For quite some time now, maybe even from the beginning, I need to disable and re-enable AirPlay every time after a reboot. If I don't, it will be visible to my phone, but it will immediately disconnect when I start a song. I have video support disabled (for iOS 9 compatibility). I don't know if it's in any way related, but I'm using a HiFiBerry DAC. I'm used to it and it doesn't really pose a problem for me, but if more people are experiencing the same issue, I guess it must be fixed eventually. Any ideas?
(2016-05-03, 17:29)Milhouse Wrote: [ -> ] (2016-05-03, 16:45)polo_joe Wrote: [ -> ]The repo is still empty for me.
http://sprunge.us/bBcb
Have you rebooted? Unfortunately this is down to Kodi caching - it will be populated eventually.
today it works, thanks much!
(2016-05-03, 13:59)popcornmix Wrote: [ -> ] (2016-05-02, 20:24)zed200 Wrote: [ -> ]In he last version of Openelec Milhouse Build (8.0) I can not find the option "Accelerated playback speed".
Did this option disappear ?
Yes, it was dropped due to lack of feedback.
I have added it back in, so should be in tonight's Milhouse LE build. (But note there will be no more Milhouse OE builds).
"Accelerated playback speed" is back thank you.
What would be perfect is to adjust the pitch according to speed but I guess it's not so easy.
I'm already glad that this feature exists.
#0503 build fix small issues in Live-TV channel switching using DVB-C and VDR. Zapping is now working normal again.
For me this build is almost a perfect TV setup-box.
Thank you very much for all the great effort to everybody who is working on Rpi, *ELEC, Kodi, VDR, Hyperion and all the SW around this great media center. Its just amazing
(2016-05-04, 21:49)herrmeier01 Wrote: [ -> ]#0503 build fix small issues in Live-TV channel switching using DVB-C and VDR. Zapping is now working normal again.
Good to hear. Can you confirm if #0503 fixed an issue that was present in #0502? (or just from an older build)
There wasn't an obvious fix in #0503, and it's useful to know which changes fix which bugs (to make sure they don't recur).
Beginning with build #0501 Quasar stopped working. The daemon starts, all seems OK, but when it comes to downloading something Kodi freezes and it needs a hard reboot.
It worked fine in builds previous to #0501.
Log
http://xbmclogs.com/pggc3jcu2
Yes, I confirm that #0503 fixed an issue which was present in #0502. It was a problem which started some time ago.
With each channel switch audio was present first, then the video and after that there was a short time a black screen and then the TV was running fine.
(2016-05-04, 23:00)herrmeier01 Wrote: [ -> ]Yes, I confirm that #0503 fixed an issue which was present in #0502. It was a problem which started some time ago.
Interesting. Probably one of these:
mmalrenderer: Avoid creating presenting thread when it is not required (1075e96e)
RenderManager: Inform renderer even when display refresh matches (f6d364d1)
RenderManager: Disable vsync adjust - it causes unpleasant glitches after seeking (bd4ec64e)
I'd quite like to know which one. I might try reverting these one by one as a test over the next few nights.
If you can keep an eye out, and report if the problem returns, that would be helpful.
hi, wonder if its possible add some more information about what file we are watch, ex: 720 or 1080? on my file mkv, in estuary i have on metadata info 5.1, dolby, 2.40:1 ,h264, in confluence we have audio (eng), subtitle (eng, ita, etc)
OK, let us proceed like this
(2016-05-04, 22:54)Kiralina Wrote: [ -> ]Beginning with build #0501 Quasar stopped working. The daemon starts, all seems OK, but when it comes to downloading something Kodi freezes and it needs a hard reboot.
Log http://xbmclogs.com/pggc3jcu2
Sorry still haven't got around to looking into this... if anyone else beats me to it that would be nice.
