Full Version: "play using"
When I browse my Kodi library directly on my desktop I can right-click a movie and push it to a UPNP client via the "play using" function.
Is it possible to do same via the Kore remote app? ie to browse my Kodi library using my tablet, and then push the chosen title to a UPNP client ?
No, that's not possible in Kore's library view, you can only start playing the movie on Kodi.
The best you can do is navigate Kodi's library with the remote and send it to a UPNP client (like you already do in your desktop).
Yeah, the desktop on which Kodi resides is in a different room to the DLNA/UPNP client (smart tv) so I was thinking it would be handy to sit in front of the TV, browse the library via Kore (much faster and nicer UX than crappy DLNA client on TV) and then use the push functionality to play the video to the TV.
Not to worry, thx for reply.
