Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-08-30, 00:43)richardk Wrote: [ -> ]
(2016-08-29, 17:50)Milhouse Wrote: [ -> ]
(2016-08-29, 17:43)richardk Wrote: [ -> ]I rebooted to start a new logfile...and now I'm unable to duplicate the problem. I'd seen it on repeated restarts of the same build, so I'm not sure what changed.
In any case, we can hold on this for now. If I see the problem again, I'll post a new (abbreviated) logfile.
Could it be a network issue? Do you need "Wait for network before starting Kodi" enabled in LibreELEC Settings?
Not surprisingly, this problem has come back. I did set the option you suggested, but it didn't help. (I'm using a wired Ethernet connection, so I wouldn't expect much of a delay in the network connection process.)
Here is the logfile -- hopefully one that will be useful this time. But let me know if I can do anything else to help debug this.
http://pastebin.com/HnRLcW73
This isn't even a debug log, please submit a debug log.
I updated to my rpi2 to #0828 and see jerky video playback / dropped frames on recordings from one local station (SF Bay area channel 11 720p I believe) but recorded video from local channel 5 (1080i) seems ok.
It's been awhile since I updated, so I chased this back, and it seems to have come in on the #0602 build.
#0828 log : http://sprunge.us/LQAj
#0602 log: http://sprunge.us/bVih
playback with #0601 seems to have a bit of an audio sync issue, but playback is smooth once started.
(2016-08-30, 00:43)richardk Wrote: [ -> ]Not surprisingly, this problem has come back. I did set the option you suggested, but it didn't help. (I'm using a wired Ethernet connection, so I wouldn't expect much of a delay in the network connection process.)
It's not a debug log (see note #9, first post).
I don't know what skin you're using but you've got a ton of skin related errors. Test using stock Estuary.
You're using banned addons, so get rid of those if you want help on this forum.
Your MythTV PVR Client installation is not working - maybe you've lost your configuration or it's become corrupt.
My advice would be to start with a clean .kodi without all the banned addons, re-install/reconfigure only Myth. If you still have a problem upload a debug log.
New LibreELEC.tv Krypton build #0829: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.2 #1 Mon Aug 29 21:23:18 BST 2016 armv6l GNU/Linux
# vcgencmd version
Aug 23 2016 15:58:54
Copyright (c) 2012 Broadcom
version f23e65aeeffca65654550c93254a0ee55f34fb07 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160829212143-#0829-g9a5bb06 [Build #0829]
# vcdbg log msg 2>&1 | grep DTOK
002391.975: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (9a5bb062, changelog) and tip of XBMC master (c1fa41a5, changelog) with the following modifications: Build Highlights:
  1. Minors
Build Details:
  1. LibreELEC.tv:
    • logfiles: Add CPU governor details to 03_Hardware.log (PR:675, 1 commit, 1 file changed)
    • mkimage: add fogotten distroconfig.txt after #389 (PR:674, 2 commits, 2 files changed)
    • rtl8812au: fix AP timeout value patch (PR:672, 1 commit, 1 file changed)
    • kodi: update to 17.0-beta1-81d5d26 (PR:641, 11 commits, 40 files changed)
  2. XBMC:
    • [Estuary][PVR] Recordings Info dialog: Fix 'Play recording' button. (PR:10358, 1 commit, 4 files changed)
  3. pvr.mediaportal.tvserver:
    • Internal RTSP streaming & IPv6 backend connect support (PR:46, 7 commits, 109 files changed)
(2016-08-30, 02:54)mikeb8591 Wrote: [ -> ]I updated to my rpi2 to #0828 and see jerky video playback / dropped frames on recordings from one local station (SF Bay area channel 11 720p I believe) but recorded video from local channel 5 (1080i) seems ok.
#602 did introduce a bug:
firmware: image_fx: Need to preserve flags for generated frames.
which was fixed in #613
firmware: image_fx: Mask off unwanted flags from generated frames
So I'd be interested if the problem is present in #613?
Most interesting would be #602 with firmware (start.elf/fixup.dat) copied from #613.
(2016-08-29, 23:46)Aux_ Wrote: [ -> ]Since few last builds my RPi3 kompletly freezes and no create Crashlog. I had Rpi power supply always from the socket Take out because reset (have reset button) had not helped.
Identifying the exact build that introduced the problem would be useful. Backtrace shows it doing something demux related when opening stream to get file info:
Thread 1 (Thread 0x74e66000 (LWP 623)):
#0  0x75260998 in std::_Rb_tree_increment(std::_Rb_tree_node_base const*) () from /usr/lib/libstdc++.so.6
#1  0x004cf158 in CDVDDemuxClient::GetStreams() const ()
#2  0x004b8600 in CDVDFileInfo::DemuxerToStreamDetails(CDVDInputStream*, CDVDDemux*, CStreamDetails&, std::string const&) ()
#3  0x004b8b94 in CDVDFileInfo::DemuxerToStreamDetails(CDVDInputStream*, CDVDDemux*, std::vector<CStreamDetailSubtitle, std::allocator<CStreamDetailSubtitle> > const&, CStreamDetails&) ()
#4  0x009525c8 in CVideoPlayer::GetStreamDetails(CStreamDetails&) ()
#5  0x007b27b0 in CApplicationPlayer::GetStreamDetails(CStreamDetails&) ()
#6  0x007ab4ac in CApplication::UpdateFileState() ()
#7  0x007b0b4c in CApplication::ProcessSlow() ()
#8  0x007b0e10 in CApplication::Process() ()
#9  0x00806498 in CXBApplicationEx::Run() ()
#10 0x0068362c in XBMC_Run ()
#11 0x003648d4 in main ()
But nothing has changed in DVDDemuxClient.cpp recently.
