(2016-07-27, 20:55)popcornmix Wrote: [ -> ]The most likely change in 0724 is "mmalrender: Disable deinterlace when no interlaced frames seen",
but I don't believe that could cause tvheadend errors in log.
The Tvheadend errors seem to occur more often when Kodi is idle (when in GUI and just doing nothing).
New LibreELEC.tv Krypton build #0727:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.0 #1 Wed Jul 27 21:07:29 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jul 22 2016 20:29:36
Copyright (c) 2012 Broadcom
version 4b80f6dd44e815b5038c0c39802ebfb5db2ed36c (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160727210551-#0727-g2cb8274 [Build #0727]
# vcdbg log msg 2>&1 | grep DTOK
002392.146: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (2cb82748,
changelog) and tip of
XBMC master (434764cb,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
- Includes latest bcm2835-driver master (b8ef00fa)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (51271e1a, +23), inputstream.rtmp (7bf2298e), inputstream.smoothstream (99e77711, +4), peripheral.joystick (6090a90e, +1), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (20e1ccb4, +2), pvr.dvbviewer (7a7ead36, +1), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (66dcb89f, +2), pvr.iptvsimple (21e91a5f, +1), pvr.mediaportal.tvserver (72452b9d, +2), pvr.mythtv (d10d210b, +8), pvr.nextpvr (32b3c2ff, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (b6cb9b87, +9), pvr.vbox (f38f82f0, +2), pvr.vdr.vnsi (8515b4bf, +6), pvr.vuplus (4f2ad621, +2), pvr.wmc (979c37db, +2)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: Install libbrcmEGL/libbrcmGLESv2 shared libraries, with sym links for backward compatability
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: ffmpeg: bump 3.1.1
- Include [env] PR:481: linux: Update to 4.7 (WIP)
- Include [env] PR:526: Cpu temperature readings for devices with aml_thermal interface
- Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: #TMP: Fix deinterlace SQL statement
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:171: fix seeklabel (kodi-theme-Estuary)
- Include [pkg] PR:172: add player process and pvr signal info (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:10141: set tvshow thumb on *all seasons node
- Include [pkg] PR:10157: [WIP] Double the backslash in mysql in case we're in 'LIKE'
- Include [pkg] PR:10166: Readd Player process info and PVR info dialog
Build Highlights:
- [PVR] Fix recordings resume playback context menu handling - fixes trac#16723
- Drop mmalrender commit to see if it fixes tvheadend issue
Build Details:
- LibreELEC.tv:
- Mono does not build for arm64 (PR:570, 3 commits, 3 files changed)
- lirc: add Atric IR-Wakeup-USB support (PR:572, 1 commit, 1 file changed)
- XBMC:
- [PVR] Fix recordings resume playback context menu handling - fixes trac#16723 (PR:10173, 1 commit, 2 files changed)
- [depends][win32][fix] new shairplay.dll that actually exports methods (PR:10174, 1 commit, 2 files changed)
- newclock5:
- New commits in this build:
- Revert "mmalrender: Disable deinterlace when no interlaced frames seen" (ce09b960)
(2016-07-27, 07:05)Milhouse Wrote: [ -> ] (2016-07-27, 03:54)smp1 Wrote: [ -> ]0726 is very unstable. I'm getting a weird Tvheadend behavior. I think this is started in 0724.
Are you using the latest tvheadend42? Doesn't tvheadend have it's own log? Perhaps there are errors being logged there...
Ok, here's what I get in Tvheadend log when the error occur (build #0726):
2016-07-28 02:41:22.320 htsp: 127.0.0.1 [ | Kodi Media Center ]: Disconnected
2016-07-28 02:41:22.322 htsp: Got connection from 127.0.0.1
2016-07-28 02:41:22.322 htsp: 127.0.0.1: Welcomed client software: Kodi Media Center (HTSPv25)
2016-07-28 02:41:22.322 htsp: 127.0.0.1 [ Kodi Media Center ]: Write error -- Broken pipe
2016-07-28 02:41:22.322 htsp: 127.0.0.1 [ Kodi Media Center ]: Disconnected
2016-07-28 02:41:22.327 htsp: 127.0.0.1 [ Kodi Media Center ]: Identified as user ''
Well, no errors so far with #0727.
You can enable debug logging in tvheadend may give you more info
Hello all,
Sorry if this question is not really at the good place, but it's directly linked to the LibreELEC testbuild I use.
Do you know any database manager I could use to... manage the kodi database (I mean select the good one when the scrapper is wrong...) on my MacOS, while the database is the one from the build #630 ? (if necessary, I could update the test build ^^). But for what I know, the "kodi" version I can find on my Mac is not compatible with the database format (shared on a MySQL server).
Thank you for your help
(2016-07-28, 22:50)Sinisan Wrote: [ -> ]Hello all,
Your question has nothing to do with these builds - media managers don't really don't care about the database you are using as they create NFO files which should be readable by all versions of Kodi (to varying degrees).
If you want advice on a media manager, ask in the
Supplementary Tools for Kodi forum. The
TinyMediaManager supports Mac.
