Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
Whilst it's installed your device is in violation of our forum rules (wiki) so you'll get no further support here if it remains installed.
New LibreELEC.tv Krypton build #1110: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.6 #1 Thu Nov 10 21:14:56 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Nov  6 2016 16:30:41
Copyright (c) 2012 Broadcom
version 4150eddb59ec25e6f328f5efbc6d222d8861dc93 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161110211354-#1110-g305c902 [Build #1110]
# Kodi version
(17.0-BETA6 Git:5957945). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (305c902e, changelog) and tip of XBMC master (59579457, changelog) with the following modifications: Build Highlights:
  1. Show pretty name in "Available Versions" listing (LE Settings > Updates)
Build Details:
  1. LibreELEC.tv:
    • hyperion: add patch to remove protobuf cmake function (PR:927, 1 commit, 1 file changed)
  2. XBMC:
    • [cmake] separate_arguments() is stupid (PR:10900, 1 commit, 8 files changed)
    • Picture: Partially revert f5f9b8d and aadfc21d (keeping fixes) (PR:10906, 1 commit, 1 file changed)
    • [depends] Force link generation (PR:10891, 1 commit, 2 files changed)
    • [PVR] Fix and cleanup pvr window's sort methods. (PR:10907, 1 commit, 1 file changed)
    • [PVR] Guide info dialog: fix record/add timer button visibility. (PR:10908, 1 commit, 1 file changed)
    • [cmake] Allow building add-ons by regex match without bootstrapping f… (PR:10902, 1 commit, 1 file changed)
  3. peripheral.joystick:
    • [cocoa] Fix race condition by merging CJoystickAsync into CJoystickCocoa (f0feece1)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:929: libva: bump to libva-1.7.3 and libva-intel-driver-1.7.3
    • Added: [pkg] PR:39: use prettyname_regex to show shortname in update menu (service.libreelec.settings)
(2016-11-10, 22:09)DarrenHill Wrote: [ -> ]Whilst it's installed your device is in violation of our forum rules (wiki) so you'll get no further support here if it remains installed.
Roger that. I have uninstalled it and hopefully it was the cause of the crashes.
(2016-11-02, 16:18)popcornmix Wrote: [ -> ]
(2016-11-02, 15:55)Kougami Wrote: [ -> ]- Open daisuki
- All Series -> Magic of Stella -> Episode 1
- Played the first 2-3min
-> #1024 no buffering/lag , #1025 a lot of buffering/lags
Set bandwidth limitation for #1025, but still same problem.
I've watched first 5 minutes and no buffering/lags.
What does the video bitrate and resolution show as for #1024 and #1025?
I see 1920x1080 and ~5Mb/s with latest version (and no internet bandwidth limit).
I asked the developer of the daisuki plugin, and seems this is my issue: 296611 (thread)
(2016-11-10, 20:51)zaphod24 Wrote: [ -> ]
(2016-11-10, 20:35)bmonster Wrote: [ -> ]
(2016-11-10, 19:02)zaphod24 Wrote: [ -> ]Crash from debug build Milhouse was kind enough to provide:
http://sprunge.us/TSAR
Exodus could be your problem, try uninstalling it.. Big Grin
Can certainly give that a shot and see if it goes away.
Running 1110 and uninstalled Exodus, still got the following dump overnight:
http://sprunge.us/Ijbi
The last few weeks I have a problem that I don't have any audio over HDMI. I started from scratch and since then I'm without audio. It doesn't matter in with order I power on the devices. After 5 or 6 times powering off/on everything is working and I have audio over HDMI. But it drives me crazy to do this every time I power on the system.
What I did so far:
If I install Openelec 6.0.3 I have always sound with that version. Installing Milhouse builds from Kodi 16 (Back then I always had audio) doesn't provide me audio. Also installing Kodi 17 Milhouse build doesn't give audio (but it did in the past). I searched the log, but I don't see any errors regarding audio. Then I changed the HDMI port, on with my raspberry pi, is on my amp to a different one, but this doesn't solve my problem.
