Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
@grisia yes, most likely PR10930. Can you provide a screenshot of what you see in #1114, and a screenshot of what you now see with #1115+ ?
I have many problems with latest build and tvheadend.
It fails sometimes indicating no signal. Has anyone had this problem?
I dont know the correct combination, but two weeks ago, works perfectly!
Regards.
@ezar have you installed the latest tvheadend42 from the add-ons folder (see "addons" link at bottom of first post in this thread).
hey,
now that https://github.com/raspberrypi/firmware/issues/676 is fixed i still notice a very slow ui while watching live tv compared to a sd card boot.
cpu ram usage seems like on sd card and mpg2 codec is enabled aswell.
(2016-11-15, 13:49)popcornmix Wrote: [ -> ]
(2016-11-12, 19:03)Vimes Wrote: [ -> ]I too have been trying to find something repeatable, like you note. As yet I haven't been able to. Last night it happened, the video paused for a few seconds and the audio continued and then the video starts starts back up, jumping to be in sync with the sound.
For ages I thought that it was kinda unique to my system as I searched for "pauses" and not "stutter". I'm not drawing comfort that others can be affected but perhaps that might increase the chances of one of us capturing a meaningful log for the Devs to look at.
Dave's issue involved a:
"ERROR: CMMALVideo::GetPicture - called but m_output_ready is empty"
in kodi.log - does yours?
I've had a closer look at the code around there and have tweaked something that looked suspicious.
As I can't reproduce on demand it's hard to say if it has helped, but let me know if you think latest build is any better.
You probably fixed it. I saw this issue irregular but found it also quite often in the log files.
I did a
grep -i "m_output_ready" .kodi/temp/*
daily.
WARNING: Decoder Error getting videoPicture.
Haven't seen the issue nor above error message in versions since your post. Smile
After some testing , i noticed that the daisuki streams needs sometimes several tries of playback.
Example: Episode 6 from Dagashikashi
14:00:30.253 T:1961763664 INFO: CheckIdle - Closing session to http://www.daisuki.net (easy=0x5701b6a0, multi=(nil))
14:00:40.201 T:1740632992 ERROR: ffmpeg[67BFF3A0]: [crypto] Unable to open resource: http://bngn-vh.akamaihd.net/i/43383936/3...2fAQ%3d%3d
14:00:40.202 T:1740632992 ERROR: ffmpeg[67BFF3A0]: [hls,applehttp] Error when loading first segment 'http://bngn-vh.akamaihd.net/i/43383936/35470338/smil/US/00032/953275578668225.smil/segment1_6000000_av.ts?null=0&id=AgDYvZ3fAhYILtpMMFi9jfmCE14IhtI8d7rLKDoDcFzxeoZHwtbk1bSci6uEH4xkhk+GmLYzoh2fAQ%3d%3d'
14:00:40.217 T:1740632992 DEBUG: Error, could not open file https://bngn-vh.akamaihd.net/i/43383936/...2938708654
14:00:40.217 T:1740632992 ERROR: OpenDemuxStream - Error creating demuxer
After three tries of playback, the episode started. Complete Debug Log: http://sprunge.us/TdIa . Works fine with Kodi 16.1 on my Notebook.
I've updated to the newest build and now there is a problem on boot.
"Add-on migration in progress - please wait..."
This takes almost 1 hour right now.
Is this normal?
Edit: Solved
Chroma Add-on was the problem
(2016-11-19, 13:38)Milhouse Wrote: [ -> ]@ezar have you installed the latest tvheadend42 from the add-ons folder (see "addons" link at bottom of first post in this thread).
Yes. I used last addon build.
(2016-11-19, 15:07)ElectricPim Wrote: [ -> ]Haven't seen the issue nor above error message in versions since your post. Smile
Good to hear.
(2016-11-19, 16:24)ezar Wrote: [ -> ]
Not really sure. You should post a debug log and "journalctl -a" (or post same on the tvheadend forum, if it's a tvheadend specific issue).
If screenshots make the issue any clearer, they would be welcome too. Maybe someone will recognise what the issue is and suggest a solution or PR a fix.
Since build #1115 I've have an issue with pvr recordings.
In Kodi I have grouping turned on for pvr recordings. Since build #1115 all records in sub,sub-folders/groups disappears.
For series I create a channel folder and seriesname as subfolder of channel. So I got a folder structure for example like this '[Chanelname]/[Seriesname]/[Episode.mkv]'. But since #1115 i don't see any series folder/group in Kodi.
When I disable grouping in Kodi I see all recordings.
