Full Version: [RELEASE] Photo Copier
Hes my first script I created
it create a Year folder and a Month folder in the Destination Path base on when the photo was taken or the last modified date of it
and copy the image to that location
script.photo.zip
install it
goto Configure and point it to the Destination Path where you want the Images copied to
run it It ask you to point the the Target location which it will remember for next time OK it
them you get a YES/NO question
DONE photo/images put into there right sub folders
I have tested it on
android kodi worked
apple runing kodi it worked
one thing it can't do is copy from smb to smb I think its a python and exifread short fall
Let me Know what you think
ITS DOES NOT DELETE ANY IMAGE/PHOTO IT WILL OVER WRITE IMAGE THO IT SAME NAME