I have played with serveral settings in the config.txt file, like HDMI_drive=2, etc. The config file is here: https://drive.google.com/file/d/0B4DCePj...sp=sharing
Here is the log file when there is no audio: https://drive.google.com/file/d/0B4DCePj...sp=sharing
Here is the log when I have audio: https://drive.google.com/file/d/0B4DCePj...sp=sharing
In different topics I came across the tvservice command. This is the output:
LibreELEC (community) Version: devel-20161104210232-#1104-gafab221
LibreELEC git: afab2210c74e43f5111739fbb3bc1c4aae14a1bc
LibreELEC:~ # tvservice -a
PCM supported: Max channels: 8, Max samplerate: 192kHz, Max samplesize 24 bits.
AC3 supported: Max channels: 8, Max samplerate: 48kHz, Max rate 640 kb/s.
DTS supported: Max channels: 8, Max samplerate: 48kHz, Max rate 1536 kb/s.
DTS_HD supported: Max channels: 8, Max samplerate: 192kHz, Max rate 8 kb/s.
LibreELEC:~ # tvservice -m CEA
Group CEA has 21 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
(prefer) mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
mode 14: 720x480 @ 60Hz 4:3, clock:54MHz x2 progressive
mode 15: 720x480 @ 60Hz 16:9, clock:54MHz x2 progressive
mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
(native) mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced
mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
mode 29: 720x576 @ 50Hz 4:3, clock:54MHz x2 progressive
mode 30: 720x576 @ 50Hz 16:9, clock:54MHz x2 progressive
mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
mode 35: 720x480 @ 60Hz 4:3, clock:108MHz x4 progressive
mode 36: 720x480 @ 60Hz 16:9, clock:108MHz x4 progressive
mode 37: 720x576 @ 50Hz 4:3, clock:108MHz x4 progressive
mode 38: 720x576 @ 50Hz 16:9, clock:108MHz x4 progressive
LibreELEC:~ # tvservice -m DMT
Group DMT has 1 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
Now I'm lost...
I hope you can help or provide me guidance how to solve this.
(2016-11-11, 17:48)wizzard72 Wrote: [ -> ]I hope you can help or provide me guidance how to solve this.
Are you using an AVR? Pi <-hdmi-> AVR <-hdmi-> TV or some other configuration?
Can you report output of:
tvservice -s
tvserice -n
when audio is working and not working?
You seem to be getting a different EDID in the two cases. no audio:
DEBUG: EGL initial desktop resolution 1920x1080 (1920x1080) @ 60.00i - Full Screen (1.00)
Audio:
DEBUG: EGL initial desktop resolution 1920x1080 (1920x1080) @ 60.00 - Full Screen (1.00)
and the list of supported modes (tvservice -m CEA) is different.
I suspect in one case we are getting the edid from the AVR and the other we are getting the EDID from TV.
It is possible that following this scheme: http://kodi.wiki/view/Raspberry_Pi_FAQ#T...d_on_first
making sure audio is working when you capture the EDID will result in a permanent fix.
(2016-11-11, 15:17)zaphod24 Wrote: [ -> ]Running 1110 and uninstalled Exodus, still got the following dump overnight:
I've shown the log to some devs and the line
23:06:26.119 T:1795158944   ERROR: CRenderManager::UnInit - not called from render thread
is surprising. The log didn't have debug enabled, so it's hard to piece together why UnInit is being called.
Can you try to capture a similar log with debug logging enabled?
Yeah, I'll try to do that tonight. From what I can tell, this is happening if I leave content playing but power off my TV. When the new CEC support came out, it added an option of being able to stop playback when the TV is powered off. Maybe that is the cause of the problem?
(2016-11-11, 21:35)zaphod24 Wrote: [ -> ]Yeah, I'll try to do that tonight. From what I can tell, this is happening if I leave content playing but power off my TV. When the new CEC support came out, it added an option of being able to stop playback when the TV is powered off. Maybe that is the cause of the problem?
very likely. what exactly did you do?
Popcornmix, thank you for your fast responce.
