(2016-07-21, 18:05)cojms1 Wrote: [ -> ] (2016-07-21, 14:42)popcornmix Wrote: [ -> ]Do you get the issue with recordings? If so a sample file would be useful.
Just rolled forward to #0720 again and recorded something (whilst knowing the issue was in Live TV). The recording doesn't seem to exhibit the problem. Not sure if that helps you at all though.
Moved up to #0724. Same issue persists with Live TV only. The video seems not to judder anywhere near as much but without the Sync playback to display option enabled the audio is completely out of sync.
Is another debug log required for this new version?
Thanks in advance.
(2016-07-25, 20:40)cojms1 Wrote: [ -> ] (2016-07-21, 18:05)cojms1 Wrote: [ -> ] (2016-07-21, 14:42)popcornmix Wrote: [ -> ]Do you get the issue with recordings? If so a sample file would be useful.
Thanks in advance.
+1
Can confirm that audio and video is way out of sync in #0724 had to revert to #0723 as nothing I did would fix the problem.
Seems to be when changing from and SD channel (in sync) to HD, the HD channel would be way out of sync, I turned on 'sync to display' but still get the audio out of sync.
This could be due to a number of changes in #0724 I can see there have been a number of AE updated and video deinterlace and clocking commits.
As I said, had to revert back to #0723
Cheers,
Loggio
Hi!
getting blackscreens when switching to some pvr channels with #0724 + argus tv. debug log
http://paste.ee/r/BvSqM
starting up to a working pvr channel >> first channel switch >> black screen >> waiting >> skipping some seconds on stream >> working.
last working build for me is #0625.
Greetings
Live TV seems ok (no crashes) with #0725.
New LibreELEC.tv Krypton build #0725:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.0 #1 Mon Jul 25 21:08:17 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jul 22 2016 20:29:36
Copyright (c) 2012 Broadcom
version 4b80f6dd44e815b5038c0c39802ebfb5db2ed36c (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160725210638-#0725-g6a1e71a [Build #0725]
# vcdbg log msg 2>&1 | grep DTOK
002392.339: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (6a1e71a4,
changelog) and tip of
XBMC master (2b8e2041,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
- Includes latest bcm2835-driver master (b8ef00fa)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (51271e1a, +23), inputstream.rtmp (7bf2298e), inputstream.smoothstream (99e77711, +4), peripheral.joystick (6090a90e, +1), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (20e1ccb4, +2), pvr.dvbviewer (7a7ead36, +1), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (66dcb89f, +2), pvr.iptvsimple (21e91a5f, +1), pvr.mediaportal.tvserver (72452b9d, +2), pvr.mythtv (d10d210b, +8), pvr.nextpvr (32b3c2ff, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (b6cb9b87, +9), pvr.vbox (f38f82f0, +2), pvr.vdr.vnsi (8515b4bf, +6), pvr.vuplus (4f2ad621, +2), pvr.wmc (979c37db, +2)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: Install libbrcmEGL/libbrcmGLESv2 shared libraries, with sym links for backward compatability
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: ffmpeg: bump 3.1.1
- Include [env] PR:481: linux: Update to 4.7 (WIP)
- Include [env] PR:526: Cpu temperature readings for devices with aml_thermal interface
- Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: #TMP: Fix deinterlace SQL statement
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:171: fix seeklabel (kodi-theme-Estuary)
- Include [pkg] PR:172: add player process and pvr signal info (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:10141: set tvshow thumb on *all seasons node
- Include [pkg] PR:10157: [WIP] Double the backslash in mysql in case we're in 'LIKE'
- Include [pkg] PR:10166: Readd Player process info and PVR info dialog
Build Highlights:
- New 4.7.0 kernel
- Drop AE: add atempo filter - should stop crashes
- Drop freetype bump from PR:555
Build Details:
- LibreELEC.tv:
- Sapphire Remote driver addon (PR:561, 2 commits, 8 files changed)
- Package updates (PR:555, 18 commits, 21 files changed)
- mysql: update to 5.7.13
- ccache: update to 3.2.7
- gettext: update to 0.19.8.1
- gmp: update to 6.1.1
- pcre: update to 8.39
- swig: update to 3.0.10
- libpng: update to 1.6.23
- llvm: update to 3.8.1
- bluez: update to 5.41
- xorg-server: update to 1.18.4
- busybox: update to 1.25.0
- fuse: update to 2.9.7
- libevdev: update to 1.5.2
- procps-ng: update to 3.3.12
- libinput: update to 1.4.0
- fontconfig: update to 2.12.0
- libgpg-error: update to 1.24
- libdrm: update to 2.4.70
- XBMC:
- AESinkPULSE: Disable remixing if no server downmix is needed (PR:10151, 3 commits, 1 file changed)
