Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-05-18, 20:37)bite_your_idols Wrote: [ -> ]PD: retroplayer officially integrated in Kodi is our only hope... XD
I did fix up retroplayer on Pi yesterday, and the latest builds here should work.
Am I becoming blind or why cannot I find Settings/Video where used to be Library, Playback, Acceration, File list, Subtitles and DVD?
(2016-05-18, 22:00)Takio Wrote: [ -> ]Am I becoming blind or why cannot I find Settings/Video where used to be Library, Playback, Acceration, File list, Subtitles and DVD?
Not blind, but behind the times. It all changed with PR9208.
(2016-05-18, 22:11)popcornmix Wrote: [ -> ]
Ok. Am I able to find the subtitles setting anywhere?
(2016-05-18, 22:31)Takio Wrote: [ -> ]Ok. Am I able to find the subtitles setting anywhere?
In Player->Language->Subtitles
New LibreELEC.tv Krypton build #0518: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.0 #1 Wed May 18 22:12:30 BST 2016 armv6l GNU/Linux
# vcgencmd version
May 17 2016 17:47:22
Copyright (c) 2012 Broadcom
version 72491c2e16892dd7e2a4e5b253ef499e2b6a028f (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160518221036-#0518-g8635eb0 [Build #0518]
# vcdbg log msg 2>&1 | grep DTOK
002464.310: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (8635eb0c, changelog) and tip of XBMC master (a935d581, changelog) with the following modifications: Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. Fix cmake after PR9750
Build Details:
  1. LibreELEC.tv:
    • Patch bluez to enable DualShock 3 auto pairing (PR:351, 2 commits, 6 files changed)
    • RPi-Tools: add same Adafruit library for LED backpacks (PR:347, 1 commit, 4 files changed)
    • squeezelite: create addon and dependencies (PR:345, 4 commits, 5 files changed)
    • syncthing: version 0.12.24 (PR:358, 1 commit, 2 files changed)
  2. XBMC:
    • [cleanup] - remove some unused stuff from ControlFactory (PR:9822, 2 commits, 1 file changed)
    • [cmake] File renaming for readability (PR:9750, 5 commits, 65 files changed)
    • [osx,ios] Xcode project file cleanup. (PR:9831, 1 commit, 1 file changed)
    • Fix dateadded sort method in AudioLibrary.GetSongs (PR:9809, 1 commit, 2 files changed)
    • [lang][skin.estuary] updated language files from Transifex (c4257929)
    • [lang][skin.estouchy] updated language files from Transifex (f427a959)
  3. libnfs:
    • Remove rpc_set_tcp_syncnt from the nfs-cat utility (00d9ba15)
  4. inputstream.smoothstream:
    • [cmake] Rename find_package(kodi) to Kodi (PR:4, 2 commits, 2 files changed)
  5. pvr.argustv:
    • [cmake] Rename find_package(kodi) to Kodi (PR:58, 2 commits, 3 files changed)
  6. pvr.demo:
    • [cmake] Rename find_package(kodi) to Kodi (PR:37, 2 commits, 2 files changed)
  7. pvr.dvblink:
    • [cmake] Rename find_package(kodi) to Kodi (PR:51, 2 commits, 3 files changed)
  8. pvr.dvbviewer:
    • [cmake] Rename find_package(kodi) to Kodi (PR:41, 2 commits, 3 files changed)
  9. pvr.filmon:
    • [cmake] Rename find_package(kodi) to Kodi (PR:52, 2 commits, 3 files changed)
  10. pvr.hdhomerun:
    • [cmake] Rename find_package(kodi) to Kodi (PR:26, 2 commits, 3 files changed)
  11. pvr.hts:
    • [cmake] Rename find_package(kodi) to Kodi (PR:225, 2 commits, 3 files changed)
  12. pvr.iptvsimple:
    • [cmake] Rename find_package(kodi) to Kodi (PR:81, 2 commits, 3 files changed)
  13. pvr.mediaportal.tvserver:
    • [cmake] Rename find_package(kodi) to Kodi (PR:42, 2 commits, 3 files changed)
  14. pvr.mythtv:
    • [cmake] Rename find_package(kodi) to Kodi (PR:66, 2 commits, 3 files changed)
  15. pvr.nextpvr:
    • [cmake] Rename find_package(kodi) to Kodi (PR:47, 2 commits, 3 files changed)
  16. pvr.njoy:
    • [cmake] Rename find_package(kodi) to Kodi (PR:30, 2 commits, 3 files changed)
  17. pvr.pctv:
    • [cmake] Rename find_package(kodi) to Kodi (PR:39, 2 commits, 3 files changed)
  18. pvr.stalker:
    • [cmake] Rename find_package(kodi) to Kodi (PR:61, 2 commits, 3 files changed)
