(2016-10-30, 14:26)popcornmix Wrote: [ -> ] (2016-10-29, 23:42)metaron Wrote: [ -> ]If file would be usefull l can post 1st couple of minutes via google drive. Let me know.
Can you check if problem occurs when playing the file through the file interface (not PVR)?
If you see the problem, then a sample file would be useful.
Well, I can get it to happen every time via PVR.
If I have tried to play it via PVR, trying again via UPNP is likely not to work
If this doesn't work sometimes it won't work via file (NFS mounted storage partition).
If I try directly after power on via file, it always works.
This sounds like a temperature/voltage based problem. Obviously this file does soemthing 'stressfull' but that doesn't make it the file's fault. I've always been a bit dubious about the power supplied by the LG TV anyhow...
Probably better to spend your valuable time looking at more repeatable bugs ;-)
Screensaver no longer works for me, it doesn't stay activated:
17:57:41 252.920059 T:1961280416 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
17:57:41 252.920395 T:1961280416 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
17:57:41 252.923981 T:1961287680 DEBUG: ------ Window Init () ------
17:57:41 253.001892 T:1961287680 DEBUG: Activating window ID: 10138
17:57:41 253.002029 T:1961280416 DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
17:57:41 253.002121 T:1961287680 DEBUG: ------ Window Init (DialogBusy.xml) ------
17:57:41 253.002197 T:1961280416 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
17:57:41 253.016144 T:1961287680 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
17:57:41 253.056824 T:1961287680 DEBUG: ------ Window Deinit () ------
Full Log:
http://pastebin.com/sfbcQvL2
(2016-10-30, 19:00)meccs Wrote: [ -> ]Screensaver no longer works for me, it doesn't stay activated:
Can you reproduce with stock Estuary (I can't)? You're using a third party skin (iqconq) and a bunch of related addons (skin shortcuts, skin helper services etc.) any one of which could be responsible.
If you're sure it's not a skin/addon issue you'll need to identify the first build with the issue, then maybe we can narrow it down.
Seems there is some Buffer (?) issue with the Testbuild and Daisuki plugin (from kodinerds repo)
- LibreELEC 7.0.2 -> FHD stream works
- Auf v7.90.007 -> FHD stream works
- Current Testbuild -> FHD stream lag a lot (Log:
http://sprunge.us/WPbM)
(2016-10-30, 21:40)Kougami Wrote: [ -> ]Seems there is some Buffer (?) issue with the Testbuild and Daisuki plugin (from kodinerds repo)
- Current Testbuild -> FHD stream lag a lot (Log: http://sprunge.us/WPbM)
It looks like the connection to the server you are streaming from is too slow.
Are you sure this wasn't just network conditions?
Is it possible nightly builds are choosing a higher bitrate stream? (does setting a limit in "system/internet access/internet connection bandwidth limitation" help?)
Can you identify the first Milhouse nightly build with the problem?
(2016-10-30, 17:20)metaron Wrote: [ -> ]Well, I can get it to happen every time via PVR.
If you spot a repeatable pattern (e.g. perhaps playing the file a few times from file interface fails) I can investigate.
I can test with the IPTV simple PVR interface - does that fail for you?
(2016-10-30, 22:48)popcornmix Wrote: [ -> ] (2016-10-30, 21:40)Kougami Wrote: [ -> ]Seems there is some Buffer (?) issue with the Testbuild and Daisuki plugin (from kodinerds repo)
Thanks for the answer
SD-Card with fresh installed LibreELEC v7.90.007 (RPi wired connected) -> FHD stream with no lags, no problems (Log:
http://sprunge.us/fLMK ).
After this test, i directly updated to the current Testbuild. Set bandwidth limitation to 512kbps and watched the same episode with lags (resolution was 640x360 !!!) (Log:
http://sprunge.us/fFdM ). I don’t thing this is an network problem, crunchyroll as example works on both versions fine.
