2016-11-24, 08:53
(2016-11-24, 01:26)Aux_ Wrote: [ -> ]New skin, as I click the main window -> Addons -> Install from zip nothing happens
This is a known issue. => https://github.com/phil65/skin.estuary/issues/9
(2016-11-24, 08:43)ksooo Wrote: [ -> ]@grisia how do you rename the folders? Ofc you know that it's not enough to just rename them on the disk and that you additionally have to manually edit tvheadend's internal dvr database (a set of json files)? And after this you have to restart tvheadend.
12:50:08.718 T:1001386912 ERROR: CVideoPlayerAudio::DecodeFrame - Decode Error. Skipping audio packet (-1094995529)
12:50:34.164 T:1923085216 ERROR: Previous line repeats 2 times.
12:29:03.866 T:1700938656 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:33
12:30:05.729 T:1961603072 NOTICE: NFS is idle. Closing the remaining connections.
12:30:40.440 T:1961603072 NOTICE: Samba is idle. Closing the remaining connections
12:33:47.433 T:1254990752 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
12:38:26.694 T:1709327264 WARNING: CSkinInfo: failed to load skin settings
12:38:26.760 T:1961603072 ERROR: Window Translator: Can't find window videolibrary
12:38:26.761 T:1961603072 WARNING: Label Formating: $VAR[GlobalFanartVar] is not defined
12:38:26.843 T:1961603072 ERROR: Control 1000 in window 13001 has been asked to focus, but it can't
12:38:26.846 T:1961603072 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'default/bg.jpg'
12:38:33.199 T:1923085216 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:1102)
12:38:51.403 T:1254990752 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
12:40:43.745 T:1961603072 NOTICE: VideoPlayer: Opening: pvr://channels/tv/Alle Kanäle/pvr.iptvsimple_1262629749.pvr
12:40:43.745 T:1961603072 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
12:40:43.747 T:1127216032 NOTICE: Creating InputStream
12:40:45.849 T:1127216032 NOTICE: Creating Demuxer
12:40:45.961 T:1127216032 NOTICE: Opening stream: 1 source: 256
12:40:45.962 T:1127216032 NOTICE: Creating video codec with codec id: 28
12:40:45.962 T:1127216032 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
12:40:45.963 T:1127216032 NOTICE: Creating video thread
12:40:45.963 T:1055462304 NOTICE: running thread: video_thread
12:40:45.963 T:1127216032 NOTICE: Opening stream: 4 source: 256
12:40:45.963 T:1127216032 NOTICE: Finding audio codec for: 86019
12:40:45.964 T:1127216032 NOTICE: Creating audio thread
12:40:45.965 T:1127216032 NOTICE: Opening stream: 0 source: 256
12:40:45.965 T:1001386912 NOTICE: running thread: CVideoPlayerAudio::Process()
12:40:45.965 T:1127216032 NOTICE: waiting for teletext data thread to exit
12:40:45.967 T:1127216032 NOTICE: Creating teletext data thread
12:40:45.967 T:992998304 NOTICE: running thread: CDVDTeletextData
12:40:45.993 T:1127216032 NOTICE: Opening stream: 1 source: 256
12:40:45.993 T:1127216032 NOTICE: Creating video codec with codec id: 28
12:40:46.004 T:1127216032 NOTICE: Opening stream: 4 source: 256
12:40:46.004 T:1127216032 NOTICE: Opening stream: 0 source: 256
12:40:46.026 T:1001386912 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
12:40:46.253 T:1961603072 NOTICE: Display resolution ADJUST : 1920x1080 (1920x1080) @ 50.00 - Full Screen (52) (weight: 0.000)
12:40:47.287 T:1055462304 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
12:40:54.547 T:1961603072 WARNING: Previous line repeats 2 times.
12:40:54.547 T:1961603072 NOTICE: Display resolution ADJUST : 1920x1080 (1920x1080) @ 50.00 - Full Screen (52) (weight: 0.000)
12:42:14.288 T:1961603072 NOTICE: Samba is idle. Closing the remaining connections
12:46:23.050 T:1923085216 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:1200)
12:50:08.717 T:1001386912 NOTICE: Previous line repeats 1 times.
12:50:34.165 T:1923085216 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:1200)
12:58:49.099 T:1961603072 NOTICE: Previous line repeats 1 times.
12:58:49.099 T:1961603072 NOTICE: CVideoPlayer::CloseFile()
12:58:49.099 T:1961603072 NOTICE: VideoPlayer: waiting for threads to exit
12:58:49.541 T:1127216032 NOTICE: CVideoPlayer::OnExit()
12:58:49.541 T:1127216032 NOTICE: Closing stream player 1
12:58:49.541 T:1127216032 NOTICE: Waiting for audio thread to exit
12:58:49.602 T:1001386912 NOTICE: thread end: CVideoPlayerAudio::OnExit()
12:58:49.603 T:1127216032 NOTICE: Closing audio device
12:58:49.668 T:1055462304 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
12:58:50.081 T:1127216032 WARNING: Previous line repeats 2 times.
