Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-11-17, 04:58)Milhouse Wrote: [ -> ]
(2016-11-17, 04:39)bill_orange Wrote: [ -> ]During music library scan temp is 172 F. Should I do anything about it?
172F is about 78C, which is within limits but may be causing the ARM to throttle (reduce frequency). Not ideal, and a small heatsink would help (or a FLIRC case).
(2016-11-17, 04:39)bill_orange Wrote: [ -> ]This started with build #1114.
Did anything else change, such as your skin, perhaps?
When you are running the scan, is there any text that is constantly scrolling (as this can send the GPU temperature through the roof)?
In #1114 there is a firmware and kernel update, maybe this causes the GPU to run a little hotter than usual.
Yes. the progress scan is scrolling. I have some small heat sinks I can attach.
New LibreELEC.tv Krypton build #1117: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.8 #1 Thu Nov 17 21:03:09 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Nov 14 2016 16:19:30
Copyright (c) 2012 Broadcom
version 4a839311e7b5fc3422a8e6a8623b30b52891e0ea (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161117210206-#1117-g2834222 [Build #1117]
# Kodi version
(17.0-BETA6 Git:3905258). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (28342226, changelog) and tip of XBMC master (3905258c, changelog) with the following modifications: Build Highlights:
  1. Fix RTMP-related crash
Build Details:
  1. LibreELEC.tv:
    • oscam: fix settings-default.xml (PR:941, 2 commits, 3 files changed)
  2. XBMC:
    • Follow HTTP redirect to UDP stream (PR:10933, 2 commits, 1 file changed)
    • [listprovider] Make sure content is always loaded. Fixes #16635 (PR:10931, 1 commit, 1 file changed)
    • MMALCodec: Take more care with the output lock mutex (PR:10945, 1 commit, 1 file changed)
  3. inputstream.rtmp:
    • fixed: do not close non-existent session (9a57ec14)
  4. newclock5:
    • New commits in this build:
      • temp: Add spammy logging to track down seek delays pt2 (ee39603e)
      • Revert "temp: Add spammy logging to track down seek delays pt2" (43642e5c)
    • Commits no longer in build:
      • MMALCodec: Take more care with the output lock mutex (36190ba3)
  5. kernel 4.8.y:
      • fixup: fb: Use struct device for dma_alloc_coherent (7d1faf89)
(2016-11-17, 20:12)Milhouse Wrote: [ -> ]
(2016-11-17, 19:53)ironic_monkey Wrote: [ -> ]please try https://github.com/notspiff/inputstream....b22ecb1077
Thanks, will include this in tonight's build.
That fixed it Smile
Actually it fixed it on channel stop.. but still crashes on channel change i.e. pressing up or down whilst watching a channel..
Here is debug crashlog of channel change
http://sprunge.us/RdOc
(2016-11-15, 21:59)Milhouse Wrote: [ -> ]
(2016-11-15, 19:47)Solomalee Wrote: [ -> ]any ideas?
Not without a log, preferably a debug log.
Hi, find attached a collection of log files - these are from two Raspberry PI, both running KODI 17 Beta 5 with the same basic configuration (Built from the same configuration backup). They are named PI_ATTIC & PI_LIVINGROOM respectively and both exhibit exactly the same behaviour:
After the TV is turned off at ~23:30 and turned back on in the morning (about 7 hours not being used overnight), I navigate to TV, select BBC1 from the channel list and click select to switch to that channel. The spinning timer appears and the TV channel never switches. (I notice that the onscreen Debug information is still happily updating on screen at top left)
Here are the log files for PI_ATTIC taken after I navigated to TV and selected from the channel list BBC 1
https://dl.dropboxusercontent.com/u/1448..._attic.zip
For PI_LIVINGROOM, I have two versions of the log files for you...
One set taken before the TV freeze:
One set taken after the TV freeze:
https://dl.dropboxusercontent.com/u/1448...m_post.zip
I tried last night waiting various lengths of time, I am up to 2 hours now with the TV off (PI running) and the error doesn't manifest itself, today, I'll be increasing to 3 hours, 4 hours etc until I find out how long it takes for this failure to manifest itself.
I also tried yesterday turning off the wifi connection and turning it back on again before trying to change TV channels, with this action taken, the first time TV channel change after overnight "sleep" had no problems.
(2016-11-18, 05:34)gendo Wrote: [ -> ]
That fixed it Smile
I've uploaded a new debug-enabled build #1118x which includes the rtmp fix from last night's build, just in case the channel change crash only happens once the first bug is fixed! RPi2 - can you upload a crashlog from build #1118x, thanks.
(2016-11-18, 08:36)Solomalee Wrote: [ -> ]
Please do me the courtesy of using the test builds in this thread if you're reporting problems in this thread.
Problems with 7.90.008 or any other build should be reported on the LibreELEC forum.
(2016-11-18, 08:50)Milhouse Wrote: [ -> ]
(2016-11-17, 20:12)Milhouse Wrote: [ -> ]Thanks, will include this in tonight's build.
