Here is Bello for Kodi 16 Jarvis
Download:
skin.bello
Github:
https://github.com/butchabay/skin.bello
Most of the changes for Jarvis are done.
There are still missing windows and a few other stuff that should be worked on, but the skin is usable and working.
From time to time i'll push some updates to github, but please be patient as i have other priorities atm.
Enjoy.
You are great. I will test and report. Thanks a lot.
All right! Thanks @butchabay!
Thank you for this, but unfortunately I do have to report a problem. The skin works great on my Raspberry Pi running Openelec up until it's either powered off or rebooted, at which point it enters a never-ending loop of rebooting the Kodi Jarvis splash screen. Here's my log if you can make anything of it.
21:32:10 148.662018 T:1963474944 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:32:10 148.662216 T:1963474944 NOTICE: -----------------------------------------------------------------------
21:32:10 148.662308 T:1963474944 NOTICE: Starting Kodi (16.1-RC2 Git:4cf382f). Platform: Linux ARM 32-bit
21:32:10 148.662384 T:1963474944 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
21:32:10 148.662460 T:1963474944 NOTICE: Kodi compiled Apr 7 2016 by GCC 5.3.0 for Linux ARM 32-bit version 4.4.6 (263174)
21:32:10 148.662766 T:1963474944 NOTICE: Running on OpenELEC (official) - Version: 6.95.2 7.0, kernel: Linux ARM 32-bit version 4.4.6
21:32:10 148.662857 T:1963474944 NOTICE: FFmpeg version: 2.8.6
21:32:10 148.662918 T:1963474944 NOTICE: WARNING: unsupported ffmpeg version detected
21:32:10 148.662979 T:1963474944 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
21:32:10 148.663040 T:1963474944 NOTICE: ARM Features: Neon enabled
21:32:10 148.663101 T:1963474944 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
21:32:10 148.663177 T:1963474944 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
21:32:10 148.663239 T:1963474944 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
21:32:10 148.663300 T:1963474944 NOTICE: special://home/ is mapped to: /storage/.kodi
21:32:10 148.663406 T:1963474944 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
21:32:10 148.663544 T:1963474944 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
21:32:10 148.663651 T:1963474944 NOTICE: Local hostname: OpenELEC
21:32:10 148.663727 T:1963474944 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
21:32:10 148.663834 T:1963474944 NOTICE: -----------------------------------------------------------------------
21:32:10 148.675507 T:1963474944 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
21:32:10 148.688553 T:1963474944 NOTICE: load settings...
21:32:10 148.845947 T:1963474944 NOTICE: Found 2 Lists of Devices
21:32:10 148.846115 T:1963474944 NOTICE: Enumerated PI devices:
21:32:10 148.846191 T:1963474944 NOTICE: Device 1
21:32:10 148.846848 T:1963474944 NOTICE: m_deviceName : HDMI
21:32:10 148.846954 T:1963474944 NOTICE: m_displayName : HDMI
21:32:10 148.847015 T:1963474944 NOTICE: m_displayNameExtra:
21:32:10 148.847092 T:1963474944 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
21:32:10 148.847153 T:1963474944 NOTICE: m_channels : FL,FR
21:32:10 148.847214 T:1963474944 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
21:32:10 148.847290 T:1963474944 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
21:32:10 148.847382 T:1963474944 NOTICE: Device 2
21:32:10 148.847519 T:1963474944 NOTICE: m_deviceName : Analogue
21:32:10 148.847595 T:1963474944 NOTICE: m_displayName : Analogue
21:32:10 148.847672 T:1963474944 NOTICE: m_displayNameExtra:
21:32:10 148.847733 T:1963474944 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:32:10 148.847794 T:1963474944 NOTICE: m_channels : FL,FR
21:32:10 148.847855 T:1963474944 NOTICE: m_sampleRates : 48000
21:32:10 148.847916 T:1963474944 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
21:32:10 148.847977 T:1963474944 NOTICE: Device 3
21:32:10 148.848099 T:1963474944 NOTICE: m_deviceName : Both
21:32:10 148.848160 T:1963474944 NOTICE: m_displayName : HDMI and Analogue
21:32:10 148.848221 T:1963474944 NOTICE: m_displayNameExtra:
21:32:10 148.848282 T:1963474944 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:32:10 148.848343 T:1963474944 NOTICE: m_channels : FL,FR
21:32:10 148.848450 T:1963474944 NOTICE: m_sampleRates : 48000
21:32:10 148.848526 T:1963474944 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
21:32:10 148.848587 T:1963474944 NOTICE: Enumerated PULSE devices:
21:32:10 148.848648 T:1963474944 NOTICE: Device 1
21:32:10 148.848770 T:1963474944 NOTICE: m_deviceName : Default
21:32:10 148.848846 T:1963474944 NOTICE: m_displayName : Default
21:32:10 148.848907 T:1963474944 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
21:32:10 148.848969 T:1963474944 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:32:10 148.849030 T:1963474944 NOTICE: m_channels : FL,FR
21:32:10 148.849091 T:1963474944 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
21:32:10 148.849152 T:1963474944 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
21:32:10 148.873077 T:1963474944 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
21:32:10 148.873520 T:1963474944 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<readbufferfactor>4.0</readbufferfactor>
</network>
</advancedsettings>
21:32:10 148.876099 T:1963474944 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:32:10 148.876190 T:1963474944 NOTICE: Default DVD Player: dvdplayer
21:32:10 148.876251 T:1963474944 NOTICE: Default Video Player: dvdplayer
21:32:10 148.876312 T:1963474944 NOTICE: Default Audio Player: paplayer
21:32:10 148.876389 T:1963474944 NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:32:10 148.876450 T:1963474944 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
21:32:10 148.876862 T:1963474944 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
21:32:10 148.878159 T:1963474944 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:32:10 148.879669 T:1963474944 NOTICE: Loaded playercorefactory configuration
