Full Version: Generating video output circular or trapezium geometric format image
We need to write the code inserting opengles calls in kodi code to support textures generated with opengles than we can generate any kind of video output circular image or trapezium or other geometric format image in kodi.
See this example: https://github.com/raspberrypi/userland/...t/video.c7. You can use a blender model instead of a cube. This uses egl_render to overlay video on a texture.
Some info here too: https://www.raspberrypi.org/documentatio...teapot.md4
I want to use the same solution above that uses egl_render to overlay video on a texture but with kodi.
I am searching for people that have the capacity and want to help to write this code.
This feature will support special effects using digital projectors including keystone geometric correction