(2016-11-11, 19:20)popcornmix Wrote: [ -> ]Are you using an AVR? Pi <-hdmi-> AVR <-hdmi-> TV or some other configuration?
It's exactly like that: PI --> AVR --> TV
(2016-11-11, 19:20)popcornmix Wrote: [ -> ]Can you report output of:
tvservice -s
tvserice -n
Good:
LibreELEC:~ # tvservice -s
state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
LibreELEC:~ # tvservice -n
device_name=ONK-TX-SR707
Error:
The tvservice -a now shows (no audio):
PCM supported: Max channels: 2, Max samplerate: 48kHz, Max samplesize 24 bits.
(2016-11-11, 19:20)popcornmix Wrote: [ -> ]It is possible that following this scheme: http://kodi.wiki/view/Raspberry_Pi_FAQ#T...d_on_first
I followed the steps in the wiki, but it didn't work. The TV is powered on as first, second the AVR and at last the raspberry pi. There is 5 seconds between the devices when powering on.
The strange think is that I have to power off the devices for 30 minutes before the audio over HDMI doesn't work anymore. If it's less than 30 minutes the audio over HDMI is working. I power off everything when I stop watching TV.
(2016-11-12, 00:13)FernetMenta Wrote: [ -> ]
Watching LiveTV using the MythTV plugin (mmal-mpeg2) and turn off the TV. This stops video playback. If I turn the TV back on soon after, it is black until I press a key on the remote and then the screen comes back. Whether or not I watch TV again later, sometime overnight the crash occurs. The last time was ~2am my time.
New LibreELEC.tv Krypton build #1111: RPi / RPi2
# uname -a
Linux rpi512 4.8.6 #1 Fri Nov 11 23:57:19 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Nov  6 2016 16:30:41
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161111235537-#1111-gded08c8 [Build #1111]
# Kodi version
(17.0-BETA6 Git:a458002). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (ded08c83, changelog) and tip of XBMC master (a458002b, changelog) with the following modifications: Build Highlights:
  1. newclock5 cleanup now that libcec 4.0.0 has merged
  2. busybox tar fix
Build Details:
  1. LibreELEC.tv:
    • debug: make valgrind optional, disabled by default, not available for… (PR:924, 2 commits, 3 files changed)
  2. XBMC:
    • bump to libCEC 4.0.0 + some rebased PRs (PR:10775, 4 commits, 12 files changed)
    • Videoplayer: If subtitles are set to "on" and the preferred language is "original stream's language" at least default subtitles should be shown, regardless of there language. (PR:10901, 1 commit, 1 file changed)
  3. newclock5:
    • New commits in this build:
      • cec: fixup strings after PR 10775 (04810182)
      • [win32] Settings: Added setting to enable/disable MVC decoder. (fdccdaef)
      • [Stereo3D] Added block_lr and block_rl to supported modes. (5949edd6)
      • [VideoPlayer] HasVideo returns true if video stream exists. This don't allow start visualization if audio is opened before video. (5c106bde)
      • [VideoPlayer] Disable reading extension stream from input stream if decoder doesn't support it. (0b59b35e)
      • [Settings] move SETTING_VIDEOPLAYER_SUPPORTMVC from platform settings to common settings. (6263c226)
      • [VideoPlayer] SSIF: fix for corner case when mvc stream is switched before the last packet is read from previous stream. (e5f776fc)
      • stereoscopicmanager: fixups for rbp (4ca0ca51)
      • fixup! Revert supporting crappy tab/sbs subtitles. this fixes regular subtitles. (321242b6)
    • Commits no longer in build:
      • [Stereo3D] Added mvc modes. (1e32d0aa)
      • [BaseRenderer] Fix aspect for TAB/SBS (need more testing) (e6522357)
      • [VideoPlayer] Added new msdk-mvc decoder. (c90f5092)
      • stereoscopicmanager: remove hardwarebased for rbp (661ddb2c)
      • stereoscopics: Switch to using block_lr for mvc to match makemkv (db5cbf74)
      • [libcec] Add repeating keypress patch from popcornmix' repo (a0e1f3c5)
      • cec: hack: pretend bump to 3.1.0 (d437e083)
      • [cec] Update for libcec 3.1.0 (b8d85998)
      • libcec: use system audio mode request instead of power on to start AVR reliable (2ce4c9e0)
