(2016-07-29, 15:39)hedeon Wrote: [ -> ]Hi @Guilouz,
i have a smal issue.
if i browse my TV Shows i see on every third season the "revenge" clearlogo in the upper left corner.
I dont have the revenge TV Show
only on the third season
but at every TV Show
has someone else the same issue?
I have sometimes this strange issue with osx build, all is ok with LibreElec.
Last builds for Windows and OSX seems to be very bugued...
Envoyé de mon iPhone en utilisant Tapatalk
(2016-07-29, 16:58)hedeon Wrote: [ -> ] (2016-07-29, 16:22)Guilouz Wrote: [ -> ] (2016-07-29, 15:39)hedeon Wrote: [ -> ]Hi @Guilouz,
Thanks, i have this on Windows and on my Raspberry Pi 3 with osmc to
I will try to fix this.
Got another issue:
By accident i deleted the Addons menu item. Simple as i am i re-added this menu item but found out that i was unable to navigate (to the right) to these addons.
So i compared it with a vanilla skin setup and noticed i was missing a few options:
This is the vanilla version:
Notice the icons top right!!
This is the re-added version:
Icons missing top right and unable to navigate to shown addons when clicking right button.
(2016-07-30, 00:12)schumi2004 Wrote: [ -> ]Got another issue:
Fixed for next release. A mistake ^^
Guilouz any chance you could look at having the option to either show full movie plot or movie outline?
(2016-07-30, 01:41)LloydShow Wrote: [ -> ]Guilouz any chance you could look at having the option to either show full movie plot or movie outline?
Just try, ListItem.PlotOutline return nothing for me.
New update 1.4.0 on repository :
• Add 'Next airing episodes' widget for TV Shows (Requires script.module.thetvdb which is not yet in any repo (BETA stage), get it from github). Link on first page.
• Add possibility to configure up to 6 widgets for Customizable widgets
• Add new changes from original Estuary 0.8.4
• Rearrange type of widgets
• Improve esthetic appearance
• Fix thumbnails for TV Shows Widgets
• Fix submenu with Picture Widget
• Fix Label2 when movie is linked to TV show
• Fix ClearLogos
• Fix access to addons widgets when there is no submenu
New issue with 1.4.0:
Probably coming from using a 21:9 screen but at least the old "stretch UI issue" was still usable...
This is happening as soon as I install 1.4.0 and even if I select standard estuary again the issue is still there...
(2016-07-31, 06:30)Gracus Wrote: [ -> ]New issue with 1.4.0:
Yes I have added changes from estuary that added support for 21x9 screen but visibly it's not perfect.
I don't have 21x9 screen to add full support for 21x9.
Try to remove line 10 in addon.xml and tell me if it's working like before.
(2016-07-31, 07:12)Guilouz Wrote: [ -> ] (2016-07-31, 06:30)Gracus Wrote: [ -> ]New issue with 1.4.0:
So I remove the following:
<res width="2560" height="1080" aspect="21:9" default="false" folder="1080i" />
And all is working in "stretch mode" again!
I have just installed this MOD and have to say thanks! its a great addon......however I have just one thing that I can't seem to get right!
On the TV front page, I have a total of 4 widgets set up in settings, but only see 2 on the main page, if i try to scroll down (As I can do in the Movies one to access 4 widgets) nothing happens?
Can anyone advise what I'm doing wrong please?
Dave
Hi Guilouz,
have you read my question in post 1351.
a few suggestions:
1. Music Videos: the posters have the wrong size. They must look like in movies. Look default skin.
2. MusicVisualisation.xml: if you change line 85 and 94 (aspectratio) in "keep" and (with) to "498". it's at a 21:9 (widescreen) display monitor correctly
2a: it is possible to at a " if "Total disc Number" ≤ 1" in line 165 for display the disc number ? so if the Album Total Disc ist greater then 1 show "disc1" if ≤ 1 then dont show Text "disc1"
because it make no sense to show the disc number behind Trackname if a Album have only 1 disc
2b: Duration overlaps first and second Next Track (Text) if Track name are long. so i have change line 257-268 to
<control type="label">
<left>30</left>
<bottom>91</bottom>
<width>1858</width>
<height>122</height>
<align>center</align>
<aligny>bottom</aligny>
<label>$INFO[Player.Time]$INFO[Player.Duration, / ]</label>
<font>font12</font>
<shadowcolor>black</shadowcolor>
<textcolor>white</textcolor>
</control>
the only think i dont now how to do, is to bring the <label></label> in foreground
3. Pictures/Customize Submenu/ Set thumbnail <-- think pictures.png is better as default. if you had add more item addtitle.png look like a cemetery :| at the top of Pictures main
EDIT:
Can you test !!! if you change in view_51_poster.xml the line 46-49 and 63-66 is the aspectratio OK ? because at a widescreen, if you scale or stretch, it looks catastrophic
FROM
<top>8</top>
<width>276</width>
<height>394</height>
<aspectratio>scale</aspectratio>
TO
<top>6</top>
<width>276</width>
<height>388</height>
and in myvideonav.xml line 273 from "scale" to "keep" ?
if you have no issue can you change it for us youser with widescreen monitors ?
i example have a resolution 1680x1050 and i think there are a lot of youser with widescreen monitors
so please help us
thanks for your help.
Just a heads up in case this hasn't been reported... Widget slide animations don't work when navigating from a custom menu item. If your navigating from a default menu item, say from "Movies" to "TV shows" widget slide animations will trigger, but navigation to/from a custom menu item the widget slide animations don't trigger. Also, widgets disappear periodically during normal navigation from custom menu items. You have to reload the skin in order for the widgets on a custom menu item to appear again. Thanks.