  19. pvr.vbox:
    • [cmake] Rename find_package(kodi) to Kodi (PR:129, 2 commits, 3 files changed)
  20. pvr.vdr.vnsi:
    • [cmake] Rename find_package(kodi) to Kodi (PR:82, 2 commits, 2 files changed)
  21. pvr.vuplus:
    • [cmake] Rename find_package(kodi) to Kodi (PR:46, 2 commits, 3 files changed)
  22. pvr.wmc:
    • [cmake] Rename find_package(kodi) to Kodi (PR:45, 2 commits, 3 files changed)
  23. newclock5:
    • New commits in this build:
      • VideoPlayerVideo: Need to clear pictures before switching decoder (a6d040e2)
      • mmalrenderer: Keep both pools (4c1f09f1)
      • mmal_renderer: squash: Use shared pointers to maintain the pool until the decoder has been destroyed (83f40b8d)
      • mmalcodec: Use SAFE_RELEASE (4414aca7)
  24. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: Fix cmake after PR9750
    • Added: [pkg] patch: Revert "drm/i915: Exit cherryview_irq_handler() after one pass" (BSW fix) (linux)
    • Added: [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
(2016-05-18, 10:25)Vimes Wrote: [ -> ]
(2016-05-18, 04:52)Milhouse Wrote: [ -> ]
(2016-05-18, 04:00)ragedogg69 Wrote: [ -> ]Just as a data point: #0509 #0516 both give me the busy dialog on widgets in the Estuary Mod skin. Author claims no problems using your builds on his end. #0504 works perfectly fine with the mod. Default Estuary works fine on all your builds.
As pointed out by @Vimes there might be add-ons running in the background causing delays. Some skins install a lot of add-ons by default. My guess would be that these add-ons are triggering/causing small "stutters" in the GUI due to additional locking or busy-waiting. These stutters may be very noticeable on RPi1, and barely noticeable on Core i7, with RPi3 somewhere in between (is the Estuary Mod developer testing on RPi1/2/3, or i7?) All a total guess on my part, of course.
FernetMenta is currently on holiday but will hopefully have some ideas when he gets back (next week, I think).
Further to what I posted I had started to have some issues of stability. Using the virtual keyboard would be slow and not very responsive, taking several keypresses to register a key and then often cause a Kodi reboot. Also I noticed that Kodi was taking more memory to run than usual.
I backed up my library and then started fresh. LibreElec 7 with then a new install of the latest nightly (517). The only addons are the Amazon, Youtube. WOL, Dev Update, and Backup.
Previously I had the Estuary Skin mod and all the addons that were needed, quite a few. Also I had other skins installed, Mimic and Transparency.
With the clean install and no other skins, and addons used by installing them, the virtual keyboard works a treat and all has returned to normal. No lags or stutters etc have been seen so far.
Whether the above could have occurred by a problematic addon or not I do not know, nor have the skill to diagnose, I am just happy that the stability and performance has now returned to what I had priror to skin testing etc.
I'm still having issues with the "working...." busy dialog coming up all the time. I know I'm not supposed to be testing the milhouse builds with other skins, but I've been using the Aeon Nox5: SiLVO skin for absolutely ages without many issues and this is the first real problem I've encountered. Below is a post I just made in the skin thread pertaining to this issue, with the reply from the skin designer below it.
Trixster Wrote:
Hi, sorry if this has been addressed and I've missed it, but I'm having a problem with the skin and a fix to pr#9778 PluginDirectory
I'm using the skin with the latest RaspberryPi builds made by MilHouse. All builds upto 0507 work fine but any builds since which have included pr#9778 have caused major delays with the Silvo skin. The "working...." dialog keeps popping up and slows the UI to a complete crawl with widgets and some addons taking an age to load or work thereafter.
