(2017-01-10, 18:32)xodi Wrote: [ -> ]The discart/cdart never be downloaded automatically and I only got a white hand write discart/cdart. This issue appears for a long time for Android with sdcard/usb (may be write permission issue?). I'm not sure whether it's the issue with new skin helper service. Anyone has this issue with Android? I'm sure it's working several months ago, and the issue seems appear since the skin intruduected the hand write discart/cdart.
Not an android issue
Does not work for me either with kodi 18 on windows
Thanks for the great skin.
I have an issue that I hope can be fixed
I have installed the Kodi 17 RC2 on 2 Windows PCs with access to the same network drive. Latest Estuary Mod installed.
Both have the same issue with duration not showing for movies. It works for TV shows. Also no issue with default Estuary skin.
(2017-01-10, 20:38)willson Wrote: [ -> ]Thanks for the great skin.
Just try with Kodi 17 version of my mod and it's work fine :
Make sure you have latest Skin Helper Service and his necessary addons.
New Update 1.7.4 on repository :
• Add support for postplay screen from Nextup Service Notification addon
• Add pattern to extended info windows
• Bump xbmc.gui to 5.13.0 (Kodi 18)
• Fix missing changes for new Skin Helper Service addons
• Fix clearlogos aspect ratio for TV Shows widgets
• Fix rss on widgets focus
• Minnor fix
(2017-01-10, 23:06)Guilouz Wrote: [ -> ]New Update 1.7.4 on repository :
• Minnor fix
Thanks for the update!
Will try it as soon as Team kodi give me the ability to do it...
hello, i have a question. im using this skin on a desktop and laptop with the same settings and its fine. i want to use it also on my tablet but the thing is there are no touch buttons
and i cant find the option to enable the "floor" buttons. does the skin include these buttons?
still showing 1.7.3 for me ??
(2017-01-11, 11:03)sepulchre Wrote: [ -> ] (2017-01-10, 23:06)Guilouz Wrote: [ -> ]New Update 1.7.4 on repository :
I had to uninstall \ install Guilouz Repository. Then 1.7.4 showed up in the update.
(2017-01-10, 23:02)Guilouz Wrote: [ -> ] (2017-01-10, 20:38)willson Wrote: [ -> ]Thanks for the great skin.
I have all latest versions of 'Necessary addons', apart from script.skin.helper.skinbackup and script.skin.helper.widgets, neither of which seem to want to install (they dont do anything when I click on them).
Mine also doesn't show the movie rating, I wonder if that's related.
anyone else unable to install script.skin.helper.widgets
i get errors for it in my kodi log
http://pastebin.com/FZfXiYNW
i'm running on windows 10 kodi 17 rc3
(2017-01-11, 12:44)willson Wrote: [ -> ] (2017-01-10, 23:02)Guilouz Wrote: [ -> ] (2017-01-10, 20:38)willson Wrote: [ -> ]Thanks for the great skin.
Do you try to install them from the skin settings?
If yes, then grab them from the link in OP of this thread and use "install from zip"
(2017-01-11, 13:05)kingdingaling Wrote: [ -> ]anyone else unable to install script.skin.helper.widgets
There is no error of install in your log.
There is only error that say script.skin.helper.widgets is not installed.
11:02:45.748 T:2760 ERROR: Unable to find plugin script.skin.helper.widgets
Install it manually or from marcelveldt repo