21:32:10 148.880157 T:1963474944 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:32:10 148.880447 T:1963474944 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:32:10 148.941437 T:1963474944 NOTICE: Running database version Addons20
21:32:10 149.063538 T:1963474944 NOTICE: ADDONS: Using repository repository.xbmc.org
21:32:10 149.063705 T:1963474944 NOTICE: ADDONS: Using repository repository.openelec.tv
21:32:10 149.063782 T:1963474944 NOTICE: ADDONS: Using repository superrepo.kodi.jarvis.all
21:32:10 149.147400 T:1963474944 NOTICE: Raspberry PI firmware version: Mar 24 2016 12:49:34
Copyright (c) 2012 Broadcom
version e16cd015026a8bda22bb50dc30b30ce07f52a202 (clean) (release)
21:32:10 149.147568 T:1963474944 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
21:32:10 149.147690 T:1963474944 NOTICE: cacheMemBufferSize: 20MB
21:32:10 149.148148 T:1963474944 NOTICE: Config:
arm_freq=900
audio_pwm_mode=1
audio_sdm_mod_order=2
config_hdmi_boost=5
disable_commandline_tags=2
disable_l2cache=1
enable_uart=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c0
lcd_framerate=60
over_voltage_avs=0x1b774
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
21:32:10 149.148361 T:1963474944 NOTICE: Config:
device_tree=-
21:32:10 149.148483 T:1963474944 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
21:32:10 149.151093 T:1963474944 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
21:32:10 149.151230 T:1963474944 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
21:32:10 149.151306 T:1963474944 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
21:32:10 149.151382 T:1963474944 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
21:32:10 149.151459 T:1963474944 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
21:32:10 149.151520 T:1963474944 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
21:32:10 149.151596 T:1963474944 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
21:32:10 149.151657 T:1963474944 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
21:32:10 149.151733 T:1963474944 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
21:32:10 149.151810 T:1963474944 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
21:32:10 149.151886 T:1963474944 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
21:32:10 149.151947 T:1963474944 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
21:32:10 149.152023 T:1963474944 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
21:32:10 149.152084 T:1963474944 NOTICE: Found ([email protected]) at 26, setting to RES_DESKTOP at 16
21:32:10 149.152176 T:1963474944 NOTICE: Checking resolution 16
21:32:10 149.274063 T:1963474944 NOTICE: GL_VENDOR = Broadcom
21:32:10 149.274216 T:1963474944 NOTICE: GL_RENDERER = VideoCore IV HW
21:32:10 149.274292 T:1963474944 NOTICE: GL_VERSION = OpenGL ES 2.0
21:32:10 149.274353 T:1963474944 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
21:32:10 149.274445 T:1963474944 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
21:32:12 150.367630 T:1963474944 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
21:32:12 150.608673 T:1963474944 NOTICE: Running database version Addons20
21:32:12 150.611923 T:1963474944 NOTICE: Running database version ViewModes6
21:32:12 150.615570 T:1963474944 NOTICE: Running database version Textures13
21:32:12 150.625076 T:1963474944 NOTICE: Running database version MyMusic56
21:32:12 150.643158 T:1963474944 NOTICE: Running database version MyVideos99
21:32:12 150.648575 T:1963474944 NOTICE: Running database version TV29
21:32:12 150.651688 T:1963474944 NOTICE: Running database version Epg11
21:32:12 150.654755 T:1963474944 NOTICE: start dvd mediatype detection
21:32:14 152.794006 T:1963474944 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
21:32:14 152.981888 T:1963474944 ERROR: ExecuteAsync - Not executing non-existing script script.skin.info.service
21:32:14 152.984604 T:1963474944 NOTICE: ActiveAE DSP - starting
21:32:14 153.008835 T:1963474944 NOTICE: initialize done
21:32:14 153.009064 T:1963474944 NOTICE: Running the application...
21:32:14 153.051636 T:1963474944 NOTICE: starting zeroconf publishing
21:32:14 153.052933 T:1963474944 NOTICE: WebServer: Started the webserver
21:32:14 153.053162 T:1963474944 NOTICE: starting upnp client
21:32:14 153.078156 T:1613878176 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:32:14 153.078445 T:1613878176 NOTICE: UDP: Listening on port 9777
I can confirm this only happens with Bello enabled as the skin, nothing else triggers it. I appreciate Pi compatibility may not be the biggest priority but I hope you can find a resolution, thanks again
You have all the required services installed? The only error i see is script.skin.info.service.
Can you tell me which base you uses for updating. Is it Bello, or BelloFredo, or another Base ?
It's the original Bello created by Nessus.
@ butchabay
Thank you for the work
I love the Skin and finally i can use them with Jarvis.
Only bug i found so far : Preference in the Menu donĀ“t work .
Will you add some Stuff from Bello Nero or Bello Fredo ?
(2016-04-12, 19:28)butchabay Wrote: [ -> ]You have all the required services installed? The only error i see is script.skin.info.service.
I believe so, it takes about ten minutes to install many services after selecting the skin but still fails to boot once it's either been powered off or rebooted. I have no idea why it says the script doesn't exist, I've tried it on several fresh installs and re-downloaded the skin a number of times but had no joy so far.
Waiting for krypton verison
Cool Skin
I like the animation and you have some cool views not seen in others.
I wish there was more customization for the main menu though.
Can anybody confirm, that certain keyboard button do not work? English QUERTY, buttons right to letter M.
Or is it just me?
Tried to install in SPMC Jarvis after work today, but it wouldn't complete, it scrolled a msg about a version of a script but couldn't see enough of it to make sense of it. bummer.
