(2016-12-20, 09:46)Iceman360 Wrote: [ -> ] (2016-12-19, 20:07)outcave Wrote: [ -> ] (2016-12-19, 14:32)outcave Wrote: [ -> ]mmm.... So the problem exists!
A ghost issue? Yes it could be IF I installed/updated/reinstalled the stuff (Kodi, Skin, addons, etc..). BUT about my case, it was all done from the beginning (total re installation of Kodi, addons and skin)... So in this case I cannot figure out a "ghost issue".
May be the problem is related to Skin Helper, but I don't know how to understand if it's the problem.
Some more screen shots of the problem of a "Top movie", double TMDB and the Top movie flag/icon:
See here the Metadata during play, it show IMDB with the same rating value of TMDB....:
Also have this issue when I change to tmdb. Using imdb it works fine.
Hi Guilouz.
It seem that I'm not the only one to have this issue (on Kodi 17).
Any chance to get it working? What do you need from us to address the issue?
What I like about this skin apart from its look and features, is the ongoing activity and support in this forum from the users and the creator. Well done [emoji1376]
Sent from my iPhone
(2016-12-20, 10:26)iMak Wrote: [ -> ]What I like about this skin apart from its look and features, is the ongoing activity and support in this forum from the users and the creator. Well done [emoji1376]
Sent from my iPhone (typie typie)
I agree!
Guilouz is always available to address the issue and to implement what users wants!
(2016-12-20, 10:43)outcave Wrote: [ -> ] (2016-12-20, 10:26)iMak Wrote: [ -> ]What I like about this skin apart from its look and features, is the ongoing activity and support in this forum from the users and the creator. Well done [emoji1376]
I agree!
Sorry, I made a mistake with skin for Kodi 17. Try last git, I have fixed this issue.
Stop providing your custom made French language Addon cause its wrong
We provide official Kodi language Addons and the one you provide from your repo screws things up.
(2016-12-20, 13:48)Martijn Wrote: [ -> ]We provide official Kodi language Addons and the one you provide from your repo screws things up.
Ah sorry, I have not find transifex for Kodi 18. That's why I have add this to my repo, to keep all my kodi systems up to date with language.
(2016-12-20, 13:51)Guilouz Wrote: [ -> ] (2016-12-20, 13:48)Martijn Wrote: [ -> ]We provide official Kodi language Addons and the one you provide from your repo screws things up.
Do not do that! You cause problems for others by doing that.
Transfix will remain on v17 until we decide no more updates are needed and then we move to v18. So there is no official transifex for v18 so you cannot have updated language files.
(2016-12-20, 13:54)Martijn Wrote: [ -> ] (2016-12-20, 13:51)Guilouz Wrote: [ -> ] (2016-12-20, 13:48)Martijn Wrote: [ -> ]We provide official Kodi language Addons and the one you provide from your repo screws things up.
I will remove it.
Some strings are not translated for v18, that's why I have added my personnal translation.
(2016-12-20, 13:41)Guilouz Wrote: [ -> ] (2016-12-20, 10:43)outcave Wrote: [ -> ] (2016-12-20, 10:26)iMak Wrote: [ -> ]What I like about this skin apart from its look and features, is the ongoing activity and support in this forum from the users and the creator. Well done [emoji1376]
I agree!
For "fixed the issue", do you mean the "double TMDB" is now solved for Kodi 17?
(2016-12-19, 13:20)outcave Wrote: [ -> ]Please, is it possible to add the "Release date" (with scrolling enabled) of the movie (how does Estuary v2) in the "red box" below?
Hi Guilouz,
is it possible to do that in a next update?
(2016-12-19, 12:57)Guilouz Wrote: [ -> ] (2016-12-19, 08:49)xodi Wrote: [ -> ]I turned off the animated poster in skin settings and deleted the "/userdata/Thumbnails/animatedgifs" folder, but the this folder is constantly created by skin helper service addon and a lot of gifs are downloaded to this folder again and again. After fixed the bug in skin helper service addon, these gifs are still downloaded, but I think the issue currently is on the skin mod.
I dumped the skin settings with the skin backup and got these variables related with this in guisettings.txt:
(u'bool', 'Skin_EnableAnimatedPosters', 'false')
(u'bool', 'SkinHelper.EnableAnimatedPosters', 'true')
These two variables should have the same value "false", but don't know why the "SkinHelper.EnableAnimatedPosters" is still true. Because this value is true, skin helper service think it should retrieve animated poster information and download the gifs again and again.
In the skin, the variable is set by
<onload condition="Skin.HasSetting(Skin_EnableAnimatedPosters)">Skin.SetBool(SkinHelper.EnableAnimatedPosters)</onload>
Could you please check this?
My code is correct, see : https://github.com/marcelveldt/script.sk...imated-Art
Not a a skin issue.
The issue is this:
In the SkinSettings.xml, the code only change the value of skin (Skin_EnableAnimatedPosters), but not the value of skinhelper addon (SkinHelper.EnableAnimatedPosters)
<control type="radiobutton" id="647">
<label>40056</label>
<width>1256</width>
<include>DefaultSettingButton</include>
<onclick>Skin.ToggleSetting(Skin_EnableAnimatedPosters)</onclick>
<selected>Skin.HasSetting(Skin_EnableAnimatedPosters)</selected>
</control>
And in the Home.xml, there is only one condition
so if the animated poster is enabled once, its value is never reset to false, so skin think animated poster is disabled, but the skinhelper addon think it's still enabled, thus download gifs constantly.
I created a pull request here to fix this.
https://github.com/Guilouz/repository.guilouz/pull/64
