2016-04-12, 18:42
Well after much searching I find the solution.
After creating Movistar list pastebin channels and check that windows works perfectly on Android I'm not able to make it work.
Not if the problem is that android does not support channels type rtp : // .... because if I put a channel http : // if played.
Someone help me?
Thank you
Someone help me?
Thank you