New LibreELEC.tv Krypton build #0728:
RPi /
RPi2
# uname -a
Linux rpi512 4.7.0 #1 Thu Jul 28 21:08:00 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jul 28 2016 12:46:32
version e12916091ba9d68ef2780e4e142ade56aa301754 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160728210617-#0728-g9cd9b9e [Build #0728]
002390.890: Kernel trailer DTOK property says yes
Based on tip of
LibreELEC.tv master (9cd9b9e8,
XBMC master (84d55c1f,
- Includes latest bcm2835-driver master (1205048f, ahead +1)
- Include [env] PR:573: kodi/Intel: Various improvements from fritsch
Build Highlights:
- New firmware
Build Details:
- Firmware (Jul 28):
- firmware: platform: Default to 16bit framebuffer with cutdown firmware
- firmware: armstub: Move redundant write to mailbox register. See: link
- firmware: vc_client: Fix for sending vguPolygon data in chunks. See: link
- LibreELEC.tv:
- Fix NAND auto installs on WeTek devices (PR:575, 1 commit, 1 file changed)
- XBMC:
- [cmake/linux] Require at least PulseAudio 2.0 (PR:10176, 1 commit, 1 file changed)
- [cmake] Improve generated Visual Studio and Xcode projects (PR:10158, 9 commits, 44 files changed)
- [SpecialProtocol] Fix crash caused by envhome on Windows (PR:10175, 1 commit, 1 file changed)
- set tvshow thumb on *all seasons node (PR:10141, 1 commit, 1 file changed)
- [PVR][json-rpc] Fix PVR.AddTimer for timer rules. (PR:10178, 1 commit, 1 file changed)
- kernel 4.7.y:
- config: Enable CONFIG_USER_NS (084b55c7)
- bcm2708_fb: Default framebuffer to 32-bit (a5e30abb)
- Added: [env] PR:573: kodi/Intel: Various improvements from fritsch
I'm getting the following with latest build and usb dvb-t tune fails
[ 112.647759] mceusb 1-1.5.1:1.0: Error: urb status = -71
[ 112.648758] mceusb 1-1.5.1:1.0: Error: urb status = -71
[ 112.649758] mceusb 1-1.5.1:1.0: Error: urb status = -71
[ 112.650066] usb 1-1.5: USB disconnect, device number 4
[ 112.650082] usb 1-1.5.1: USB disconnect, device number 8
[ 112.735611] usb 1-1.5.4: USB disconnect, device number 7
[ 112.789366] usb 1-1.5.4: dvb_usb_v2: usb_bulk_msg() failed=-19
[ 112.789413] usb 1-1.5.4: dvb_usb_v2: usb_bulk_msg() failed=-19
[ 112.789430] af9033 3-0038: i2c wr failed=-19 reg=80004c len=1
(2016-07-29, 05:44)gendo Wrote: [ -> ]I'm getting the following with latest build and usb dvb-t tune fails
You only have this problem with #0728? Everything is OK with #0727?
will check and revert as previous build i was using was #0722
#0727 seems fine..
New LibreELEC.tv Krypton build #0729:
RPi /
RPi2
# uname -a
Linux rpi512 4.7.0 #1 Fri Jul 29 21:20:12 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160729211831-#0729-g82d8199 [Build #0729]
002391.646: Kernel trailer DTOK property says yes
Based on tip of
LibreELEC.tv master (82d8199e,
XBMC master (1abe5194,
- Include [env] patch: kodi: Revert cache clearing - replaced by PR9225
Build Highlights:
- Revert season-all thumb change
- AE: add ffmpeg atempo filter (newclock5)
Build Details:
- LibreELEC.tv:
- docker: update to 1.12.0 (PR:557, 4 commits, 8 files changed)
- XBMC:
- Revert "set tvshow thumb on *all seasons node" (PR:10181, 1 commit, 1 file changed)
- More long-press enhancements (PR:10171, 1 commit, 2 files changed)
- Default keymaps for WeTek USB remotes (PR:10169, 1 commit, 2 files changed)
- Added assignment for Android keys L1 and R1 (PR:10125, 1 commit, 1 file changed)
- Handle Remote Typing via web interface (PR:10102, 2 commits, 1 file changed)
- [PeripheralCecAdapter] fix playback stopping on screensaver deactivated (PR:9803, 1 commit, 1 file changed)
- newclock5:
- AE: change usage of swr_set_compensation (fdbbe340)
- AE: refactor resample buffers (9847f84f)
- AE: add ffmpeg atempo filter (8a86319f)
- VideoPlayer: improve rr related to clockspeed (ac7413ca)
- squash atempo (afdaf706)
- fixup! [ae] Add debug logging showing resamplerate (7c60f60d)
- Added: [env] patch: kodi: Revert cache clearing - replaced by PR9225
There might be remote control issues in tonight's build, I'm investigating. Please post if your remote is working differently from build #0728.
You've just pre-empted the post I was typing, Milhouse
With a gpio/lirc remote, the OK button isn't working. All other buttons appear to be fine from a quick test, and say if you need any other info.
Edit: Back button appears to be only partially working - it will take the system back in the window hierarchy, but won't close the video information dialog.
(2016-07-28, 23:28)Milhouse Wrote: [ -> ] (2016-07-28, 22:50)Sinisan Wrote: [ -> ]Hello all,
If you want advice on a media manager, ask in the Supplementary Tools for Kodi forum. The TinyMediaManager supports Mac.
Thank you for your answer. Unfortunately, what I was asking for, is a tool that works with the database, as I don't want to store thousands of .nfo. Perhaps could I find a Kodi for Mac version with uses the same database version as in the build I use ?
Thank you for your help, and for your work.
