hello there
i am trying something that looks impossible
is it possible to put a block 4 : playing video in the home screen so that the trailer (tv tunes) is playing while a serie/movie is selected in the widget
it is working fine in the libary but cant get it to work on the home screen ...
(2016-04-11, 22:11)marcoooo Wrote: [ -> ]hello there
I don't think it's possible. AFAIK, from the TVTunes script side it uses the video library to trigger the video preview. However, in home, lists are built from playlists or nodes. Meaning some infos may not be available depending the chosen widget content. A widget using a full Library vfs path "should" work however but maybe not what you're looking for. You can still check if there is more available option in the script settings but I really doubt,
If i know were the controle are located for the small video preview window i could try to add this option to it
TVTUNES-Show when tv tunes plays video
This option is only there when maKing video viewtypes
In bloc 4
(2016-04-12, 17:18)marcoooo Wrote: [ -> ]If i know were the controle are located for the small video preview window i could try to add this option to it
In bloc 4
Well, the problem is not from the designer option but from the content that launches TvTunes video. As I explained above, video lists in Home are not the same as in Libraries. I checked it myself by modding the option availability in designer, browsed the widget medias but TvTunes just doesn't launch. So enabling the option in Designer is useless since it won't produce anything. TvTunes is definitely intended to be used in libraries level only.