12:58:50.081 T:1127216032 NOTICE: Deleting audio codec
12:58:50.081 T:1127216032 NOTICE: Closing stream player 2
12:58:50.081 T:1127216032 NOTICE: waiting for video thread to exit
12:58:50.082 T:1055462304 NOTICE: thread end: video_thread
12:58:50.083 T:1127216032 NOTICE: deleting video codec
12:58:50.088 T:1127216032 NOTICE: Closing stream player 4
12:58:50.088 T:1127216032 NOTICE: waiting for teletext data thread to exit
12:58:50.088 T:992998304 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
12:58:50.088 T:992998304 NOTICE: thread end: data_thread
12:58:50.655 T:1961603072 NOTICE: VideoPlayer: finished waiting
12:58:50.831 T:1961603072 NOTICE: CVideoPlayer::CloseFile()
12:58:50.831 T:1961603072 NOTICE: VideoPlayer: waiting for threads to exit
12:58:50.831 T:1961603072 NOTICE: VideoPlayer: finished waiting
12:58:54.289 T:1254990752 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
12:58:57.950 T:992998304 WARNING: CSkinInfo: failed to load skin settings
12:58:58.016 T:1961603072 ERROR: Window Translator: Can't find window videolibrary
12:58:58.016 T:1961603072 WARNING: Label Formating: $VAR[GlobalFanartVar] is not defined
12:58:58.094 T:1961603072 ERROR: Control 1000 in window 13000 has been asked to focus, but it can't
12:58:58.096 T:1961603072 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'default/bg.jpg'
12:59:02.533 T:1923085216 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:1102)
(2016-11-23, 18:05)popcornmix Wrote: [ -> ](2016-11-23, 18:01)hanspeter Wrote: [ -> ]same behavior also with the bootcode.bin from #1119, freezes with 614M. Is this expected, or is the memtester freezing with a large value already a symptom of this problem...?
I think the freezing is something else. memtester locks the memory and if there is too little remaining linux struggles to run.
I believe I got that and did a control-c and left it for a while it response did return.
I'm more interested in using a lower number such that the test does run, but reports corruption.
(2016-11-24, 01:50)Milhouse Wrote: [ -> ](2016-11-23, 21:34)doldi Wrote: [ -> ]But with mouse i can not handle my files in a folder - if there are more than 20 single files i have no chance for a selection - scroll down or up is to fast :-)
Do you still have this mouse problem with tonight's #1123 build (in case it's a kernel 4.9-rc6 related issue)? Assuming you do, then it's probably best to report it in the Estuary forum as a usability issue.
(2016-11-24, 15:40)hanspeter Wrote: [ -> ]Ran for >12hrs, no errors. I also could not find any way to provoke the crash... Do you have any ideas what the root-cause could be? If you suspect a (hardware) memory problem, would overclocking the memory to an unstable value maybe provoke it...? Or what about running memtester while kodi is running?
(2016-11-24, 17:59)popcornmix Wrote: [ -> ](2016-11-24, 15:40)hanspeter Wrote: [ -> ]Ran for >12hrs, no errors. I also could not find any way to provoke the crash... Do you have any ideas what the root-cause could be? If you suspect a (hardware) memory problem, would overclocking the memory to an unstable value maybe provoke it...? Or what about running memtester while kodi is running?
I hardware issue seemed possible when only you had a problem. As gendo also saw a similar crash, then a hardware issue is less likely.
Most likely the arm is trying to access memory in the top 16M of address space. This should be used by the GPU but there may be a situation I'm missing,
If I could reproduce this then diagnosing it would be easier.
As total_mem=1008 works and total_mem=1024 (the default if unspecified) doesn't work, it may be interesting to see what the threshold is.
E.g. Try total_mem=1016. If that seems good try total_mem=1020, and if not try total_mem=1012.
If you get a crash where ssh still works, then dmesg output may be useful.
After a reboot then .kodi/temp/kodi.old.log may be useful if it shows what was going on from just before the crash.
(2016-11-24, 19:08)gendo Wrote: [ -> ]Nothing in old log.. funny thing is i have 2 x RPi2 1 hangs 3 -4 times a day whilst the other one is rock solid.. both have libreelec on usb drive... but the one that crashes has a usb DVB-t tuner and runs at 720p resolution
both are Pi2 Model B rev 1.1, BCM2836 SoC with 1GB RAM by Sony (reported by bcmstat)
<advancedsettings>
<pvr>
<!-- <minvideocachelevel>40</minvideocachelevel> -->
<!-- <minaudiocachelevel>40</minaudiocachelevel> -->
</pvr>
<network>
<disableipv6>true</disableipv6>
</network>
<cache>
<buffermode>1</buffermode>
<memorysize>157286400</memorysize>
<readfactor>10</readfactor>
</cache>
<videolibrary>
<cleanonupdate>true</cleanonupdate> <!-- Also clean library during library update -->
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
<videoscanner>
<ignoreerrors>true</ignoreerrors> <!-- Silently ignore errors while scanning videos. -->
</videoscanner>
<video>
<timeseekforward>15</timeseekforward> <!-- Skip back time 15 s -->
<timeseekbackward>-15</timeseekbackward> <!-- Skip forward time 15 s -->
</video>
</advancedsettings>
(2016-11-24, 19:23)popcornmix Wrote: [ -> ](2016-11-24, 19:08)gendo Wrote: [ -> ]Nothing in old log.. funny thing is i have 2 x RPi2 1 hangs 3 -4 times a day whilst the other one is rock solid.. both have libreelec on usb drive... but the one that crashes has a usb DVB-t tuner and runs at 720p resolution
That's the sort of information that could be interesting.
I can't currently think of a reason why the DVB tuner or 720p resolution would cause the crash.
However if you were to report, say, that switching the good Pi to 720p made it unreliable then that would be even more interesting.
(2016-11-24, 19:43)SpokV Wrote: [ -> ]For some reason I get screen resolution with big icons and fonts and it looks scaled out.
(2016-11-24, 23:47)Milhouse Wrote: [ -> ](2016-11-24, 19:43)SpokV Wrote: [ -> ]For some reason I get screen resolution with big icons and fonts and it looks scaled out.
Can you post a screen shot? It might be how it's supposed to look...