The version of the silvo skin I'm using is 5.9.0-3.0.3 which i assume is the latest build for krypton?
Here is a debug log from just after a reboot having updated to the latest 0518 build.
http://pastebin.com/GDpbHSre
Unfortunately there is nothing I can do about that. It either must be solved in core or all plugins need to updated to use a different method. Seems like we might have to wait for some bickering to subside and a compromise is found. If not the only solution is to completely remove all the good stuff like widgets, autocompletion, extended info integration in DialogVideoInfo. Hopefully it will be solved in the not too distant future without any drastic/complicated changes for all parties of interest.
I agree with the reply from the skin maintainer. This is a core issue, and a solution is yet to be identified. See the ongoing discussion in PR9778.
New LibreELEC.tv Krypton build #0519: RPi / RPi2
# uname -a
Linux rpi512 4.6.0 #1 Thu May 19 21:07:37 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160519210544-#0519-g2f86163 [Build #0519]
002464.975: Kernel trailer DTOK property says yes
Based on tip of LibreELEC.tv master (2f86163b, changelog) and tip of XBMC master (c603f070, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
  • Includes latest bcm2835-driver master (564f73be, ahead +7)
  • Includes latest kodi-platform master (c8188d82, ahead +4)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (00d9ba15, ahead +19)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (29bfe9d8, +3), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (d8f2c50f, +9), inputstream.smoothstream (32275717, +2), peripheral.joystick (ff017ccc, +27), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (d0ef0264, +4), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (4ff1552f, +4), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (dc112316, +6), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
  • Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: xf86-video-intel: bump to 3fafabe
  • Include [env] patch: Fix SIGTERM patch after PR9748
  • Include [env] patch: Fix cmake after PR9750
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Disable -werror as libnfs won't build 32-bit without it
  • Include [env] patch: Enable custom framebuffer resolution
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:353: plymouth-lite: add bilinear interpolation patch
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
  • Include [pkg] patch: Revert "drm/i915: Exit cherryview_irq_handler() after one pass" (BSW fix) (linux)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
  2. Updated LibreELEC Settings add-on - now Estuary compliant.
Build Details:
  1. LibreELEC.tv:
    • LibreELEC-settings: update to latest master (PR:360, 1 commit, 1 file changed)
    • script.moonlight: initial add-on (PR:299, 6 commits, 8 files changed)
    • settings: bump to 0.8.0 (PR:361, 1 commit, 1 file changed)
    • LibreELEC-settings: drop obsolete patch (PR:363, 1 commit, 1 file changed)
    • docker: add kodi notifications (PR:356, 1 commit, 6 files changed)
    • connman: remove temp-fix-kernel-headers-bug patch (PR:365, 1 commit, 1 file changed)
  2. XBMC:
    • [addon] binary add-on library rework for API level system (PR:9659, 11 commits, 476 files changed)
    • [win32][test] Fix linking of the test suite (PR:9810, 1 commit, 2 files changed)
    • Fix using albumartist tag rather than artist (PR:9837, 1 commit, 1 file changed)
    • [linux] redirect stderr when calling lsb_release fixes #16729 (PR:9832, 1 commit, 1 file changed)
    • [cmake] Force Python version to 2.7 (PR:9818, 1 commit, 1 file changed)
    • fix 'unknown sources' setting visibility when opened from dialog (PR:9830, 2 commits, 4 files changed)
    • [network] CWebServer: fix bad log messages (a49f32c3)
  3. newclock5:
      • stereoscopics: Switch to using block_lr for mvc to match makemkv (e6793f95)
    • Added: [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
Thanks Milhouse and the team
Flip eyes for 3D mvc iso is not working in #519. In OSD it reads block_lr (instead of mvc_lr) now.
I guess commit "stereoscopics: Switch to using block_lr for mvc to match makemkv (e6793f95)" is causing this?
(2016-05-20, 12:30)-DH- Wrote: [ -> ]I guess commit "stereoscopics: Switch to using block_lr for mvc to match makemkv (e6793f95)" is causing this?
Indirectly. I've spotted what looks like a typo in the pre-existing "block_lr" handling, that we are now using.
Hopefully this will fix tonight's build.
