(2016-11-02, 20:16)Milhouse Wrote: [ -> ] (2016-11-02, 19:31)robertus Wrote: [ -> ]i try last version and works for me at the moment, but i have an addon that doesn't work for this version of kodi (17).
So i want to downgrade to kodi 16, but is slow at change iptv channel.
You know how to fix it in kodi 16 ? (because last testbuilds of this version have some issue for me like black screen when in idle for a while)
@milhouse: infact i didn't attach log, like you told my some posts ago, because this issue if with kodi 16 testbuilds, that i guess isn't supported anymore )
You should contact the add-on developer for a Kodi 17 compatible update. There will be no further Kodi 16 development.
I do that but we say that i'll support 17 when be come stable.
Anyway you know how to have fast iptv change Channel in kodi? Because your builds ( 16 and 17 ) have it.
If we use kodi 16.1 stable in libreelec 7.0.2 is slow.... With iptv simple addon.
Inviato dal mio Nexus 5 utilizzando Tapatalk
(2016-11-02, 22:10)Basfet Wrote: [ -> ]Hi.
Can anybody confirm my bug?
It's only for me?
Unfortunally i use my iptv list without use any Group but tomorrow i'll try to create a group to reproduce the issue
It's only for me?
Your original post is a little confusing.
(2016-11-02, 09:54)Basfet Wrote: [ -> ]Addon PVR IPTV Simple does not recognize the group of channels in the playlist. Tested on the LibreELEC (Krypton) v7.90.008 ALPHA at Raspberry Pi3. LibreELEC Kodi 16.1 - Jarvis works similarly.
Does the above mean that 7.90.008 also doesn't recognise the group of channels in the playlist? And neither does Jarvis? Or that 7.90.008 and Jarvis are correctly showing the channels in the playlist, but the latest test builds in this thread do not?
(2016-11-02, 09:54)Basfet Wrote: [ -> ]Channel groups can be seen on OSMС builds with the same playlist.
Difficult to draw any conclusion without knowing which version of OSMC and which version of PVR IPTV Simple on OSMC you are testing with.
(2016-11-02, 09:54)Basfet Wrote: [ -> ]What am I doing wrong?
In the absence of a
debug log (wiki), or any better ideas from PVR developers, the best approach is usually to identify the first test build with the problem.
New LibreELEC.tv Krypton build #1102:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.6 #1 Wed Nov 2 21:08:22 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Oct 25 2016 17:02:22
Copyright (c) 2012 Broadcom
version cd1ab218dc23c84d9e6d984385a57f2471600300 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161102210542-#1102-g9d8a561 [Build #1102]
# Kodi version
Kodi (17.0-BETA6 Git:564671b). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (9d8a561e,
changelog) and tip of
XBMC master (564671b5,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.8.y
- Includes latest bcm2835-driver next (a901d4cd, ahead +584)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (81fe5bc0, ahead +56)
- Includes latest libnfs master (2edbd147)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (f1cb7cb0, +2), inputstream.smoothstream (081c6c43), peripheral.joystick (ae86732f), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (2c73804a, +3), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f), pvr.mediaportal.tvserver (aa02879b, +2), pvr.mythtv (2f3dfcdc), pvr.nextpvr (6a2128d8), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (8e496578, +10), pvr.vdr.vnsi (5b47bd06), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] 881901c6: Mako: initial commit
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta5-1
- Include [env] patch: mesa: update to mesa-13.0.0
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: visualization.shadertoy: update to 1.1.4
- Include [env] PR:900: linux: update to linux-4.8.6
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10785: add privacy policy
- Include [pkg] PR:10819: fix hash checking in addon installer
Build Highlights:
- [PVR] Fix epg update deadlock.
