Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
What's happened to wall view in movies? I'm using #1008
(2016-10-09, 03:03)CAM STEW Wrote: [ -> ]What's happened to wall view in movies? I'm using #1008
It's PR10646 in #1007. I've added a github comment here seeking to clarify if the new look is intentional, if it is and you disagree please continue the discussion in the Estuary sub-forum.
I still have a small live tv related issue.
When i switch to a 720p channel then the audio keeps running off for the first about 20s. Then my amp shortly looses audio signal and from then on everything is good.
Debug Log
It appears only to happen when i switch the channel with the number or arrow keys. If i use the epg to switch channels everything is working fine.
This has sporadically happend since the 1080i to 720p bug was fixed, but i have never found a way to reliably reproduce this behavior, since now.
New LibreELEC.tv Krypton build #1009: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.1 #1 Sun Oct 9 21:05:49 BST 2016 armv6l GNU/Linux
# vcgencmd version
Oct  4 2016 19:03:30
Copyright (c) 2012 Broadcom
version c844c61ad08f94946910d0d5e1be076df4c8c56d (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161009210447-#1009-g5661f32 [Build #1009]
Based on tip of LibreELEC.tv master (5661f325, changelog) and tip of XBMC master (8344d702, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.8.y
  • Includes latest bcm2835-driver master (ec63df14)
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (62b8520c, ahead +15)
  • Includes latest libnfs master (2edbd147, ahead +61)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (b45f98ff, +8), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (e842db92), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (57b546a3, +2), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (dd95edef), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Exclude [env] libcec-PR208.patch: merged upstream (libcec)
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:759: linux: update to linux-4.8.1
  • Include [env] PR:792: scripts/build: use MinSizeRel cmake build type
  • Include [env] PR:796: scripts/build: cleanup
  • Include [env] PR:800: xf86-video-intel: enable dri3 and make it default
  • Include [env] PR:807: Network: smb & ntfs config mods
  • Include [env] PR:810: path: remove regex dependency when processing packages
  • Include [env] PR:812: libdrm: update to libdrm-2.4.71
  • Include [env] PR:813: scripts/build: no need to setup toolchain twice and before really building
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Revert [env] PR:793: projects/*/options: disable lcdproc for all projects except Generic/Virtual (Reverted until add-on available)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
  • Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
  • Include [pkg] PR:10572: [CryptThreading] replace hardcoded value for CRYPTO_LOCK by macro
  • Include [pkg] PR:10641: [video] fix NFO parsing of <namedseason>'s
  • Include [pkg] PR:10658: support reusing of CFile::m_pFile
  • Include [pkg] PR:10663: [guilib] make onclick override conditional. Fallback to default actio…
Build Highlights:
  1. New 4.8.1 kernel
  2. VideoPlayer sync and seek updates
  3. libnfs 1.11.0
Build Details:
  1. LibreELEC.tv:
    • tigervnc: add icon, port setting (PR:819, 1 commit, 4 files changed)
    • imx6 updates (PR:822, 4 commits, 5 files changed)
    • RTL8812AU: remove debug ouput (PR:823, 1 commit, 1 file changed)
    • revert "imx6/kodi: update advancedsettings.xml" (PR:824, 1 commit, 1 file changed)
    • RTL8812AU: fix patch file permission (PR:825, 1 commit, 1 file changed)
  2. XBMC:
    • [doxygen] update python listitem documentation (PR:10662, 1 commit, 1 file changed)
    • X11, osx: yield to main loop after input action has been handled (PR:10664, 2 commits, 2 files changed)
    • fix encrypted DVD playback fixes #16965 (PR:10667, 1 commit, 1 file changed)
    • aarch64 build support (PR:10659, 25 commits, 52 files changed)
    • VideoPlayer: fix general synchronize, often resulted in global timeout (PR:10668, 1 commit, 6 files changed)
    • [VTB/GLES] - release CVBuffer after it actually has been rendered (PR:10652, 1 commit, 4 files changed)
    • [cmake] get_filename_component(... PATH) is deprecated. Use DIRECTORY instead (PR:10660, 1 commit, 10 files changed)
