(2016-06-20, 19:54)elchupete Wrote: [ -> ] (2016-06-20, 18:41)bg_x Wrote: [ -> ] (2016-06-19, 23:09)Guilouz Wrote: [ -> ]You need to enable auto update addons in settings or you can update manually in media menu when you are in addons settings.
No that doesn't work. I will make later a screenshot.
Gesendet von meinem CRR-L09 mit Tapatalk
Had the same problem. Try to manually update the Repo (not the skin). After the Repo was updated, Skin updates are executed automatically.
Thx I uninstalled repro and skin and now it worked!
(2016-06-20, 09:48)estuary_enthusiast Wrote: [ -> ]hi, rotten bug when 100%
and, any chance to set colour to white like other flag?
I will fix it in next release.
I've just discovered this excellent new skin in the forum (Thanks Guilouz)
Just a quick question - do i need to install all the addins on the first page if I want to use this skin with Krypton or have they been integrated into the mod by now.
Hi again,
Is there anywhere that the IMDb TT numbers are shown for a selected movie.
I'm currently replacing all my posters and fanart for animated ones, but to identify the artwork I need to look up the TT numbers.
For your info, manually selecting them as posters and fanart allows them to run on the home screen widgets, it looks great.
Thanks again.
(2016-06-21, 14:47)JohnWB Wrote: [ -> ]I've just discovered this excellent new skin in the forum (Thanks Guilouz)
Yes you need install necessary addons first. And additional for better experience.
Request:
Remove the box on the ratings
Can the Video OSD look like this?
(2016-06-21, 16:14)movie78 Wrote: [ -> ]Request:
Box is present to keep same look as other flag icons.
It's already look like that.
Thanks Guilouz for this very good skin !!!
Have you planned to integrate CDarts in Movies views too?
Kebnekajse
(2016-06-21, 18:18)kebnekajse Wrote: [ -> ]Thanks Guilouz for this very good skin !!!
Kebnekajse
No, no more space to add this.
Hi. Found this mod skin as suggested in the Intel NUC 3D thread and love that I can have Atmos and dts:X logos. One question I have is there a way turn the sounds on and off? I like the "click" sound when you move around your movies and stuff but there's a loud "BRNG!" kinda sound that happens when I stop playing a 3D video and it's very loud. Shocks the Mrs. and the kids watch 3D movies and videos a lot. Is there a setting to turn sounds of I haven't discovered yet?
(2016-06-22, 06:47)Charger Hellcat Wrote: [ -> ]Hi. Found this mod skin as suggested in the Intel NUC 3D thread and love that I can have Atmos and dts:X logos. One question I have is there a way turn the sounds on and off? I like the "click" sound when you move around your movies and stuff but there's a loud "BRNG!" kinda sound that happens when I stop playing a 3D video and it's very loud. Shocks the Mrs. and the kids watch 3D movies and videos a lot. Is there a setting to turn sounds of I haven't discovered yet?
Set your GUI sound to Never or to Only when playback stopped
Thanks for the reply. I was more meaning is there a setting to only silence certain sounds? I do like some of them but the loud notification(?) sounds are a problem.
(2016-06-22, 09:14)Charger Hellcat Wrote: [ -> ]Thanks for the reply. I was more meaning is there a setting to only silence certain sounds? I do like some of them but the loud notification(?) sounds are a problem.
And which sounds would that be? You mean GUI sounds right? You can't disable specific GUI sounds that i'm aware of, you can change to other sounds though.
Not sure if been asked but can the TV guide be a widget on the home screen when on the live tv tab?
Anyway to adjust guide to increase size by limiting the amount of hours shown? First time using the pvr part of Kodi so just learning it a bit.
(2016-06-22, 12:31)AnthonyJS02 Wrote: [ -> ]Not sure if been asked but can the TV guide be a widget on the home screen when on the live tv tab?
It's already done for next release
I dont understand what do you mean for guide ?