- [python] Add xbmcgui.DialogBusy()
Build Details:
- LibreELEC.tv:
- imx6: bump linux to 3.14.79 (PR:902, 1 commit, 2 files changed)
- touchscreen: initial addon (PR:897, 1 commit, 30 files changed)
- Add $DEVICE support to the build-system (PR:842, 6 commits, 10 files changed)
- touchscreen: limit build projects and use autoreconf for tslib (PR:903, 1 commit, 2 files changed)
- WeTek_Hub: use meson-ir and lirc (PR:820, 3 commits, 6 files changed)
- XBMC:
- [PVR] Fix epg update deadlock. (PR:10841, 1 commit, 1 file changed)
- [python] Add xbmcgui.DialogBusy() (PR:10699, 3 commits, 5 files changed)
- [depends] alsa-lib: fix typo in configure.in (PR:10840, 1 commit, 2 files changed)
- [Fix] access violation in CFFmpegImage::Initialize (PR:10842, 1 commit, 1 file changed)
- [win32] Set minimum Windows 10 version for UWP (PR:10843, 1 commit, 1 file changed)
- pvr.hdhomerun:
- Update libhdhomerun (PR:29, 4 commits, 3 files changed)
(2016-11-03, 00:30)Milhouse Wrote: [ -> ]Does the above mean that 7.90.008 also doesn't recognise the group of channels in the playlist? And neither does Jarvis? Or that 7.90.008 and Jarvis are correctly showing the channels in the playlist, but the latest test builds in this thread do not?
I did not find any version LibreElec that would show channel group for IPTV. I tried version LibreELEC 7.0.2, LibreELEC (Krypton) v7.90.006, LibreELEC (Krypton) v7.90.008. Versions of PVR IPTV Simple which have been used: 1.12.12 (for Jarvis), 2.4.4 (for Krypton).
OSMC build 2016.08-1 (Kodi Jarvis) with the add-on version 1.12.12 (the same as in LibreELEC 7.0.2) works correctly with groups of channels. The same versions of the addon (1.12.12, 2.4.4) work correctly at Kodi for Windows. I also confirm that this bug has not been observed in the OpenElec.
I think that this is a bug of LibreElec.
I am currently on Libre ELEC alpha 7 , and channel groups for IPTV work fine in the Simple Client.
In fact, they have always worked for me with Libre ELEC .
On the alpha versions:
- Go to TV - Channels (so you get the list)
- Navigate to Left
- There you will see an option to choose a group
(2016-11-03, 14:00)Bmn2016 Wrote: [ -> ]- There you will see an option to choose a group
I know it. But I only see "All channels" and nothing else. No groups.
What's your device? Raspberry Pi3?
(2016-11-03, 14:00)Bmn2016 Wrote: [ -> ]I am currently on Libre ELEC alpha 7 , and channel groups for IPTV work fine in the Simple Client.
It seems that this bug personally for me.
Can I ask for an example of your playlist to check?
(2016-10-23, 12:02)Milhouse Wrote: [ -> ] (2016-10-23, 11:26)origpumu Wrote: [ -> ]Hi, many thanks for your great work! Can someone help me with this (for me anoying) overlay that shows playing position and endtime of played songs. It is shown in Front of the normal gui and also in screensaver. Is there an Option to disable this timebar?
This is a bug in Estuary, please report it in the Estuary bug thread: http://forum.kodi.tv/showthread.php?tid=262373
Include a screenshot - pictures speak a thousand words. If you know how to trigger it (I've seen it once, but couldn't reproduce) then that will help enormously.
Edit: No sooner do I post this then I can reliably reproduce...
I'll post something in the bug thread...
Does anyone have an update on this issue? It occurs 100% of the time on my system, with both Estuary and Estuary MOD. It also shows up when using the new Beta 8 release. Beta 7 works fine. I see where Milhouse posted a bug report with the Estuary team, but no one seems to have an answer. The Estuary MOD team seems confused as well. Are we sure that this is a skin issue?
Mike
Basfet are you testing with stock Estuary? If not, it's likely a skin issue. Also try a "clean" .kodi, with default settings and add-ons - shutdown Kodi, rename .kodi to .kodi.bak, restart Kodi, enable PVR IPTV Simple add-on then report results.