May be "[PVR] Fix recordings url encoding. (PR:10930, 2 commits, 5 files changed)" or "Json fixes (PR:10927, 2 commits, 4 files changed)" is affecting this issue.
As PVR backend i'm on Tvheadend 4.1-2322~g879d532
Build #1114 Recordings
Recodings overview
Subgroup "Disney Jr."
Subgroup "Disney Jr./Wunderhaus"
Build #1115 Recordings
Recodings overview
Subgroup "Disney Jr." with missing sub/subgroups
(2016-11-19, 23:08)grisia Wrote: [ -> ]Hi,
Thanks, the screenshots help make it clearer. Hopefully a Kodi developer knows what is happening. Pinging @ksooo as the last person to try and fix this with PR10930.
New LibreELEC.tv Krypton build #1119: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.9 #1 Sat Nov 19 21:04:16 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Nov 19 2016 19:49:42
Copyright (c) 2012 Broadcom
version af95a294891b6ca0d369ffb1cabcc3f6c53489ca (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161119210315-#1119-g653bc14 [Build #1119]
# Kodi version
(17.0-BETA6 Git:da57020). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (653bc14d, changelog) and tip of XBMC master (da570207, changelog) with the following modifications: Build Highlights:
  1. New firmware - updates for frambebuffer, debug_sym and deinterlace
  2. New 4.8.9 kernel
Build Details:
  1. Firmware (Nov 19):
    • next: Update to latest master branch
    • firmware: h264: Calculate interlace state more like ffmpeg. See: link
  2. LibreELEC.tv:
    • cleanup: remove for real out of tree projects and options file, featu… (PR:952, 1 commit, 3 files changed)
    • Hyperion fix build, update protobuf, bump version (PR:950, 3 commits, 4 files changed)
    • steamcontroller: initial add-on (PR:944, 3 commits, 11 files changed)
    • busybox: update to busybox-1.25.1 (PR:953, 1 commit, 2 files changed)
    • bluez: updated to 5.43 (PR:948, 1 commit, 1 file changed)
    • connman: remove unneeded patch (PR:947, 1 commit, 1 file changed)
    • pvr.filmon: Change user agent as filmon was blocking old one (PR:946, 1 commit, 1 file changed)
    • linux: update to linux-4.8.9 (PR:956, 4 commits, 31 files changed)
    • inputstream.rtmp: update to add-on version 1.0.2 (54fb7d11)
  3. XBMC:
    • [binary-addons] Rename DEPENDS_PATH to ADDON_DEPENDS_PATH (PR:10865, 1 commit, 9 files changed)
    • Fix 100% cpu usage after a while while scanning for peripheral events (PR:10921, 2 commits, 5 files changed)
    • Fix episode selection when entering a show from the homescreen (PR:10845, 1 commit, 2 files changed)
    • Controller dialog fixes and code improvements (PR:10932, 5 commits, 11 files changed)
    • [PVR][Estuary] Recordings window: show status for recordings in progress (PR:10954, 1 commit, 4 files changed)
    • Fix crash in PVR input streams (PR:10952, 2 commits, 2 files changed)
    • [dxvahd] Re-init video context before creating an enumerator. (PR:10920, 3 commits, 2 files changed)
    • guilib: fix segfault caused by not protected method CGUITextureManage… (PR:10956, 1 commit, 1 file changed)
    • [PVR] Recordings window: Fix show status for recordings in progress (PR:10959, 1 commit, 3 files changed)
  4. inputstream.rtmp:
    • Update version after do not close non-existent session (PR:12, 1 commit, 1 file changed)
  5. newclock5:
    • Commits no longer in build:
      • fixed: do not null player pointer on Close (546e2c96)
      • changed: drop passing string as const char* (e4fbf383)
  6. kernel 4.8.y:
      • Merge pull request #1717 from notro/bcm270x-rip-1 (9fce3365)
i use on Windows 10 "TinghtVNC" for connect to Raspberry
since the #1116 is VNC broken
Connection to #1115 works
on #1116, 1117, 1118 and the last #1119 not working.
I see in the log(raspberry) nothing.
Windows error..
from Germany text to English translate Wink
"No connection could be established because the target computer refuses the connection"
I have neither changed on PC or Raspberry, only updated you firmware.
(2016-11-20, 01:04)kampfi Wrote: [ -> ]i use on Windows 10 "TinghtVNC" for connect to Raspberry
Whatever add-on you installed on your RPi to enable VNC is most likely in need of an update (my guess, broken SSL).
Updated Krypton addons based on gcc-6.2.0 and LibreSSL 2.4.4 are being prepared and will appear in the LibreELEC repository in the next few days. In the meantime I suggest you roll back to #1115 if you need VNC.
