(2016-06-29, 18:02)Synopis Wrote: [ -> ] (2016-06-29, 17:10)Guilouz Wrote: [ -> ] (2016-06-29, 16:54)Synopis Wrote: [ -> ]I'm unable to use the right arrow key to move to in progress tv shows and the random/unwatched movies sections.
Edit
Media info is also cut off
http://i.imgur.com/Q2WnsUw.png
Click on arrow ? That's right? I will see when I go back home.
For end time media flag icon, you must configure your time format correctly, see posts I have already talking about that.
Whenever I press the right arrow key on my keyboard.. I can go to the in progress tv show section and it would go directly to the shows seasons. I'm unable to do that and instead I have to go to tv shows and hunt for the tv show I want to watch.
http://i.imgur.com/UBEufoo.png
I just test it, I can navigate without problem in progress tv shows widget, same for random movies.
In select widget , no thing work.. Addons , video library , defualt widgets , only skin helper service widgest can opened .
before i update to your latest mod , widgets was working partly .
this bugs related to your skin mod , not to skin shouttcut script becouse i switched to titan for now , and widgets work perfectly now. No hasles to add media or widgets . Please try to fix home shouttcut implementation in your mod . Thank you.
(2016-06-29, 22:11)samehvirus Wrote: [ -> ]In select widget , no thing work.. Addons , video library , defualt widgets , only skin helper service widgest can opened .
Oh yes I just see that. I will fix it.
EDIT : Fix with new update on repo.
When playing a video, I always got two "Extended info" buttons (A screen capture here
http://imgur.com/SVXyHnr ), is this expected? And the meta data of the video can only be seen from the "Media info" -> "Metadata", is it possible to show this information directly without pressing buttons several times, just like the kodi before version 17?
(2016-06-30, 04:46)xodiuser Wrote: [ -> ]When playing a video, I always got two "Extended info" buttons (A screen capture here http://imgur.com/SVXyHnr ), is this expected? And the meta data of the video can only be seen from the "Media info" -> "Metadata", is it possible to show this information directly without pressing buttons several times, just like the kodi before version 17?
What is the type of video you play ? Movie, tv shows, live tv ?
(2016-06-29, 19:14)Guilouz Wrote: [ -> ] (2016-06-29, 18:02)Synopis Wrote: [ -> ] (2016-06-29, 17:10)Guilouz Wrote: [ -> ]Click on arrow ? That's right? I will see when I go back home.
I've been unable to for the past 3-4 versions as that was the time I downloaded this mod.
(2016-06-30, 12:08)Guilouz Wrote: [ -> ] (2016-06-30, 04:46)xodiuser Wrote: [ -> ]When playing a video, I always got two "Extended info" buttons (A screen capture here http://imgur.com/SVXyHnr ), is this expected? And the meta data of the video can only be seen from the "Media info" -> "Metadata", is it possible to show this information directly without pressing buttons several times, just like the kodi before version 17?
It's the same for all types of video you listed. I'm using Android version of Kodi.
(2016-06-30, 16:56)Synopis Wrote: [ -> ] (2016-06-29, 19:14)Guilouz Wrote: [ -> ] (2016-06-29, 18:02)Synopis Wrote: [ -> ]Whenever I press the right arrow key on my keyboard.. I can go to the in progress tv show section and it would go directly to the shows seasons. I'm unable to do that and instead I have to go to tv shows and hunt for the tv show I want to watch.
Problem with your system, not skin.
(2016-06-30, 19:49)Guilouz Wrote: [ -> ] (2016-06-30, 19:38)xodiuser Wrote: [ -> ] (2016-06-30, 12:08)Guilouz Wrote: [ -> ]What is the type of video you play ? Movie, tv shows, live tv ?
No problem for me :
Movie content
Episode content
It's wired. I have these two buttons from the first time I use Krypton and your mod. When click he first button, it will shows the complete extended info, but clicking the second button only shows several buttons, like "Your rating, Add to list", etc., no other things, so at first, I thought it's normal.
When playing a video, I always got two "Extended info" buttons also for me. Why?
(2016-06-30, 20:34)Palexxtra Wrote: [ -> ]When playing a video, I always got two "Extended info" buttons also for me. Why?
You launch you video from library ?
Whats the best way to upgrade the skin to v1.3.1?
Currently im on 1.2.9. is it to go to gitHub and download the .zip and copy across?
thanks
