No problem
[/quote]
Lines 122 and 160 at MyPVRGuide.xml to center the text inside the cells of the EPG.
<control type="label" id="1">
<left>14</left>
<top>10</top>
[url]https://drive.google.com/open?id=0B-
and on line 44 to center the date over the channels
<control type="label">
<width>365</width>
<height>45</height>
<font>font13</font>
<label>$INFO[ListItem.Label]</label>
<textoffsetx>10</textoffsetx>
<align>center</align>
<aligny>center</aligny>
<textcolor>$VAR[SkinColorVar]</textcolor>
</control>
[/quote]
Not possible to do that, there is icons (recording etc) in the bottom of label.
[/quote]
[url]https://drive.google.com/open?id=0B-Et0s
Looks like that on mine.
New at this, I've got square logos when no image is found, at the bottom left, is there a way to make them wider or just centered without mess up with the recording etc?
Hi, newbie question: If I install this skin, will it automatically install the additional addons which are required as listed in post 1 of this thread?
I assume I don't have to install them one by one?
(2016-12-06, 00:26)archie456 Wrote: [ -> ]Hi, newbie question: If I install this skin, will it automatically install the additional addons which are required as listed in post 1 of this thread?
No, you need to install them manually because some of them are not on official repo.
Envoyé de mon iPhone en utilisant Tapatalk
[/quote]
[/quote]
I'm new at this, I've got square logos when no image is found, at the bottom left, is there a way to make them wider or just centered under the channel names without mess up with the recording etc?
[/quote]
Could you please add those 2 genders as well? forgot to include them
Thanks for your effort, the mod is looking great.
Is the cdart working in fullscreen music?
I only see the generic cd even when a cdart is present for the sounding album.
Using latest 1.7.1 and kodi 17 beta 6
(2016-12-06, 02:24)goibe Wrote: [ -> ]Is the cdart working in fullscreen music?
Yes it's working. Make sure you have latest Skin Helper Service addon.
@ Guilouz,
Not giving an option where to backup skin
(2016-12-06, 02:54)Blurayx Wrote: [ -> ]@ Guilouz,
In Skin Helper backup settings ^^
(2016-12-06, 02:55)Guilouz Wrote: [ -> ] (2016-12-06, 02:54)Blurayx Wrote: [ -> ]@ Guilouz,
Thanks, I didn't realise the skin backup feature changed
First I would like to say great Mod. I'm trying to add some items to the main menu and I'm having one problem. Once I have added items to the menu (ActivateWindow(TVRecordings) I have to click on them to get them to Activate. All of the preexisting items are activated (displayed) as you scroll through them. How can I get the recordings to display when I scroll up or down and come to recordings in the menu list?
(2016-12-06, 02:28)Guilouz Wrote: [ -> ] (2016-12-06, 02:24)goibe Wrote: [ -> ]Is the cdart working in fullscreen music?
I was using the last version but without configure it, so working now.
Hi Guilouz, hi all.
For what I know actually the rating score is taken from "IMDB".
See the red arrow here:
Please, is it possible to add the possibility so the user can choose to take the rating score from "TMDB"?
I mean a new option to the skin so the user can choose to take the rating score from "TMDB" or from "IMDB".
The scroll bar (right) in Favorites is overlapped with the items in it.
Hi Guilouz, do you have any interest adding the database cleaning feature (
http://forum.kodi.tv/showthread.php?tid=272112) to the skin? It's very useful IMHO.
(2016-11-26, 19:41)braz Wrote: [ -> ]Great work, thanks! Here's what I did...
For the different colored On/Off labels, I couldn't get a variable to work, so just made separate controls. This is what you would have to do anyway, I think, for the skin that ships with the script.
https://github.com/braz96/skin.mimic/blo...ummary.xml
One suggestion is to put the on/off labels into label2 controls in list #10, then you wouldn't need two lists. Not sure what that would take in python though.
