2016-04-16, 19:33
2016-04-17, 17:25
Hi
the multi user log in screen is black for me
https://www.dropbox.com/s/sd7k8oc81jpci9...2.png?dl=0
cheers
cheers
2016-04-18, 08:59
2016-04-18, 15:24
^^^^^ Need
2016-04-19, 19:06
I plan on changing alot of things. What is holding me back right now is I don't have a ATV4 to do research.
The more you guys post suggestions, the more it helps me as I have had minimal time with the ATV4 so far. I don't think the skin will ever be an exact clone of ATV4 but in the end it should be fairly similar.
FYI everyone, I am taking notes of all the bugs and they will be fixed in next update. Next update should be ready in roughly a week.
2016-04-19, 21:55
If you have access to OSX there is a UI kit for Sketch with full, layered 1080p designs for all the menus.
http://www.developertown.com/apple-tvos-...-template/
I'm not asking for it to be perfect, I am grateful for any skin you create, just thought it might help
2016-04-19, 22:20
(2016-04-19, 21:55)TheLegendOfMart Wrote: [ -> ]If you have access to OSX there is a UI kit for Sketch with full, layered 1080p designs for all the menus.
Unfortunately I only have a PC, hmm maybe I could use Virtual Box.
2016-04-19, 22:34
2016-04-20, 01:16
Hey Guys i made some icons for personal use and thought they would be useful to some of you
https://www.dropbox.com/s/y4eap121utzo10...e.zip?dl=0
2016-04-20, 05:35
(2016-04-19, 22:34)TheLegendOfMart Wrote: [ -> ]Converted it to PDF for you: https://www.dropbox.com/s/0xc3z8avto4ink...s.pdf?dl=0
Hope it helps.
Awesome Thanks! Now I just need the tvOS navigation sounds.
(2016-04-20, 01:16)jvelez523 Wrote: [ -> ]Hey Guys i made some icons for personal use and thought they would be useful to some of you
Nice. I'll add these to the extra icons.
2016-04-20, 06:03
(2016-04-20, 05:35)iCanuck Wrote: [ -> ](2016-04-19, 22:34)TheLegendOfMart Wrote: [ -> ]Converted it to PDF for you: https://www.dropbox.com/s/0xc3z8avto4ink...s.pdf?dl=0
Hope it helps.
Cool. I also have alternate versions of some icons with images and text instead of just text. If requested i can upload those too and make other icons if necessary. Other than that will you be integrating other views any time soon? Great work on the skin, Thanks!
2016-04-20, 13:58
Thanks for your efforts!
Here's my feedback and suggestions so far:
Original ATV4 UI Home:
Full res images
Full res images
2016-04-21, 05:31
(2016-04-20, 06:03)jvelez523 Wrote: [ -> ]Cool. I also have alternate versions of some icons with images and text instead of just text. If requested i can upload those too and make other icons if necessary. Other than that will you be integrating other views any time soon? Great work on the skin, Thanks!
Yes please send them over!
(2016-04-20, 13:58)bigbadrabbit Wrote: [ -> ]Thanks for your efforts!
Are you on Krypton? I see some bugs I have fixed already, if your on Krypton tvOS-X isn't updated yet.
I'm aware of this alignment issues in the pictures.
The way it was designed was when unfocused the shelf label is lower than the time & when focused the shelf label zooms and aligns with time label. It does need to be moved right a bit though.
Would everyone prefer that the shelf label is aligned with the time and the first cover without zooming when focused?
In tvOS I find the shelf label size is wayyy too big, what do other people think?
Yes I was going to change the Homescreen label colors to look similar to tvOS.
Yes I need to do a lot of things to the views still.
2016-04-21, 10:23
No, i'm on Jarvis RC2. But i think somehow it's the Krypton version i'm using here...
I wasn't and still am able to get tvOS-X show up in your repo under Jarvis. So i've upgraded to Krypton and it showed up. I installed the Krypton version and wen't back to Jarvis.
I even did a fresh install of Kodi Jarvis but then your repo was empty again. Only on Krypton tvOS-X was available.
2016-04-22, 02:09
it looks like the unfocused text lines up with the coverart and the focused text is in the same animation at the coverart and moves to the right. heres an image
screenshots are possible too
http://www.macworld.com/article/3005461/...le-tv.html
