Full Version: Scraping inconsistency scrap.exe/xbmc?
Pages: 1 2
then Grab the plot extraction from my scraper (check the SVN)
it works fine.
(remember that with some movies it's called synopsis, and others introduction, hence the double expressions)
The plot issue had something to do with the build, as a later build worked fine with the same scraper.
Glad you corrected the open issues in my scraper, the actors and cast were working already though? Anyway, if the scaper in SVN is working all is well...
Pages: 1 2
