(2016-10-06, 08:55)dias0 Wrote: [ -> ] (2016-10-06, 08:17)Milhouse Wrote: [ -> ] (2016-10-06, 08:10)dias0 Wrote: [ -> ]Lirc Remote not working with build #1005.
Not working at all?
Yes not working at all.Revert to build #1004
This works fine on my RPI3 with an MCE USB IR receiver.
Sent from my iPhone
RPi 1B2 #1005 confirm lirc does not work on GPIO receiver. PVR-NEXTPVR couldn't load.
irw does not report key presses. No mention of lirc in DMESG.
#1004
Lirc works, irw report keypresses, loaded in DMesg. PVR not loaded. Doesn't seem to be a way to enable TV.
(2016-10-06, 15:03)donbrew Wrote: [ -> ]RPi 1B2 #1005 confirm lirc does not work on GPIO receiver. PVR-NEXTPVR couldn't load.
#1004
Can you post dmesg for #1004 and #1005.
Also output of lsmod for both.
dias0 what is in your config.txt file? I added:
and get:
LibreELEC:~ # uname -a
Linux LibreELEC 4.8.0 #1 SMP Thu Oct 6 03:13:52 BST 2016 armv7l GNU/Linux
LibreELEC:~ # dmesg |grep -i lirc
[ 3.251238] lirc_dev: IR Remote Control driver registered, major 243
[ 3.264337] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.209608] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 4.209761] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 4.209765] lirc_rpi: driver registered!
[ 4.381629] input: lircd as /devices/virtual/input/input0
LibreELEC:~ # lsmod |grep -i lirc
lirc_rpi 5930 3
lirc_dev 7013 1 lirc_rpi
rc_core 15390 1 lirc_dev
Not working at all?
confirmed Lirc Remote not working with build #1005.
Back to 1004
(2016-10-06, 16:32)popcornmix Wrote: [ -> ]@dias0 what is in your config.txt file?
My config.txt
gpu_mem=300
force_turbo=0
disable_overscan=1
#dtparam=sd_overclock=83
framebuffer_width=1280
framebuffer_height=720
hdmi_ignore_cec_init=0
decode_MPG2=0xe4fcbf65
decode_WVC1=0xceb36774
hdmi_pixel_encoding=2
#hdmi_pixel_encoding=4
dtoverlay=lirc-rpi
#dtoverlay=pi3-miniuart-bt-overlay
#max_usb_current=1
(2016-10-06, 16:39)laniel Wrote: [ -> ] (2016-10-06, 08:55)dias0 Wrote: [ -> ] (2016-10-06, 08:17)Milhouse Wrote: [ -> ]Not working at all?
Back to 1004
lirc_rpi still broken in #1006
EDIT: nonsense, it was still #1005 - #1006 isnt out yet, sorry...
#1005:
kodi-wz:~ # dmesg | grep lirc
kodi-wz:~
#1004:
[ 5.205260] lirc_dev: IR Remote Control driver registered, major 244
[ 5.234861] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.128186] lirc_rpi: auto-detected active low receiver on GPIO pin 18
[ 6.128677] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 6.128698] lirc_rpi: driver registered!
[ 6.666209] input: lircd as /devices/virtual/input/input2
kodi-wz:~ #
For me, dtoverlay=hifiberry-dacplus doesn't work anymore in build #1005, but it does in #1004.
Milhouse, reference my previous recent posts. NO kodi crashes after install and boot and/or wake-up from idle/sleep with CEC remote with builds #1003, #1004 & #1005
As suggested added a comment and links to a few of the recent thread posts to
PR:10544
(2016-10-06, 18:50)popcornmix Wrote: [ -> ] (2016-10-06, 18:37)makruiten Wrote: [ -> ]For me, dtoverlay=hifiberry-dacplus doesn't work anymore in build #1005, but it does in #1004.
Can you report output of
dmesg
lsmod
vcdbg log msg
for #1004 and #1005
Here they are! Small part of the output:
001857.805: dtdebug: Failed to open overlay file 'overlays/hifiberry-dacplus-overlay.dtb'
001862.180: dtdebug: Failed to open overlay file 'overlays/hifiberry-dacplus.dtb'
001862.193: Failed to load overlay 'hifiberry-dacplus'
(2016-10-06, 15:28)popcornmix Wrote: [ -> ] (2016-10-06, 15:03)donbrew Wrote: [ -> ]RPi 1B2 #1005 confirm lirc does not work on GPIO receiver. PVR-NEXTPVR couldn't load.
#1004
forget the bit about pvr-nextpvr I forgot to start it on the host.
Here are all 4
https://1drv.ms/f/s!AjzU630GFTBNjn6pz-jJlQY2NFQB
(2016-10-06, 21:17)makruiten Wrote: [ -> ] (2016-10-06, 18:50)popcornmix Wrote: [ -> ] (2016-10-06, 18:37)makruiten Wrote: [ -> ]For me, dtoverlay=hifiberry-dacplus doesn't work anymore in build #1005, but it does in #1004.
dmesg
lsmod
vcdbg log msg
for #1004 and #1005
same here, the same message in the log