(2016-11-03, 16:01)mazeeff Wrote: [ -> ]Does anyone have an update on this issue? It occurs 100% of the time on my system, with both Estuary and Estuary MOD. It also shows up when using the new Beta 8 release. Beta 7 works fine. I see where Milhouse posted a bug report with the Estuary team, but no one seems to have an answer. The Estuary MOD team seems confused as well. Are we sure that this is a skin issue?
This was bothering me last night, actually, so I did some testing.
I see it on a NUC, so it's nothing to do with newclock5 patches, and not RPi specific.
I dropped all unmerged patches (both for Kodi core, and Estuary, so essentially building only plain Kodi master) and I still saw the stuck seek overlay in LibreELEC on NUC, yet can't reproduce this on Ubuntu (timing issue, perhaps?)
Interesting that you see it in Estuary MOD, which further suggests this isn't a new skin issue being introduced by LibreELEC patches as these builds do nothing with Estuary MOD.
I also tested with a "clean" .kodi - no extra addons, all default settings - but still see this issue.
Going back through old builds today and it first appears in
build #1015.
Reverting PR10707 seems to fix the issue and I no longer see the stuck seek overlay in a new NUC test build.
I'll drop PR10707 from tonight's build as a one-off test.
@Milhouse
@Bmn2016
I found my problem.
Item "Synchronise channel groups with backend(s)" in TV settings is disabled by default for LibreElec (enabled by default for OSMC and Windows).
I turned on it and groups of channels are displayed.
Thanks to all.
p.s. Maybe turn it on by default?
you know why milhouse builds for example about kodi 16 and also 17 have fast switch iptv channel, and stable version are too slow ?
i can't figure out that and i don't know how to fix it
(2016-11-03, 21:13)robertus Wrote: [ -> ]you know why milhouse builds for example about kodi 16 and also 17 have fast switch iptv channel, and stable version are too slow ?
With which addon (IPTV Simple Client maybe)?
New LibreELEC.tv Krypton build #1103:
RPi /
RPi2
# uname -a
Linux rpi512 4.8.6 #1 Thu Nov 3 21:03:44 GMT 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161103210241-#1103-g9d8a561 [Build #1103]
# Kodi version
Kodi (17.0-BETA6 Git:f74b5fd). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (f74b5fd1,
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (aa3b00ac, +3), inputstream.smoothstream (081c6c43), peripheral.joystick (ae86732f), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (2c73804a, +3), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f), pvr.mediaportal.tvserver (aa02879b, +2), pvr.mythtv (038cee07, +6), pvr.nextpvr (6a2128d8), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (8e496578, +10), pvr.vdr.vnsi (5b47bd06), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Include [env] PR:905: mesa: update to 13.0.0
- Include [pkg] PR:36: fix syntax in window xml (service.libreelec.settings)
- Include [pkg] PR:10800: [xbmc][fix] Change texture loading to not block skin updates
- Revert [pkg] PR:10707: SeekHandler: fix state InProgress (Reason: stuffs up music seek overlay)
Build Highlights:
- Drop PR10707 Seekhandler. Is the stuck Music seek overlay fixed? (@mazeeff)
- PR:10800: [xbmc][fix] Change texture loading to not block skin updates (for @paxxi)
Build Details:
- XBMC:
- FFmpegImage: free avpacket side data (PR:10844, 1 commit, 1 file changed)
- more verbose help for --enable-optimizations (PR:10839, 1 commit, 1 file changed)
- [strings] Clarify it's system memory/cpu usage (PR:10802, 1 commit, 3 files changed)
- inputstream.rtmp:
- fix build on Rbpi (PR:10, 1 commit, 1 file changed)
- pvr.mythtv:
- 4.8.0 (PR:74, 3 commits, 9 files changed)
- 4.9.0 (PR:75, 3 commits, 11 files changed)
- Added: [env] PR:905: mesa: update to 13.0.0
- Added: [pkg] PR:36: fix syntax in window xml (service.libreelec.settings)
- Added: [pkg] PR:10800: [xbmc][fix] Change texture loading to not block skin updates
- Reverted: [pkg] PR:10707: SeekHandler: fix state InProgress (Reason: stuffs up music seek overlay)
