(2016-12-23, 09:44)outcave Wrote: [ -> ] (2016-12-22, 23:40)Guilouz Wrote: [ -> ]Can't fix first because window property not working in container. Just Kodi core rating can be used.
Second is fixed (need latest skin helper service from git). I have reported this issue to marcelveldt and it's fixed. Need last skin git too.
Many Thanks!!!
But, the rating number in "home page" that is wrong because it's still taken from TMDB (vote 7.2) also if it is IMDB (vote 8.0) that is enabled, cannot be fixed?
I mean this one:
It's possible, I have not finished yet.
Great! I will wait for that other fix, thanks as usual.
I think, after that others fix, that you can release the 1.7.3 as a Christmas gift!!!
(2016-12-21, 05:24)Gracus Wrote: [ -> ]And now a little "request"
(no pressure: only if it can be done and if you want to)
Actually, the skin show for movie set the clearlogo (or clearart?) of the first movie of the set
Could it be possible to add a setting to change the movie set clearlogo (or clearart?) like we can already do it for fanart and poster?
Some news about this one?
(2016-12-23, 14:55)Gracus Wrote: [ -> ] (2016-12-21, 05:24)Gracus Wrote: [ -> ]And now a little "request"
Ask to marcelveldt to add this for movieset. There is no function to do that.
I use addon for movieset to configure them.
Hi, not sure if I'm missing something but I cannot seem to get the screensaver to stay off while playing music. I have it disabled in the skin music osd settings and the option ticked under interface screensaver settings to show visualization when playing audio. I use the artist fanart when playing music but the screensaver still kicks in.
Just wondering if anyone else has this issue or any ideas as to what is happening?
Cheers.
Hi
Have just installed a fresh copy of kodi-17.0-Krypton_beta7 and the latest Estuary MOD skin. I am having trouble getting my Video-AddOn widgets to stick. The video shows my YouTube widget displaying correctly - then I leave the menu item and return and its vanished! Is this a bug? Or something I'm doing wrong?
(2016-12-23, 15:08)Guilouz Wrote: [ -> ] (2016-12-23, 14:55)Gracus Wrote: [ -> ] (2016-12-21, 05:24)Gracus Wrote: [ -> ]And now a little "request"
Hi Guilouz (and merry christmas)
Had an answer and seems that skin.helper already allow it
Angelinas give the code here:
http://forum.kodi.tv/showthread.php?tid=...pid2485015
And has been confirming working a little bit later by Marcelveldt
(2016-12-24, 15:26)Gracus Wrote: [ -> ] (2016-12-23, 15:08)Guilouz Wrote: [ -> ] (2016-12-23, 14:55)Gracus Wrote: [ -> ]Some news about this one?
Merry Christmas too.
I have already $INFO[Window(Home).Property(SkinHelper.ListItem.Art.Clearlogo)] in my code.
You can change clearlogo here but it's not the same like for music artworks. There is no choice. You can only add them while browsing your hard disk.
I'm not really understand that he mean by "chosen from context menu movieset-choose art)".
(2016-12-24, 12:00)beeve Wrote: [ -> ]Hi
If you use personnal widget, it's better to use customizable widget.
(2016-12-24, 16:45)Guilouz Wrote: [ -> ] (2016-12-24, 15:26)Gracus Wrote: [ -> ] (2016-12-23, 15:08)Guilouz Wrote: [ -> ]Ask to marcelveldt to add this for movieset. There is no function to do that.
Even weirder!
I do not have a way to choose movie set clearlogo like you:
As you can see, I can only choose fanart and poster for the movie set
Latest nightly v18 with latest MOD from your git
Will try to dig into the xml files and see if I found what could go wrong
(2016-12-24, 17:52)Gracus Wrote: [ -> ]Will try to dig into the xml files and see if I found what could go wrong
Not skin issue, I have the same with original Estuary :
(2016-12-24, 17:55)Guilouz Wrote: [ -> ] (2016-12-24, 17:52)Gracus Wrote: [ -> ]Will try to dig into the xml files and see if I found what could go wrong
Yep!
Does not work for me neither on stock estuarry v2:
I really start to be bored by all those things in kodi that works on some OS and not on the others...
