(2016-11-08, 21:55)garret Wrote: [ -> ]EDIT: Sorry. I know that i should take screenshot from Estuary skin, but this issue exist in all skins.
I think creating a
trac issue would be best. Pretty sure this issue isn't related to Pi or these builds.
Saw a crash in #1108 and log is here:
http://sprunge.us/QhKD
Was watching LiveTV on mythtv PVR and it went black so I stopped it and it crashed.
(2016-11-09, 16:37)pyrodex Wrote: [ -> ]Saw a crash in #1108 and log is here: http://sprunge.us/QhKD
That crash is interesting as it looks to be in MMAL code. I can see you pressing stop:
08:26:23 T:1961197568 DEBUG: LIRC: Update - NEW at 1203507:80 0 KEY_STOP devinput (KEY_STOP)
08:26:23 T:1961197568 DEBUG: OnKey: guide (0xe0) pressed, action is Stop
But no kodi errors before that. How long was the screen black before you pressed stop?
I notice you have a high overclock - can you try disabling that for now and see if you can reproduce issue?
(2016-11-09, 17:17)popcornmix Wrote: [ -> ] (2016-11-09, 16:37)pyrodex Wrote: [ -> ]Saw a crash in #1108 and log is here: http://sprunge.us/QhKD
The screen was black for about 10-15 seconds, during last night after upgrading I saw an issue with PVR.
I will disable the overclock and report back.
(2016-08-15, 20:30)popcornmix Wrote: [ -> ] (2016-08-15, 18:51)thent Wrote: [ -> ]since long time ago - unfortunately I cannot tell since which build exactly, but at least the beginning of this year - I've been experiencing kodi crashes (+ subsequent rebooting) when opening audio streams. I'm using the radiotunes addon together with Yatse from several Android devices to run the streams. Usually, when kodi was idle for hours, it crashes immediately after opening a second stream righter after the first one.
Yes. I flagged it on the Kodi Slack, and the problem has been identified
May I remind you that this still seems to be unfixed for me. Thanks!
Strange restart/crash of Kodi with crashlog:
http://sprunge.us/LGDZ
Unfortunately things have been working well and I didn't expect a crash, so no debug enabled.
(2016-11-09, 22:40)zaphod24 Wrote: [ -> ]Strange restart/crash of Kodi with crashlog:
Unfortunately no info in the backtrace
Thread 1 (Thread 0x74dfa000 (LWP 404)):
#0 0x76f2fb64 in memcmp () from /lib/libarmmem.so
#1 0x44e98000 in ?? ()
If you find a way of reproducing it, a debug LE build may have a better backtrace.
(2016-11-09, 22:43)popcornmix Wrote: [ -> ] (2016-11-09, 22:40)zaphod24 Wrote: [ -> ]Strange restart/crash of Kodi with crashlog:
Sure thing. It was just sitting idle at home though.
(2016-11-09, 22:52)zaphod24 Wrote: [ -> ] (2016-11-09, 22:43)popcornmix Wrote: [ -> ]If you find a way of reproducing it, a debug LE build may have a better backtrace.
I've uploaded a debug-enabled build #1109x:
RPi2
New LibreELEC.tv Krypton build #1109:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.6 #1 Wed Nov 9 21:03:33 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Nov 6 2016 16:30:41
Copyright (c) 2012 Broadcom
version 4150eddb59ec25e6f328f5efbc6d222d8861dc93 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161109210230-#1109-ge95c15f [Build #1109]
# Kodi version
(17.0-BETA6 Git:93876d9). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (e95c15fd,
changelog) and tip of
XBMC master (93876d9d,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.8.y
- Includes latest bcm2835-driver next (c9a60134, ahead +585)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (481dd826, ahead +58)
- Includes latest libnfs master (a2b37349, ahead +2)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (4d4be7f7, +4), inputstream.smoothstream (081c6c43), peripheral.joystick (8364b65a, +7), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (2c73804a, +3), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f), pvr.mediaportal.tvserver (47b9ade8, +16), pvr.mythtv (038cee07, +6), pvr.nextpvr (6a2128d8), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (7ffbb3d7, +16), pvr.vdr.vnsi (5b47bd06), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta5-1
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: visualization.shadertoy: update to 1.1.4
- Include [env] PR:924: debug: make valgrind optional, disabled by default, not available for armv6
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:249: Fix ass_set_cache_limits() to work with composite cache (libass)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- projects/WeTek_Play_2: Update recovery image (PR:926, 1 commit, 1 file changed)
- libass: update to 0.13.4 (PR:918, 1 commit, 1 file changed)
- XBMC:
- [guiinfo][pvr] Fix LISTITEM_RESUMABLE to prefer recording info tag over video info tag, fire recordings updated event on playcount change" (PR:10899, 1 commit, 2 files changed)
- [iOS] Fix IsIosSandboxed (PR:10905, 1 commit, 1 file changed)
- [cmake] Fix issue with PLATFORM_OVERRIDE (on linux) (PR:10897, 2 commits, 5 files changed)
- pvr.vbox:
- Added reminders (popup only) to EPG+channels menus (PR:150, 2 commits, 12 files changed)
- kernel 4.8.y:
- New commits in this build:
- spi-bcm2835: Remove unused code (6927ac4d)
(2016-11-09, 23:32)Milhouse Wrote: [ -> ] (2016-11-09, 22:52)zaphod24 Wrote: [ -> ] (2016-11-09, 22:43)popcornmix Wrote: [ -> ]If you find a way of reproducing it, a debug LE build may have a better backtrace.
I've uploaded a debug-enabled build #1109x: RPi2
Thanks! I've installed the debug-enabled build and l will upload a crash log if it happens again.
(2016-11-10, 03:00)zaphod24 Wrote: [ -> ] (2016-11-09, 23:32)Milhouse Wrote: [ -> ] (2016-11-09, 22:52)zaphod24 Wrote: [ -> ]Sure thing. It was just sitting idle at home though.
Crash from debug build Milhouse was kind enough to provide:
http://sprunge.us/TSAR
(2016-11-10, 19:02)zaphod24 Wrote: [ -> ] (2016-11-10, 03:00)zaphod24 Wrote: [ -> ] (2016-11-09, 23:32)Milhouse Wrote: [ -> ]I've uploaded a debug-enabled build #1109x: RPi2
Exodus could be your problem, try uninstalling it..
(2016-11-10, 20:35)bmonster Wrote: [ -> ] (2016-11-10, 19:02)zaphod24 Wrote: [ -> ] (2016-11-10, 03:00)zaphod24 Wrote: [ -> ]Thanks! I've installed the debug-enabled build and l will upload a crash log if it happens again.
Can certainly give that a shot and see if it goes away.
