There's some issues with my database it seems, some of my tables are blank. Does anybody have one they'd be willing to export? Or at least the schema? I think I can solve a lot of my problems if I manually fix the DB. I've tried recreating it several times, even on a different server.
If you delete the db, it will be recreated by Kodi on startup
Still has the same issue, I've tried that a dozen times, on 3 versions of MySQL on 2 different servers (5.1, 5.5, 5.6)
I guess the previous version is corrupted, then.
A
debug log (wiki) without Videos99 DB (thus of the upgrade) will tell
Well then ya, it created a blank DB. Did you add any content into the library?
EDIT: Maybe a better question is what is the issue from a Kodi perspective, not from looking inside the DB