New LibreELEC.tv Krypton build #0520: RPi / RPi2
# uname -a
Linux rpi512 4.6.0 #1 Fri May 20 21:34:39 BST 2016 armv6l GNU/Linux
# vcgencmd version
May 20 2016 19:05:21
version faf071dd4885c5ac1a89483d35a5326e7f69495f (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160520213240-#0520-ge533f15 [Build #0520]
002470.189: Kernel trailer DTOK property says yes
Based on tip of LibreELEC.tv master (e533f151, changelog) and tip of XBMC master (578e9d50, changelog) with the following modifications:
  • Includes latest bcm2835-driver master (ac0c0bff, ahead +9)
  • Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (29bfe9d8, +3), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (83371862, +30), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (4ff1552f, +4), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (dc112316, +6), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
  • Include [env] PR:366: mysql: update to 5.7.12
  • Include [env] PR:371: dtc: add package
  • Include [env] PR:374: eventlircd update to new upstream
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] PR:9847: [PVR] Feature: Make instant recording behavior configurable
Build Highlights:
  2. New firmware.
    popcornmix Wrote:Note: there is an sdram related change. We've removed the "pvt" operation that disables sdram twice a second with a new calibration. This was already being done when using sdram overclock or audio_pwm_mode=2.
    Our tests suggest that it's better never to do this, as whenever you get a different value from the expected one, memtester is more likely to fail.
    So shouldn't be a problem, but any with change like this, it's worth keeping an eye out for any regressions.
  3. Add dtparam and dtc userland binaries
  4. Bump MySQL client library from 5.1.73 to 5.7.12
  5. Bump eventlircd
  6. PR:9847: [PVR] Feature: Make instant recording behavior configurable
Build Details:
  1. Firmware (May 20):
    • firmware: sdram: Remove disable_pvt option and always do the nopvt calibration
    • firmware: bootcode.bin: Set PVT explicitly with config.txt option
    • firmware: dtoverlay: Use fewer shell commands, tidy up
    • firmware: imx219_cypto: use 0 size sub-addresses and remove I2C_FLAGS_READ_REQUIRES_STOP. See: link
    • extra: Update for support of Pi zero v2
  2. LibreELEC.tv:
    • packages/unofficial: remove git submodule (PR:375, 1 commit, 2 files changed)
    • noobs: single quotes break json (PR:369, 2 commits, 4 files changed)
    • scripts/image: make the images as well when running make noobs (PR:311, 1 commit, 1 file changed)
  3. XBMC:
    • [cmake/ios] Packaging (PR:9806, 5 commits, 17 files changed)
    • [aml] add gui settings to enable/disable sd material hw decoding (PR:9834, 1 commit, 5 files changed)
    • [PVR] Fix 'Stop recording' from inside PVR channel window. (PR:9839, 1 commit, 3 files changed)
    • Music artist tag processing improvements (PR:9812, 1 commit, 5 files changed)
    • [GUI] add orientation support to slider controls (PR:9704, 3 commits, 10 files changed)
  4. inputstream.mpd:
  5. peripheral.joystick:
    • [cmake] Rename find_package(kodi) to Kodi (PR:40, 2 commits, 2 files changed)
    • Fix build on Android, RBPi and Linux (PR:41, 1 commit, 5 files changed)
  6. pvr.hts:
    • Fix instant timers. (PR:226, 1 commit, 3 files changed)
  7. newclock5:
      • fixup! stereoscopics: Switch to using block_lr for mvc to match makemkv (37c40c80)
  8. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:366: mysql: update to 5.7.12
    • Added: [env] PR:371: dtc: add package
    • Added: [env] PR:374: eventlircd update to new upstream
    • Added: [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
    • Added: [pkg] PR:9847: [PVR] Feature: Make instant recording behavior configurable
Just reporting that I'm having to revert to 0507 because of two - not debilitating but annoying reasons.
1.) There is no focus on any item when entering a video addon like Youtube. It requires a directional press fora tile to become focused
2.) Autocomplete keyboard refreshes after every keystroke making searching youtube really slow
I've tried every build since 0507 hoping that one would fix the issues because after 0508 the splash screen plays in its entirety which I like but the two problems persist. I don't have the know how to problem solve these issues but just thought I'd report.
DVD playback remains temporarily disabled so long time ...