- [iOS] Add "Copy to Kodi" functionality (PR:9781, 1 commit, 7 files changed)
- [depends] Install config-binaddons.site and Toolchain_binaddons.cmake (PR:10163, 1 commit, 1 file changed)
- pvr.mythtv:
- 4.7.0 (PR:72, 2 commits, 9 files changed)
- newclock5:
- Commits no longer in build:
- kernel 4.7.y:
- New commits in this build:
- iqaudio-dac: Compile fix - untested (3a4a43e6)
- Added support for headphones, microphone and bclk_ratio settings. (451b8ef3)
- BCM270X_DT: Add mcp23017 to the overlay Makefile (68edfbff)
- BCM270X_DT: Sort entries to placate check script (2010ee57)
- BCM270X_DT: Add spi-rtc overlay on SPI0.0 (0164a0b4)
- Add critical information for getting pi3-miniuart-bt overlay to work (de0bc972)
- enable led support for xpad driver - fixes flashing leds on controller (76708b44)
- bcm2835-sdhost: Improvements to error recovery (f93aac31)
- dts: Add overlay for NXP SC16IS752 Dual UART with SPI Interface (415849ef)
- BCM270X_DT: Overlay to re-enable HW CS on SPI0 (b96a1194)
- BCM270X_DT: Declare the audio PWM pins explicitly (aac501e3)
- BCM270X_DT: Restore lost closing brace. (bf258c13)
- config: Add driver for mcp23017 I2C GPIO expander (8fd2f707)
Potentially silly question about the new PlayerProcessInfo dialog.... It appears to replace the old playback info dialog. Are there any plans for it to also show any drops/skips as that seems to be missing?
New LibreELEC.tv Krypton build #0726:
RPi /
RPi2
# uname -a
Linux rpi512 4.7.0 #1 Tue Jul 26 21:07:10 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160726210513-#0726-gab8e333 [Build #0726]
002391.192: Kernel trailer DTOK property says yes
Based on tip of
LibreELEC.tv master (ab8e333e,
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- webgrabplus: initial addon (PR:545, 1 commit, 6 files changed)
- moonlight-embedded: disable gold linker for imx6 project (PR:569, 1 commit, 1 file changed)
- zlib : Add libMinizip build to package (PR:563, 1 commit, 1 file changed)
- newclock5:
- rbp: Ensure processinfo values are initialised (9b3d3050)
0726 is very unstable. I'm getting a weird Tvheadend behavior. I think this is started in 0724.
http://sprunge.us/LMcX (errors start at 04:36:31)
http://sprunge.us/KBJa (stream stalled at 05:52:50)
(2016-07-24, 18:12)smp1 Wrote: [ -> ]I noticed a rare but very annoying bug. This usually happens when watching a HD DVB-S channel for a prolonged period of time (12+ hours).
I tested with Jarvis (LE 7.0.2) and got the same issue there. Kodi always crash when it tuned to a HDTV channel for a long period of time (10-15 hours). There is no crashlog, Kodi just froze, I had to reboot it via ssh.
(2016-07-27, 03:54)smp1 Wrote: [ -> ]0726 is very unstable. I'm getting a weird Tvheadend behavior. I think this is started in 0724.
Are you using the latest
tvheadend42? Doesn't tvheadend have it's own log? Perhaps there are errors being logged there...
(2016-07-25, 21:52)Screech Wrote: [ -> ]Hi!
getting blackscreens when switching to some pvr channels with #0724 + argus tv. debug log http://paste.ee/r/BvSqM
Greetings
+1 with ArgusTv, but only on 1920x1080 content SD live plays fine. To get 1080i HD to play need to skip back a few seconds then ok. same on #0725
(2016-07-27, 07:05)Milhouse Wrote: [ -> ]Are you using the latest tvheadend42? Doesn't tvheadend have it's own log? Perhaps there are errors being logged there...
Yes, I use Tvheadend 4.2. Nothing unusual in Tvheadend's log. Didn't try the debug log yet.
Hi guys,
please don't shoot me, cause i have just a little issue about modification of the confluence skin.
What i'm asking you is how to modify the video player to show up no boxes , Info's etc when i press pause on my remote.
I need only the still video image without any UI while in Pause mode.
So is there a quick and no rocket science solution for me to customize the skin or player to do that ?
Thanks a lot for your support and Millhouse and Popcornmix ...you guys rock
Peter
The most likely change in 0724 is "mmalrender: Disable deinterlace when no interlaced frames seen",
but I don't believe that could cause tvheadend errors in log.
But, I'll revert it for tonight's build (it will re-introduce the stuttering when switching channels from 1080i->720p) just to confirm if it is causing an issue.
(2016-07-27, 20:30)Kowdi4Ever Wrote: [ -> ]Hi guys,
Peter
You should ask in the
Confluence forum, as this question is OT for this thread (these builds no longer even ship Confluence as standard). The answer will most likely involve editing one or more skin files. You could also try using a modified version of Confluence in case they support what you are after.