New LibreELEC.tv Krypton build #0504:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.0-rc5 #1 Wed May 4 21:33:11 BST 2016 armv6l GNU/Linux
# vcgencmd version
May 3 2016 17:47:44
Copyright (c) 2012 Broadcom
version b870a5bbf6c662327916ee582c22309c9f997b3d (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160504213208-#0504-gbc45a62 [Build #0504]
# vcdbg log msg 2>&1 | grep DTOK
002467.744: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (bc45a620,
changelog) and tip of
XBMC master (afab40a0,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest bcm2835-driver master (6832d9a4, ahead +8)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (b3c41060, ahead +15)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (5cf12e83), adsp.biquad.filters (af575f3d), adsp.freesurround (6dc533be), asplib (da66f517), inputstream.mpd (2cb2eab2, +2), inputstream.smoothstream (352b14eb, +12), peripheral.joystick (76b7c40a), pvr.argustv (3a4eccd4, +5), pvr.demo (f4950d3d, +1), pvr.dvblink (41a62b12, +1), pvr.dvbviewer (77771ddc, +6), pvr.filmon (0b906770, +1), pvr.hdhomerun (9b511856, +2), pvr.hts (8929c220, +4), pvr.iptvsimple (373b525d, +1), pvr.mediaportal.tvserver (4723f6de, +1), pvr.mythtv (11b70a50, +1), pvr.nextpvr (fa13c7d0, +1), pvr.njoy (aea0b8ab, +1), pvr.pctv (fc80e0f7, +2), pvr.stalker (c1d8ee73, +2), pvr.vbox (31748578, +1), pvr.vdr.vnsi (090ef7e1, +6), pvr.vuplus (ec652b92, +1), pvr.wmc (b1d7a40a, +1)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Default double buffered
- Include [env] patch: Drop repo hack (not needed after PR9642)
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Add experimental splash video for RPi (core dump enabled)
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: Drop readbufferfactor: Category and property names have changed, but we're already using the default value so no need to set anything
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:286: Upstream changes
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9576: [network] improvements to the webserver implementation
- Include [pkg] PR:9723: [OSX] - second try to properly fix apple remote and harmony support, aka - fix the regression of the regression
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- VideoPlayer updates, fix c/p error in RenderManager
- PR:9576: [network] improvements to the webserver implementation
Build Details:
- LibreELEC.tv:
- distro-tool: Workaround packages that call exit (PR:292, 1 commit, 1 file changed)
- docker: update to 1.11.1 (PR:280, 1 commit, 3 files changed)
- tinc: bump to 1.1pre14 (PR:291, 1 commit, 1 file changed)
- dispmanx_vnc: move config to addon (PR:285, 1 commit, 8 files changed)
- dispmanx: bump PKG_REV to 101 (PR:293, 1 commit, 1 file changed)
- XBMC:
- [EPG] CGUIEPGridContainer cleanup, incl. Coverity fix (PR:9743, 4 commits, 3 files changed)
- [cmake] Fix *.cmake files install after 3e19e40 (PR:9741, 1 commit, 1 file changed)
- cmake: Handle generated files in core_add_test correctly (PR:9692, 3 commits, 3 files changed)
- fixed: regression from a00a747b6c1ba633e8d83adcf50f93ce888f65dd (PR:9751, 1 commit, 3 files changed)
- [cmake] Packaging for OSX (PR:9716, 8 commits, 12 files changed)
- [settings] fix linux.xml after ee40239798bf6 (PR:9752, 1 commit, 1 file changed)
- [aml] Fix includes in amcodec/codec.h to make them relative (PR:9745, 1 commit, 2 files changed)
- fix rating / votes infolabels (PR:9740, 1 commit, 1 file changed)
- wrap skin debug info (PR:9722, 1 commit, 1 file changed)
- cosmetics - display correct window name (PR:9737, 1 commit, 1 file changed)
- VideoPlayer: fix c/p error in RenderManager (fb0b2f81)
- newclock5:
- New commits in this build:
- VideoPlayer: drop old fps(reconfigure) workaround (bd4a624a)
- mmalcodec: Set initial aligned height explicitly to avoid multiple reconfigures in renderer (912cb6ac)
- Commits no longer in build:
- mmalrenderer: reduce logging spam for bypass mode (e778dc9a)
- Revert "mmalrenderer: reduce logging spam for bypass mode" (86e12547)
- RenderManager: Inform renderer even when display refresh matches (f6d364d1)
- Added: [env] patch: Drop readbufferfactor: Category and property names have changed, but we're already using the default value so no need to set anything
- Added: [env] PR:286: Upstream changes
- Added: [pkg] PR:9576: [network] improvements to the webserver implementation
(2016-05-04, 23:14)Milhouse Wrote: [ -> ] (2016-05-04, 23:11)pl4tin Wrote: [ -> ]hi, wonder if its possible add some more information about what file we are watch, ex: 720 or 1080? on my file mkv, in estuary i have on metadata info 5.1, dolby, 2.40:1 ,h264, in confluence we have audio (eng), subtitle (eng, ita, etc)
Codec OSD?
thank you for your fast replay i willl try to find something about this codec
(2016-05-04, 23:25)pl4tin Wrote: [ -> ] (2016-05-04, 23:14)Milhouse Wrote: [ -> ]Codec OSD?
Press "o" (letter O) on the keyboard, or map the "CodecInfo" action to a button on your remote control.
