(2016-04-26, 23:45)Milhouse Wrote: [ -> ] (2016-04-26, 23:10)Kiralina Wrote: [ -> ]Here it is: http://xbmclogs.com/pquz55osi
Same behavior with #0423 and #0424
Thank you.
So quasar works with #0420 but not #0423 or #0424. Strange. The only obvious change in #0423 is the libressl change, possibly connman 1.32, but the quasar query isn't https, at least not to the local trakt server.
Quasar does however appear to be crashing due to an invalid/unexpected response from the local trakt server - maybe trakt is having a problem authenticating remotely? I think you need to get the log from the trakt server (if there is such a log), or speak with a trakt/quasar developer (pinging @Razze for trakt).
I've followed the steps in
http://forum.kodi.tv/showthread.php?tid=...pid2321749 and with build LE #0401 I get the authorisation code. Great.
I also get the authorisation code by clicking "Addons" > "Settings" (context menu) > "Advanced" > "Authorize Quasar", and that's my current "test method".
Starting with build LE #0408 I get an HTTP Error. I get this error with all builds after #0408, including #0420.
Build LE #0408 is the first with
PR:128 so unfortunately this looks like another certificate issue.
To see the issue, in LE #0407:
rpi22:~ # curl -v http://localhost:65251/trakt/authorize
* Trying 127.0.0.1...
* Connected to localhost (127.0.0.1) port 65251 (#0)
> GET /trakt/authorize HTTP/1.1
> Host: localhost:65251
> User-Agent: curl/7.48.0
> Accept: */*
< HTTP/1.1 200 OK
< Content-Type: text/plain; charset=utf-8
< Date: Thu, 05 May 2016 17:57:27 GMT
< Content-Length: 0
* Connection #0 to host localhost left intact
but in LE #0408 there is an "internal server error":
> Accept: */*
< HTTP/1.1 500 Internal Server Error
< Date: Thu, 05 May 2016 17:54:53 GMT
< Content-Length: 0
Since Quasar is shipped with a pre-compiled binary it's not possible to tell what it's doing (maybe the code is on Github or Sourceforge, not looked) but it doesn't seem to like the CA bundle that is shipped with LibreELEC.
The nearest I can come to determining what Quasar is doing is that if I recreate "/etc/pki/tls/cacert.pem" (which is no longer present after
PR:128) then Quasar works again even in the latest builds, so it would seem that Quasar has some hard dependency on /etc/pki/tls/cacert.pem (which is just a sym link to /etc/ssl/cacert.pem)
I've had a quick word with the LE team and we'll add back the "/etc/pki/tls/cacert.pm" sym link in tonight's build.