(2016-08-30, 13:14)popcornmix Wrote: [ -> ]
Thanks for the reply @popcornmix
The behavior is very difficult to track, This error occurs rarely and spontaneously, to find that I will need days or weeks.
I had used another SD card some time ago, maybe's that? Must old SD card back and try back.
(2016-08-30, 02:01)smp1 Wrote: [ -> ]
(2016-08-28, 10:11)polo_joe Wrote: [ -> ]I can't watch livetv or playback recording of the channel TecTime Tv.
Add this to ~/.kodi/userdata/advancedsettings.xml:
<advancedsettings>
    <omx>
        <omxdecodestartwithvalidframe>0</omxdecodestartwithvalidframe>
    </omx>
</advancedsettings>
That did the trick!! Thanks much.
New LibreELEC.tv Krypton build #0830: RPi / RPi2
# uname -a
Linux rpi512 4.7.2 #1 Tue Aug 30 21:06:26 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160830210444-#0830-g6c34b94 [Build #0830]
002390.540: Kernel trailer DTOK property says yes
Based on tip of LibreELEC.tv master (6c34b945, changelog) and tip of XBMC master (28d9f9fc, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
  • Includes latest bcm2835-driver master (d0bc6ce8)
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (62b8520c, ahead +15)
  • Includes latest libnfs master (fac3a954, ahead +34)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (20c47221, +2), inputstream.rtmp (9c05b8dd), inputstream.smoothstream (b63ecbb4), peripheral.joystick (73623136, +27), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (3c39bd0c, +7), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (bb9c0b10, +10), pvr.vbox (2750c92a), pvr.vdr.vnsi (40c45dc9), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Exclude [env] kodi-999.99-PR10309.patch: merged upstream
  • Exclude [env] libcec-PR208.patch: Merged upstream
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: ffmpeg: Bump to 3.1.3-Krypton-Beta3 (e9002c3)
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
  • Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
  • Include [pkg] PR:50: Update to peripheral API v1.1.0: Add function to save button maps (peripheral.joystick)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:10364: Peripheral API v1.1.0: Fix mapping D-pad on RPi for some controllers
  • Include [pkg] PR:10367: DVDAudioCodecPassthrough: Fix memory leak after 14af37aac18b0f471694ac7c65a96d39afaf327
Build Highlights:
  1. peripheral.joystick updates - any changes for those with the weird controller-related crashes?
  2. DVDAudioCodecPassthrough - should prevent OOM while seeking with passthrough, although seeking itself is not yet 100%
Build Details:
  1. LibreELEC.tv:
    • cleanup: clean build scripts to make more reproducible builds (PR:679, 1 commit, 4 files changed)
    • webgrabplus: update mdb ini files (PR:673, 1 commit, 3 files changed)
    • emby: update and rebuild ffmpegx (PR:677, 2 commits, 3 files changed)
    • busybox: enable rpm2cpio applet (PR:680, 1 commit, 1 file changed)
  2. XBMC:
    • [keymap] fix window names (PR:10360, 1 commit, 2 files changed)
    • Double the backslash in mysql in case we're in 'LIKE' (PR:10157, 1 commit, 2 files changed)
    • [contextmenu] refactor addon loading/initialization (PR:10356, 3 commits, 11 files changed)
    • Fix query that was missing the actual join condition for unique_id (PR:10362, 1 commit, 1 file changed)
    • [depends] gnutls 3.4.14 and nettle 3.2 (PR:10365, 1 commit, 5 files changed)
  3. inputstream.mpd:
  4. peripheral.joystick:
    • [udev] Refactor logic to avoid rapid motor events (5ab8d4a1)
    • [udev] Protect motor states with a mutex (73623136)
  5. kernel 4.7.y:
    • New commits in this build:
      • snd-bcm2835: Use bcm2835_hw params in preallocate (a1fe7200)
      • dwc_otg: Use kzalloc when suitable (8a6e7f5b)
  6. Additional commits/pull requests/changes not yet merged upstream:
    • Updated: [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
    • Added: [pkg] PR:50: Update to peripheral API v1.1.0: Add function to save button maps (peripheral.joystick)
    • Added: [pkg] PR:10364: Peripheral API v1.1.0: Fix mapping D-pad on RPi for some controllers
    • Added: [pkg] PR:10367: DVDAudioCodecPassthrough: Fix memory leak after 14af37aac18b0f471694ac7c65a96d39afaf327
(2016-08-30, 13:04)popcornmix Wrote: [ -> ]#602 did introduce a bug:
The behavior is still present in #828
I didn't try #613, but it was present in #825, #725, #622 and #611 as well. (I tried those working back to find where the issue started for me.)
(2016-08-30, 22:58)Milhouse Wrote: [ -> ][*]peripheral.joystick updates - any changes for those with the weird controller-related crashes?
It still crashes when the joystick is connected.
http://sprunge.us/KOhV
(2016-08-31, 04:10)smp1 Wrote: [ -> ]
Thanks. @garbear any ideas?
Hello !
I've got problems I haven't in previous version (805 I think) : I can't move (chapter jump, or fast forward) in a 3D movie. It "jumps", but only one picture is displayed and frozen, as if it was paused.
Here the log : http://sprunge.us/aKWc
Thank you for your help,
Regards,
(2016-08-31, 08:17)Sinisan Wrote: [ -> ]Hello !
Regards,
Turn off passthrough, any better?
If not, can you identify the exact build when this problem started.
Having problem with kernel panic with my Pi 2 Model B since build #0823 (works with #0822 and lower builds)
Crash seems to be related to Netgear A6100 (rtl8812au) when plugged in during boot or plugged in after successful boot.
Unplugged it works just fine.
Screenshot of kernel panic http://imgur.com/a/la4vK