That fixed it Smile
here is crashlog with updated build http://sprunge.us/XaZP
the crash is now in core and not in the add-on. it unconditionally derefs a nullptr for the player. this code is broken. DVDInputStreamPVRManager will call CloseAndOpen(). In Close() the m_pPlayer pointer is nulled. Guess what happens in Open() which is called right after it.
fix submitted 10952 (PR)
(2016-11-15, 00:40)MikeKL Wrote: [ -> ]
(2016-10-24, 23:21)MikeKL Wrote: [ -> ]
(2016-10-21, 23:51)MikeKL Wrote: [ -> ]kodi crash after 1st boot of #1021 Kodi crash debug log
kodi crash after 1st boot of #1024, Kodi crash debug log
Kodi crash after 1st boot of #1113, Kodi crash debug log
Ref "ERROR: SQL: [TV29.db] SQL error or missing database" in log
"rm -f /storage/.kodi/userdata/Database/TV29.db" has been commented out of my autostart.sh for almost all build install/boots since #1024 with no 1st boot crash issues. (Thought Improved stablity at 1st boot might be due to recent PVR epg fixes)
Kodi crash after 1st boot of #1117 Kodi crash debug log Note verbose libcurl logging enabled in dbug logging, TV29.db removed prior to kodi startup with autostart.sh
New LibreELEC.tv Krypton build #1118: RPi / RPi2
# uname -a
Linux rpi512 4.8.8 #1 Fri Nov 18 21:04:42 GMT 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161118210338-#1118-g4ee20e8 [Build #1118]
# Kodi version
(17.0-BETA6 Git:670ca96). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (4ee20e8c, changelog) and tip of XBMC master (670ca967, changelog) with the following modifications: Build Highlights:
  1. Fix channel change crash
  2. Bump bluez to 5.43
  3. Change Samba allocation roundup size, enable strict allocation
Build Details:
  1. LibreELEC.tv:
    • build fixes (PR:937, 1 commit, 1 file changed)
    • Revert "inadyn: disable autoreconf" (PR:942, 1 commit, 1 file changed)
    • autoreconf fixes (PR:939, 2 commits, 1 file changed)
    • script: create_docker_package (PR:864, 1 commit, 8 files changed)
    • scripts/checkdeps: check for distro specific packages (PR:943, 1 commit, 1 file changed)
  2. XBMC:
    • [cmake] Crossguid offline url override (PR:10948, 1 commit, 1 file changed)
    • [python] update setInfo() documentation (PR:10935, 1 commit, 1 file changed)
  3. peripheral.joystick:
    • Fix loss of control if A becomes unmapped (PR:65, 2 commits, 5 files changed)
  4. pvr.filmon:
    • Change user agent as filmon was blocking old one (PR:56, 1 commit, 3 files changed)
  5. newclock5:
      • temp: Add spammy logging to track down seek delays pt3 (f1015f4b)
      • fixed: do not null player pointer on Close (546e2c96)
      • changed: drop passing string as const char* (e4fbf383)
      • Revert "temp: Add spammy logging to track down seek delays pt3" (7f07f162)
  6. kernel 4.8.y:
      • ARM: dts: Visit overlays subdir unconditionally (ea6eeaff)
  7. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:947: connman: remove unneeded patch
    • Added: [env] PR:948: bluez: updated to 5.43
    • Added: [env] PR:951: samba: fix allocation/size on disk issues reported by Windows 8.x+
Just checked #1118 with pvr.filmon enabled and stopping and switching between channels is working fine now.
(Thanks to those working together quickly on fix)
(2016-11-19, 00:24)MikeKL Wrote: [ -> ]Just checked #1118 with pvr.filmon enabled and stopping and switching between channels is working fine now.
yes its is.. only thing i have missing is epg data, which i believe used to show up before.. do you have epg for filmon channels?
(2016-11-19, 06:49)gendo Wrote: [ -> ]
Agreed epg data is now missing, where as far as I can recall it was working fine prior to recent filmon api changes. Initial pvr.filmon channel loading/re-loading faster now Wink
(2016-11-18, 08:55)Milhouse Wrote: [ -> ]Please do me the courtesy of using the test builds in this thread if you're reporting problems in this thread.
Apologies - I didn't realise I was posting in the wrong place. Test Build ≠ Beta Test Blush
Solo
Since build #1115 I've have an issue with pvr recordings.
In Kodi I have grouping turned on for pvr recordings. Since build #1115 all records in sub,sub-folders/groups disappears.
For series I create a chanel folder and seriesname as subfolder of channel. So I got a folder structure for example like this '[Chanelname]/[Seriesname]/[Episode.mkv]'. But since #1115 i don't see any series folder/group in Kodi.
When I disable grouping in Kodi I see all recordings.
May be "[PVR] Fix recordings url encoding. (PR:10930, 2 commits, 5 files changed)" or "Json fixes (PR:10927, 2 commits, 4 files changed)" is affecting this issue.
As PVR backend i'm on Tvheadend 4.1-2322~g879d532
May be some one can investigate this behavior?