      • Revert "libcec: use system audio mode request instead of power on to start AVR reliable" (983c9cab)
      • Revert "[cec] Update for libcec 3.1.0" (f5d68c0b)
      • Revert "[cec] Temp - more logging" (ed690916)
      • Revert "[cec] Don't discard buttons when repeat mode is enabled" (f6cd5cf1)
      • Revert "[cec] Add settings for configuring button repeats" (25ba0492)
      • Revert "cec: hack: pretend bump to 3.1.0" (9a4e73af)
      • Revert "[libcec] Add repeating keypress patch from popcornmix' repo" (545c1131)
      • Revert "[cec] Don't suspend pi on tv switch off - it can't wake up" (d1ada620)
      • bump to libCEC 4.0.0 (aa343e3e)
      • Added advances settings for action when TV goes standby (146b4082)
      • Add CEC IMX adapter as known type and set no polling. - that eliminates extensive periodic /sys walkthrough (e0c2ba52)
      • changed: removed no longer used com port override (88bbe85c)
      • added: setting to make libCEC wake up the AVR explicitly when activating the source. (4ab126ba)
      • bump dep to 4.0.0 (b310e657)
      • fixed: wrong label used in 41621bcc99be98f0b2e9e4845564894a16348ba3 (5cc775e9)
      • bump dep to 4.0.0 (da73dbdd)
      • Revert "[power] hack - don't kill lirc or cec" (36243488)
      • [cec] Don't suspend pi on tv switch off - it can't wake up (bbedf55e)
      • [cec] Add settings for configuring button repeats (c0aa85f1)
      • [cec] Don't discard buttons when repeat mode is enabled (dca0891f)
      • [cec] Temp - more logging (6e2e5e61)
      • [power] hack - don't kill lirc or cec (958bbfde)
    • Added: [pkg] patch: tar: handle pax-encoded utf8 filenames and link names. Closes 9406 (busybox)
There is no sound anymore after the update. Somebody else got that issue?
Well... I had no sound after starting music a youtube video or a movie but it got back on after starting a youtube live stream. So after that everything works fine for now...weird Smile
(2016-10-23, 10:43)DaveBlake Wrote: [ -> ]
(2016-10-23, 10:07)meccs Wrote: [ -> ]Is this about the freezing or stuttering? I'm confused now. Because if it is still about the "freezing while audio continues" I can chime in. I have traced it back to #0919 and with those older builds it is a bit different. The picture AND audio freezes.
popcornmix doesn't notice it probably because it is very random. You can't just start a video and then watch for 10 minutes. It can go for 2 hours and suddenly happen or you can watch for 30 and it will happen 3 times. So tracking it down is very difficult.
The ONE thing that would make it easier is if someone could tell me how to disable the On Screen Overlay while logging. I can only watch so much stuff for hours without getting annoyed about the overlay. This really needs to go in order to make logging a lot more pleasant. There should be at least the option to disable it.
My issue is sound continues but picture freezes for a moment then leaps to catchup. So not both. But it does not happen at repeatable places on a video like you describe. Enabling both sync playback to display and Adjust display refresh rate to match seems to have solved it.
To avoid the on screen overlay set loging from advancedsettings.xml rather than the GUI. See here Log_file/Advanced (wiki)
For video do something like this
<loglevel>1</loglevel>
  <debug>
      <extralogging>true</extralogging>
      <setextraloglevel>32768</setextraloglevel>
      <showloginfo>false</showloginfo>
  </debug>
The randomness of the the picture freezing but the sound continuing makes it hard to determine what it could be. We can be watching for ages and nothing will happen and then the picture pauses for a few seconds whilst the sound continues but after that few seconds the picture then catches up.
Sadly enabling sync playback to display no longer seems to enable DTS audio pass-through for sound.
It didn't use to happen but again due to the randomness it is hard to remember when it did start.
