Still have the run-away audio problem on recording playback, with #1014
I've tried changing audio settings like pll adjustment, passthrough, latency, no difference.
I've tried changing video settings like adjust display refresh, sync playback to display with no difference.
RPi2 with HDMI out. I don't see the problem when I go back to #0531 so it has to be some kind of software or settings issue.
Are there any AV Params that are controlled by a conf file, rather than the gui?
(2016-10-16, 02:13)mikeb8591 Wrote: [ -> ]Still have the run-away audio problem on recording playback, with #1014
All 3 players have the a/v sync problem for me [audio gets progressively further ahead of video]
OMX player was good up til #0607 #0608 has the a/v sync issue.
MMAL player has bad video up til an end of august build I tried, and then has the a/v sync issue (and video isn't perfect either)
the software player had good a/v sync until the #0714 build, #0715 has the a/v sync issue.
Hopefully this will help someone figure out what's going on. I still have no idea why I'm the only one reporting this.
New LibreELEC.tv Krypton build #1015:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.1 #1 Sun Oct 16 02:40:18 BST 2016 armv6l GNU/Linux
# vcgencmd version
Oct 13 2016 17:21:14
Copyright (c) 2012 Broadcom
version b301dbab300729c7871442ca50f65c669446af20 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161016023917-#1015-ged2f577 [Build #1015]
Based on tip of
LibreELEC.tv master (ed2f5777,
changelog) and tip of
XBMC master (63b8843a,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.8.y
- Includes latest bcm2835-driver master (597c662a, ahead +1)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (2edbd147)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (94d8a71d, +9), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (54120fff, +20), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892, +1), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f, +3), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (2f3dfcdc, +2), pvr.nextpvr (f99b17d3), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (dd95edef), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: sqlite: update to sqlite-3.15.0
- Include [env] PR:837: lcdd: initial addon
- Include [env] PR:838: llvm: build llvm-tblgen for host and use it for target
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:33: bye bye lcdproc (service.libreelec.settings)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10698: [gui] add listitem.appearances for actors / directors
- Include [pkg] PR:10699: [python] Add xbmcgui.DialogBusy()
Build Highlights:
- Controller fixes
- Aspect ratio fix
- SQLite 3.15.0 - micro-optimizations reduce CPU usage by more than 7% on common workloads
- Drop lcdproc - service.lcdd add-on available (addons)
Build Details:
- LibreELEC.tv:
- hardkernel reference no longer need (PR:839, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: fix seek beyond eof for mp4 (PR:10705, 2 commits, 1 file changed)
- Fix controller input on the Shield if peripheral.joystick is not present (PR:10695, 1 commit, 4 files changed)
- Fix restart needed to enable/disable peripheral add-ons (PR:10690, 2 commits, 5 files changed)
- Fix missing lock in CAddonButtonMap (PR:10691, 1 commit, 2 files changed)
- [android] don't strip binaries in debug builds (PR:10683, 2 commits, 3 files changed)
- [CryptThreading] replace hardcoded value for CRYPTO_LOCK by macro (PR:10572, 1 commit, 1 file changed)
- [webinterface.default] tvshows: default to poster view and use sorttitle (PR:9853, 2 commits, 1 file changed)
- [droid] force UTF8 locale (PR:10636, 1 commit, 1 file changed)
- disable filedirectories in addonbrowser (PR:8965, 1 commit, 3 files changed)
- VideoPlayer: drop dead code (PR:10706, 1 commit, 2 files changed)
- SeekHandler: fix state InProgress (PR:10707, 2 commits, 6 files changed)
- [cmake] Fix build_addon() macro (PR:10703, 1 commit, 1 file changed)
- Changed WinEventsSDL.cpp to better support Mac Native Full Screen (PR:10681, 1 commit, 1 file changed)
- [infomanager] add player.dbid infolabel (PR:10567, 1 commit, 2 files changed)
- app: move first access of CPlaylistPlayer after init (PR:10709, 2 commits, 16 files changed)
- [gitignore] add addon packages, __.SYMDEF* and certificates (PR:10566, 1 commit, 1 file changed)
- pvr.mythtv:
- 4.7.3 (PR:73, 2 commits, 3 files changed)
- newclock5:
- New commits in this build:
- VideoPlayer: ffmpeg - use codec aspect ratio for stereo modes (5a98e838)
- kernel 4.8.y:
- ARM64: Modify default config to get raspbian to boot (#1686) (214ccb22)
- Added: [env] patch: sqlite: update to sqlite-3.15.0
- Added: [env] PR:837: lcdd: initial addon
- Added: [env] PR:838: llvm: build llvm-tblgen for host and use it for target
- Added: [pkg] PR:33: bye bye lcdproc (service.libreelec.settings)
Hi.I have a problem with builds #1011 #1012 #1013.When connecting my af9015 dvb-t usb tuner
in rpi3 wired network stops working,wireless is ok.With build #1010 and back usb tuner
and wired network works ok.
dmesg #1010
http://pastebin.com/9cx7vr2X
dmesg #1013
http://pastebin.com/4TnWmiwE
(2016-10-15, 10:06)Milhouse Wrote: [ -> ] (2016-10-08, 12:04)camelreef Wrote: [ -> ] (2016-10-08, 00:30)Milhouse Wrote: [ -> ]- Reverted: [env] PR:793: projects/*/options: disable lcdproc for all projects except Generic/Virtual (Reverted until add-on available)
Thanks again! My VFD is back!
Nico
I'm going to stop reverting the lcdproc change with tonight's build, as there will be a service.lcdd addon you can install as zip from here: http://milhouse.libreelec.tv/builds/addons
Can you give it a try with tonight's build #1015 and report any issues etc.? Thanks!
It is working fine. Once I found the proper conf file for the settings of my MtxOrb driver.
If I may offer advice... Maybe
indicating somewhere in the plugin's interface that choosing the driver may not be enough, and that
editing the config file for that particular driver will probably be needed. Indicating the
location of the conf file would be a plus.
Other than that, I would give this a go.
Thanks for waiting for this plugin before removing LCDd from the main build!
Nico
(2016-10-16, 11:06)dias0 Wrote: [ -> ]Hi.I have a problem with builds #1011 #1012 #1013.When connecting my af9015 dvb-t usb tuner
dmesg #1010 http://pastebin.com/9cx7vr2X
dmesg #1013 http://pastebin.com/4TnWmiwE
The second log doesn't include the start of dmesg - can you try capturing again sooner after boot, where hopefully the initial log messages are present?
Picture (local files) stops randomly for a few seconds with #1015, audio keeps playing (Passthrough). Not sure when it started. It's pretty hard to find out since I would have to watch a movie with every build. I'll try to investigate.
