Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
watch gallery
We have twice LibreElec in System?
btw: screenshot do not work now in this newer builds like:
http://192.X.X.X:8082/jsonrpc?request={ "jsonrpc": "2.0", "id": 1, "method": "Input.ExecuteAction", "params": { "action": "screenshot" }}
THX for answers
Harald
(2016-11-26, 12:57)doldi Wrote: [ -> ]We have twice LibreElec in System?
Known issue, even mentioned in the release notes...
(2016-11-26, 12:57)doldi Wrote: [ -> ]btw: screenshot do not work now in this newer builds like:
THX for answers
Harald
This is working for me... can you double check and post a debug log?
hi milhouse, next problem:
settings/Skin/config ->Thema : chance curial or flat - RPi will rebot after shown a grey baar instead mouse-
arrow...
RPI make a reboot without chancing anything of settings and i have no mouse.
about screenshot - works over browser - have put them into ssh :-p
#1119 is good for me
(2016-11-26, 12:25)marty29ak Wrote: [ -> ]
Quote:Same here. 3 crashes last 3 hours on #1124
All is stock, no overclock. CPU temp reached 75 degrees C for the first time since i have the RPi3 on idle.
Now updated to #1125
The problem is also in the version # 1125 yet.
Have three RPI 3 all have the same problem.
I am not crashing but I am running much hotter. When the temp alarm started appearing, I added some cooling. I have stuck a small heat sink on the CPU and opened the case.. Even so I am running about 64 degrees C. I am sure without the heat sink and with the lid closed I would beat your 75 degrees C. I don't know at what temp the speed rolls back, but I have been scanning my music folder for 10 hours. It usually takes an hour.
LibreELEC (community) Version: devel-20161119210316-#1119
pi3:~ # vcgencmd measure_temp
temp=50.5'C
pi3:~ # vcgencmd measure_clock arm
frequency(45)=600000000
pi3:~ # vcgencmd measure_volts
volt=1.2000V
Hi, marty29ak & bill_orange
i'm back to #1119 (because skin) and i have here a little bit more temp (+4°C)as in the latest build, but always ok.
RPi3 works in a aluminium case, heatsink selfmade and bond with special adhesive.
watch gallery
...with standart (no) overclocking. Have a look to your powersupply
I am not able to activate bluetooth, could not find an entry via services. I have the build from today: LibreELEC-RPi2.arm-8.0-Milhouse-20161125210425
(2016-11-26, 18:14)Happysporti Wrote: [ -> ]I am not able to activate bluetooth, could not find an entry via services. I have the build from today: LibreELEC-RPi2.arm-8.0-Milhouse-20161125210425
milhouse already mentioned bluetooth not working in #1125 release, earlier today here with comment will be fixed in tonights #1126 build
There seems to be no way to change Estuary background to custom wallpaper...
(2016-11-26, 18:00)doldi Wrote: [ -> ]LibreELEC (community) Version: devel-20161119210316-#1119
temp=50.5'C
volt=1.2000V
watch gallery
I added a little heat sink I used to have on a PI2 (which I sold on eBay for what I paid for it) before upgrading to PI3. It not a big as yours.
My Music Library scan was trudging onward slowly so I cooled the CPU with a little Freon, dropping the temp to 90 F. The scan was done in less than an additional hour.
I have a 2A supply. Clearly something happened around build #1119 that upped the CPU load. I am not sure which build exactly since normal use does not create the excess temp in my situation. Scanning to the library sure does.
ok, bill orange - mine is not so big lol...
but i have to testing in that case 2 RPi's (2/3) with identical 2,5 Amp powersupplies.
Do you know somthing about eBääh devices - hmm, i don't know.
2 pices from Rpi i have but in waste for sometimes...hour over hour i'm searching and searching...you know?
This Rpi was bought as new from RS-online here in germany....from Angelika lol
Here's an odd issue. Can anyone reproduce it? Cleaning the music library just once and rebooting does nothing. I have to clean and reboot twice. Once this is done, I am always left with one entry that will not clean away no matter how many reboots are used. It get weirder. If I go to Music > Artist most displayed artists are wrong. That last remaining artwork is displayed in the left field. I have reproduced this on two PIs.
hi bill_orange,
i'm scanning now my libary and start with :
temp=58.5'C
after 5 min.
the highest temp is :
temp=68.8'C
after 30% of doing the job in my mp3 Folder (20.970 Dateien, 1.429 Ordner) highest Temp.
after them the temp is toogle down and high to max.
(2016-11-26, 11:32)dsenseb Wrote: [ -> ]
(2016-11-21, 23:32)hanspeter Wrote: [ -> ]This one freezes (ssh and serial-console dead, log stops), with random colored noise on the screen, not reproducable, sometimes while playing video, sometimes while idle with black screensaver on; happened six or seven times in the last 18h...
I've still not seen this issue.
I was hoping that leaving it in place a few days might result in some information to help reproduce the issue.
But, as we don't seem to be getting there I've reverted the change.
You can manually enable the extra 16M with total_mem=1024 in config.txt if you weren't having issues.
(2016-11-25, 07:28)Milhouse Wrote: [ -> ]
(2016-11-25, 06:54)MrSliff Wrote: [ -> ]Same problem here, just tried it again with that Stream Milhouse. It freezes.
So it's not currently crashing as originally claimed? Just want to be clear on that, as it's a rather important point.
(2016-11-25, 06:54)MrSliff Wrote: [ -> ]So with the above command in ssh i get a forced crashlog?
Yes:
kill -SIGSEGV $(pidof kodi.bin)
will crash kodi.bin, and you should then have a crashlog that you can upload.
(2016-11-25, 06:54)MrSliff Wrote: [ -> ]Where will i find the crash log?
See note #4 in the first post. Upload the crashlog to a pastebin site, then paste the link here.
(2016-11-25, 06:54)MrSliff Wrote: [ -> ]Edit:
Found this in your crashlog, just overflew it:
00:52:09.846 T:1784619936 WARNING: CreateLoader - unsupported protocol(playmedia("http) in playmedia("http://relay1.hirschmilch.de:7100/chillout.tbn
Maybe thats the problem?
No, that warning is related to the new skin and should not have any bearing on this issue.
So ive just tried to start the Stream again, just a minute of freeze now. Force-Crashed Kodi and took a look in the Kodi.log file, but there are only logs until approx 1 hour before i force crashed.
Cant post the log with pastebin, its too big for it (512kb).
edit: Oh made a mistake... The log has an 1 hour offset back.reviewed a new log, no changes to the log before. Looks like same informations.
Since its too big for Pastebin, here the logfile for Download: https://www.dropbox.com/s/hv5zvqiulb441u...I.log?dl=0