New LibreELEC.tv Krypton build #1030:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.4 #1 Sun Oct 30 22:26:52 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Oct 25 2016 17:02:22
Copyright (c) 2012 Broadcom
version cd1ab218dc23c84d9e6d984385a57f2471600300 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161030222550-#1030-gae704a7 [Build #1030]
# Kodi version
Kodi (17.0-BETA6 Git:a08a5e3). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (ae704a71,
changelog) and tip of
XBMC master (a08a5e3f,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.8.y
- Includes latest bcm2835-driver next (a901d4cd, ahead +582)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (f6fdd650, ahead +54)
- Includes latest libnfs master (2edbd147)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (48742bc1), inputstream.smoothstream (081c6c43), peripheral.joystick (ae86732f), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f), pvr.mediaportal.tvserver (aa02879b, +2), pvr.mythtv (2f3dfcdc), pvr.nextpvr (6a2128d8), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (810994a2), pvr.vdr.vnsi (5b47bd06), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] ed1576d2: RBP: ARCH_MULTIPLATFORM changes (see PR:1699)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta5-1
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10739: Fixed OnPlayBackResumed not getting fired anymore.
- Include [pkg] PR:10785: add privacy policy
- Include [pkg] PR:10819: fix hash checking in addon installer
- Revert [pkg] PR:1700: #Use raspberrypi-power to turn on USB power (Reason: RPi1 fails to initialise USB) (linux)
Build Highlights:
- PR:10819: fix hash checking in addon installer
- Revert kernel 4.8.y PR:1700 - breaks USB
- MemoryAlignment: Fixes
Build Details:
- LibreELEC.tv:
- i.MX6 4.4 kernel: update the patches set to all known in the wild (PR:883, 1 commit, 22 files changed)
- XBMC:
- FIX: [amc] Multiple fixes (PR:10779, 5 commits, 2 files changed)
- Coverity: Initialize videoinfotag rating and uniqueid ids (PR:10812, 1 commit, 1 file changed)
- [cmake] Debug binary-addon packaging issues on android (PR:10803, 2 commits, 2 files changed)
- deprecate autotools (PR:10797, 1 commit, 1 file changed)
- Bunch of SPMC jni backports (PR:10808, 26 commits, 76 files changed)
- MemoryAlignment: Fixes (PR:10810, 4 commits, 5 files changed)
- [skins] seeknumeric - use hh:mm:ss format (PR:10816, 1 commit, 2 files changed)
- FFmpeg: Bump to 3.1.5-Krypton-Beta5-1 (PR:10746, 1 commit, 1 file changed)
- allow settings.xml.in (PR:10815, 1 commit, 1 file changed)
- Fixed: RTMP swfvfy also accepts 1 instead of just true (PR:10820, 1 commit, 1 file changed)
- kernel 4.8.y:
- New commits in this build:
- BCM270X_DT: Use raspberrypi-power to turn on USB power (0bf264c2)
- firmware: bcm2835: Don't turn on USB power (9fdbef16)
- Merge pull request #1700 from notro/raspberrypi-power-1 (d8f7c2da)
- Added: [pkg] PR:10819: fix hash checking in addon installer
- Reverted: [pkg] PR:1700: #Use raspberrypi-power to turn on USB power (Reason: RPi1 fails to initialise USB) (linux)
(2016-10-31, 16:46)Aux_ Wrote: [ -> ]Addons menu no longer works, as soon as I with the remote control on Addon menu down scrol crashes kodi and reboot. Addons icons are also not visible.
I think this crash is fixed here:
https://github.com/xbmc/xbmc/pull/10828
(2016-10-31, 16:55)pyrodex Wrote: [ -> ]Could this also fix the crashes I saw last night on two different RPI3s when navigating the TV Library? Some shows would cause it to crash but some would be fine.
Yes, all those crashes look like they may be caused by invalid image buffer allocations, so were likely caused by
#10810 and should be addressed by
#10828
(2016-10-31, 17:00)popcornmix Wrote: [ -> ] (2016-10-31, 16:55)pyrodex Wrote: [ -> ]Could this also fix the crashes I saw last night on two different RPI3s when navigating the TV Library? Some shows would cause it to crash but some would be fine.
Yes, all those crashes look like they may be caused by invalid image buffer allocations, so were likely caused by #10810 and should be addressed by #10828
Thanks! I will test tonight's build if this is pushed into it and report back.
@devs
since 3D playback of MVC streams are already working beautifully from MKVs and ISOs, is there any chance for
a setting to switch left eye and right eye channel? Several movies have left and right eye swapped (i.e. The Hobbit, Edge of Tomorrow) so one has to wear the glasses wrongly.
ps: congrats to libreELEC. I just recently tried it and I am very impressed. Excellent job.
