(2016-05-23, 22:08)zag Wrote: [ -> ] (2016-05-23, 21:55)movie78 Wrote: [ -> ]Do you where I can find the list for moviedb naming convention?
https://www.themoviedb.org
Thanks guys, moviedb naming convention seems to work
how do i fix the movie time?
it is like this:
for example:
2:.... ( it is suppose to be like 2:30 or something like that)
(2016-05-22, 17:37)AnthonyJS02 Wrote: [ -> ] (2016-05-22, 17:14)Guilouz Wrote: [ -> ] (2016-05-22, 16:27)AnthonyJS02 Wrote: [ -> ]How would disc art look above the big poster view in movie? Is it possible to add?
Also In one of your views, I saw your movie sets had data. I have never been able to manage to get that to display. Is that a setting or nfo for movie sets?
No not possible, no more space.
I use Movie Set Artwork addon. Here : http://forum.kodi.tv/showthread.php?tid=153502
Sounds good, I dont know if this a bug for my setup or in general. In certain views, specifically related to movie sets. Movie set posters are not displaying correctly for some sets in some views. Other sets it displays correct for example:
Correctly displays all posters:
List
Poster
Info Wall
Wall
Displays some set posters and some thumbnails/landscapes:
Shift
Big Posters
I am also having the skin use thumbnails instead of posters on some movies using the clear art view.
New Update 1.1.8 :
• Add Last/Next Aired episode on some views and on TV Shows info
• Add Extendedinfo video search support
• Add T9 search dialog addon support
• Update for GlobalSearch addon
• Fix visualisation over fading
• Fix header label of picture widget
• Fix widget selection when no submenu is define
• Fix popup notification on startup
• Fix scrollbars and media menu in some case
• Fix posters on some views
thanks for the update..
btw, how to get fanart in homescreen widget, like default esturay?
and can you put in option for thumbnail in recently added episode? coz every update i manually edit in home.xml >.<
Most recent update fixed the posters in clearart view.
Is there a way to use fanart as the logo if there is no logo to use in the clearlogos viewtype?
(2016-05-24, 07:02)estuary_enthusiast Wrote: [ -> ]thanks for the update..
Not possible with skin.shortcuts.
No I do not plain to do this.
Available on last git for ClearLogos and ClearArts views
Great, is there a how to somewhere to see how to do it?