    • AE: Explicitely check for DTS for making settings invisible (PR:10666, 1 commit, 2 files changed)
    • [xbmc][cleanup] Remove hardcoded bitness from CSysInfo (PR:10637, 1 commit, 1 file changed)
    • Revert "X11, osx: yield to main loop after input action has been handled" (PR:10671, 1 commit, 2 files changed)
    • VideoPlayer: fix subsequent seeks (PR:10665, 4 commits, 3 files changed)
  3. libnfs:
  4. newclock5:
    • New commits in this build:
      • Revert "[dvdmessage] Increase timeout on CDVDMsgGeneralSynchronize" (5c38c80f)
      • VideoPlayer: fix general synchronize after 48301edd6a88c044243e6468ceeb54ff65f35f26 (f263018d)
      • VideoPlayer: do not wait for teletext msg queue to be empty, makes no sense (a4b9d3b6)
  5. kernel 4.8.y:
      • build: support for .dtbo files for dtb overlays (7fb6be7f)
      • [media]bcm2835-camera: fix compilation warning/werror (88403aeb)
      • bcm2709: Drop platform smp and timer init code (5d9847d1)
  6. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [pkg] PR:10663: [guilib] make onclick override conditional. Fallback to default actio…
Still see runaway audio with #1009. Back on #0531
Hello all,
Just to know if I missed something (I was not here for some time), I jumped from #830 to #1008, and Krypton's splash screen disappeared after Kodi's one. Is it normal ?
No, it doesn't matter Smile , but as I can't find this remove in the different releases descriptions, it was just to know if my install is correct.
Thank you Smile
@Sinisan you should see the Kodi Krypton splash appear after the LE splash (either video, or static image) unless you've disabled the Kodi splash in advancedsettings.xml. If you're not seeing the Kodi Krypton splash then please upload your debug log.
Question about timeshift - current setup is 2x PI3s with ServerWMC running on windows box.
I have put latest build LibreELEC on one of the PIs, but the time is now short by an hour. I'm in the UK, and on the other box it is correct, but despite setting the LE one to UK 12H on the International settings it constantly comes back an hour behind Sad
Any ideas where I can change?
(2016-10-10, 14:23)jbromley Wrote: [ -> ]Question about timeshift - current setup is 2x PI3s with ServerWMC running on windows box.
Did you set the "Timezone country" to "Britain (UK)"? You'll need to change the settings level to at least Standard in order to see the Timezone option.
(2016-10-10, 14:33)Milhouse Wrote: [ -> ]
Whereabouts is this option? I only found the "International" option in Skin settings...
Settings > Interface settings > Regional
Also, test with stock Estuary.
@Milhouse
your addon LibreELEC Tvh-addon v.105-#1009-milhouse-v4.1-2267-g6efcfd2 is actually Build: 4.1.2236
Could you check this please?
I just tried #1009 and couldn't find the "use limited color range" option in Settings -> System -> Display (as mentioned here Settings/System/Display (wiki)).
I wanted to set everything up as explained in Video_levels_and_color_space (wiki) but it seems Kodi is always scaling the videos to Full RGB (RPi config.txt is already set to Full RGB and confirmed with tvservice -s) so I'm losing BtB (0-15) and WtW (236-255)
How is this supposed to work?
(2016-10-10, 18:57)Korrigan Wrote: [ -> ]I just tried #1009 and couldn't find the "use limited color range" option in Settings -> System -> Display (as mentioned here Settings/System/Display (wiki)).
You are not losing anything. The Pi knows if the video is limited or full range.
It knows if it is outputting limited or full range and will scale between the two if necessary.
It signals to the display whether the signal is limited or full range.
In general you should just leave everything alone and you will get the right results.
The only instance you need do anything is if the display doesn't handle the limited/full range signalling, but that is pretty rare.
Bought a new wireless dongle (TP-LINK Archer T1U) the other day and just thought I'd give it a go with my Pi and LibreELEC. There doesn't seem to be a driver available for it though.
rpi-lounge:~ # lsusb
Bus 001 Device 004: ID 2357:0105
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
journalctl -k output is here: http://sprunge.us/IPAd
I did a little bit of research and it seems that TP-LINK have a linux driver but only for kernel versions 2.6-3.16 (http://www.tp-link.com/en/download/Arche...tml#Driver). Is there anything that can be done to get this available in LibreELEC?
