hi
ar you going to insert Custom Hub?
(2016-07-05, 18:59)hib1000 Wrote: [ -> ] (2016-07-03, 21:18)drsaini88 Wrote: [ -> ] (2016-07-03, 20:23)avia Wrote: [ -> ]me to
I am also having this problem
Same problem here
New update will arrive. I have fixed this.
(2016-07-05, 21:25)avia Wrote: [ -> ]hi
No, I do not plan to do this.
I know there is currently a vertical and horizontal media bar orientation but is it possible to add a setting to switch the horizontal media bar from top to bottom or vice versa?
New Update 1.3.3 on repository :
• Add IMDB Top 250 flag icon
• Add possibility to change background color regardless of main skin color
• Add button for Color Management on video OSD
• Add complete discography on artist info
• Now use Skin Helper Service for artists and albums description
• Fix missing posters and fanarts on some views (thanks elchupete for his beta testing)
• Other minor fixes
• Updated language files from Transifex
• Cleanup code
This skin mod is my favorite out of all of them...keep up your great work
I'm still only seeing 1.3.2 in the repo. Has it been updated yet?
(2016-07-06, 10:16)hib1000 Wrote: [ -> ]I'm still only seeing 1.3.2 in the repo. Has it been updated yet?
Yes. You must enable auto update adons in settings or you can manually update.
Maybe a bug. When browsing tvshow,
GUI Language: English
GUI language:chinese
MOD 1.3.3
(2016-07-06, 12:30)startv Wrote: [ -> ]Maybe a bug. When browsing tvshow,
MOD 1.3.3
Check if your Kodi translation file is fully translated.
Is the finish time bugged? It seems to be cut off.
(2016-07-06, 12:38)hib1000 Wrote: [ -> ]Is the finish time bugged? It seems to be cut off.
Check other posts, i have already talking about that many times.
(2016-07-06, 12:37)Guilouz Wrote: [ -> ] (2016-07-06, 12:30)startv Wrote: [ -> ]Maybe a bug. When browsing tvshow,
MOD 1.3.3
I tried chinese(traditonal),also bugged.
I have checked the file:Kodi\addons\resource.language.zh_cn\resources\strings.po, Seemes all be translated
Could you tell me which file I'll check and where is the file location.Thank you
