(2017-08-31, 14:50)Zvezke Wrote: [ -> ]Hi all!
I know that I'm able to 'Backup/Restore' my skin in 'Settings' -> 'Skin settings', but where is the backup file located? I can't find it anywhere.
All help is appreciated.
Location is define in Skin Helper Service Skin Backup settings, you can also change it.
(2017-08-31, 21:29)Guilouz Wrote: [ -> ] (2017-08-31, 14:50)Zvezke Wrote: [ -> ]Hi all!
Ahh, why didn't I think of this. Thanks a lot.
... and thanks for this great skin, by the way. Great work.
Had to reinstall the entire system after messing things up. Now I'm getting 'Installation failed' as soon as I try installing this skin.
Is your repo down?
(2017-09-02, 00:59)Zvezke Wrote: [ -> ]Had to reinstall the entire system after messing things up. Now I'm getting 'Installation failed' as soon as I try installing this skin.
Is your repo down?
No, no problem, it's working.
(2017-09-02, 01:57)Guilouz Wrote: [ -> ] (2017-09-02, 00:59)Zvezke Wrote: [ -> ]Had to reinstall the entire system after messing things up. Now I'm getting 'Installation failed' as soon as I try installing this skin.
Is your repo down?
Strange. Tried again this morning – still 'Installation failed'. I did a clean install (reflashed the sd), but no.
Here is my log file:
http://paste.ubuntu.com/25450017/
I've noticed this error at the very end:
CCurlFile::Open failed with code 404 for
https://github.com/Guilouz/repository.gu...1.7.14.zip
(2017-09-02, 11:21)Zvezke Wrote: [ -> ] (2017-09-02, 01:57)Guilouz Wrote: [ -> ] (2017-09-02, 00:59)Zvezke Wrote: [ -> ]Had to reinstall the entire system after messing things up. Now I'm getting 'Installation failed' as soon as I try installing this skin.
Is your repo down?
Here is my log file: http://paste.ubuntu.com/25450017/
CCurlFile::Open failed with code 404 for https://github.com/Guilouz/repository.gu...1.7.14.zip
Same here trying to install Estuary MOD (KODI17) it says installation failes
(2017-09-03, 12:45)menomenic Wrote: [ -> ] (2017-09-02, 11:21)Zvezke Wrote: [ -> ] (2017-09-02, 01:57)Guilouz Wrote: [ -> ]No, no problem, it's working.
from
Yeah, it hasn't been fixed yet.
To install the skin, you can go the zip file's parent directory in the URL above:
https://github.com/Guilouz/repository.gu...tuary.mod/
... and download the file 'skin.estuary.mod-1.7.14.zip.20170901235001'.
Or you can just download the file directly from
this link
Remove the numbers (timestamp?) in the end, and you have the zip file. Move the zip to your Kodi and 'Install from zip' and the skin should install.
The problem seems to be that the zip file on Github has been appended with a timestamp. As Kodi is looking for the file without the timestamp, an error 404 is caused.
It's fixed ! That was a mistake ^^
Hi everyone ,
The master lock hides all the movies in my smart playlists when it's enabled. Is it related to this skin ?
Any chance of a Big Poster View like Arctic Zephyr skin. Also the Kodi 18 mod from Guliouz has a panel poster widget. Any chance this could be implemented?
(2017-09-10, 10:16)LloydShow Wrote: [ -> ]Any chance of a Big Poster View like Arctic Zephyr skin. Also the Kodi 18 mod from Guliouz has a panel poster widget. Any chance this could be implemented?
Development for this version is stopped since many month. So no implementation/addition.
Is anyone taking over and maintaining this skin?
For some reason I can't get smooth playback on local files on Kodi 18 so have had to abandon your Estuary 18 skin on there.
This skin isn't for Kodi 18 but for Kodi 17.
The original developer is making a skin for Kodi 18.
I believe it's already available.
Verstuurd vanaf mijn GT-I9505 met Tapatalk
Amazing skin! Perfect! The main thing I was always looking for in a skin (since nobody seems to have it) is the ability to easily go back to the full screen view after hitting the back button while watching a TV show. This has the feature. Not sure why other skins don't have that feature. Along with the Estuary look and feel, it's also very customizable. Thank you!.
Hello,
There is no HDR 4K logo in files naming ?
Thx
