin helper service settings.
(2016-08-23, 11:43)Guilouz Wrote: [ -> ]I can't do nothing for that, it's the same code for both.
So why is it showing year of the TV show on wall view BUT showing aired date on list view?
(2016-08-23, 11:52)Gracus Wrote: [ -> ] (2016-08-23, 11:43)Guilouz Wrote: [ -> ]I can't do nothing for that, it's the same code for both.
Because there is no more space on wall view to show aired date (like 01/01/2016).
(2016-08-23, 12:06)Guilouz Wrote: [ -> ] (2016-08-23, 11:52)Gracus Wrote: [ -> ] (2016-08-23, 11:43)Guilouz Wrote: [ -> ]I can't do nothing for that, it's the same code for both.
Si it left 2 logical solution:
-show aired year (if possible)
-show no date
(2016-08-23, 12:34)Gracus Wrote: [ -> ] (2016-08-23, 12:06)Guilouz Wrote: [ -> ] (2016-08-23, 11:52)Gracus Wrote: [ -> ]So why is it showing year of the TV show on wall view BUT showing aired date on list view?
-show no date
Not possible.
Envoyé de mon iPhone en utilisant Tapatalk
(2016-08-23, 12:58)luisfmoreira Wrote: [ -> ] (2016-08-22, 14:01)luisfmoreira Wrote: [ -> ] (2016-08-20, 13:46)Guilouz Wrote: [ -> ]screenshot please.
Well ... since I updated kodi and the skin it's gone... if it shows up again I will take a screenshot!
Got it!!!
https://db.tt/VgYglSTO
What's wrong? It's a notification show the next.
You can disable it in skin settings.
I didn't know how to disable it, or what it was, and sometimes it hangs and just stays on screen (or the EPG info has a problem)!
Je te remercie Guilouz, salutations!!!
How can I add another hub has a total of 3 - Can you explain?
Edit - I found the answer thanks
(2016-08-22, 01:00)Guilouz Wrote: [ -> ] (2016-08-21, 23:30)Repoman Wrote: [ -> ]I had to do a clean wipe of my android box, using the latest nightly builds. Tried installing skin and I "failed to install a dependency". any idea how to resolve this?
Need debug log.
There is only script.skinshortcuts and script.skin.helper.service install with skin.
Install all necessary addons before and retry.
Also getting it on clean install on Windows 10 laptop clean install. I hope this is what you need to debug file.
Quote:11:38:16 T:7688 DEBUG: CAddonInstaller: installing 'skin.estuary.mod' version '1.5.5' from repository 'repository.guilouz'
11:38:16 T:8708 DEBUG: CFileCache::Open - opening <addons/krypton/script.skin.helper.service/script.skin.helper.service-1.0.90.zip.md5> using cache
11:38:16 T:8708 DEBUG: CurlFile::Open(1213AEC0) http://mirrors.kodi.tv/addons/krypton/sc...90.zip.md5
11:38:16 T:8708 INFO: XCURL:llLibCurlGlobal::easy_aquire - Created session to http://mirrors.kodi.tv
11:38:16 T:176 DEBUG: Thread FileCache start, auto delete: false
11:38:16 T:176 INFO: CFileCache:rocess - Source read didn't return any data! Hit eof(?)
11:38:16 T:176 DEBUG: Thread FileCache 176 terminating
11:38:16 T:7688 DEBUG: ------ Window Deinit (DialogAddonInfo.xml) ------
11:38:16 T:8708 DEBUG: CurlFile::Open(1213B598) http://mirrors.kodi.tv/addons/krypton/sc...1.0.90.zip
11:38:16 T:8708 DEBUG: CCurlFile::Open - effective URL: <http://mirror.its.dal.ca/xbmc/addons/krypton/script.skin.helper.service/script.skin.helper.service-1.0.90.zip>
11:38:17 T:8708 ERROR: CAddonInstallJob[script.skin.helper.service]: failed to install dependency script.module.beautifulsoup
11:38:17 T:8708 ERROR: CAddonInstallJob[skin.estuary.mod]: failed to install dependency script.skin.helper.service
11:38:17 T:7688 DEBUG: CGUIMediaWindow::GetDirectory (addons://repository.guilouz/xbmc.gui.skin)
11:38:17 T:7688 DEBUG: ParentPath = [addons://repository.guilouz/xbmc.gui.skin]
11:38:17 T:8708 DEBUG: CAddonDatabase: SELECT repo.id FROM repo .. took 0 ms
11:38:17 T:8708 DEBUG: CAddonDatabase: query SELECT * FROM addons JOIN addonlinkrepo ON addons.id=addonlinkrepo.idAddon WHERE addonlinkrepo.idRepo IN (24) ORDER BY addons.addonID returned 2 rows in 0 ms
(2016-08-23, 16:47)Repoman Wrote: [ -> ] (2016-08-22, 01:00)Guilouz Wrote: [ -> ] (2016-08-21, 23:30)Repoman Wrote: [ -> ]I had to do a clean wipe of my android box, using the latest nightly builds. Tried installing skin and I "failed to install a dependency". any idea how to resolve this?
Need debug log.
Try to install skin.helper.service before skin (on first page).
New Update 1.5.6 on repository :
• Add DTS-HD High Resolution icon
• Add possiblity to hide time and date on top bar
• Fix playspeed label
• Fix poster, clearlogo and fanart when pressing "i" button on widgets
• Fix poster, clearlogo and fanart on video info
• Fix 'Show fanart' on music/video info
• Fix osd not showing with live tv
• Hide notifications on fullscreen
• Allow skip chapters with button on video OSD
• Updated language files from Transifex
(2016-08-23, 13:37)luisfmoreira Wrote: [ -> ]I didn't know how to disable it, or what it was, and sometimes it hangs and just stays on screen (or the EPG info has a problem)!
Je te remercie Guilouz, salutations!!!r
Go into addons/ my addons/ services, And disable the next up notification add-on.
