(2016-05-25, 11:53)drdwridav Wrote: [ -> ]Having issues with all test builds I've tried so far and rtmp streams (e.g. some USTV VOD channels). They start 'paused' then play for a second or two before returning to menu. Roll back to official Jarvis release and they play fine.b
Can post a debug log, but haven't done one before from the pi!
Unlikely to get fixed without a debug log, or determining the first build that had the problem.
(2016-05-24, 14:12)popcornmix Wrote: [ -> ] (2016-05-24, 13:58)dsenseb Wrote: [ -> ]Since one of the latest OpenElec Mulhouse buids i have a annoying issue.
Hard to imagine what could cause this. Describing your audio setup (using HDMI? AV receiver? etc) would be useful.
Are you using passthrough? Any other non-default settings?
Finding the first build that has this problem is the best way of resolving it.
I use HDMI with a AV receiver. Setup never changed. Only thing that changed is a new version of openelec.
When i have some spare time i will try to return to earlier version of OE.
Can i downgrade from LibreElec to openelec just like upgrading by putting the tar in update folder?
(2016-05-25, 15:08)drdwridav Wrote: [ -> ]Here goes...
http://xbmclogs.com/puwy1f8gh
This is problem:
14:01:54 71.623474 T:1572184992 INFO: RTMPSockBuf_Fill, recv returned -1. GetSockError(): 11 (Resource temporarily unavailable)
14:01:54 71.623566 T:1572184992 ERROR: RTMP_ReadPacket, failed to read RTMP packet header
We are getting an error from network stack. Are you sure LE Jarvis is working on this stream currently?
There is always a chance that something is changed at the server end, so it's worth double checking the stream is still good.
If it does work in LE Jarvis, then it probably was working in an earlier Milhouse nightly build.
Worth testing a build from a couple of months back just to see.
Possibly LE has bumped a library which the new version is no longer supporting this stream. Narrowing down when this occurred would be helpful.
For those who may not be aware, there is an unofficial branch of Leopold's excellent
OpenElec Dev Update (Which unfortunately does not currently work with LibreElec
miigotu makes no promises to keep his temp modified version updated, but I confirm currently works well, to specifically update Milhouse nightly builds of LibreElec and can be found
here
Just follow miigotu instructions for download, rename, and then install LibreElec Dev Update for a hassle free selection and install from within kodi "backwards/forward" through available nightly builds.
Original post on this topic from miigotu can be found
here in the LibreELEC Testbuilds for x86 (Kodi 17.0) thread.
(2016-05-25, 18:22)popcornmix Wrote: [ -> ] (2016-05-25, 15:08)drdwridav Wrote: [ -> ]Here goes...
This is problem:
I have been meaning to grab debug logs on this for some time. I have the same exact issue on my libreelec/openelec setups but works fine on pure Kodi on Windows. Not very helpful I know - I will have to pull some good debugs and bad and see the difference.
Just wanted to report drdwridav isn't alone.
New LibreELEC.tv Krypton build #0525:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.0 #1 Wed May 25 21:06:52 BST 2016 armv6l GNU/Linux
# vcgencmd version
May 20 2016 19:05:21
Copyright (c) 2012 Broadcom
version faf071dd4885c5ac1a89483d35a5326e7f69495f (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160525210500-#0525-g1647950 [Build #0525]
# vcdbg log msg 2>&1 | grep DTOK
002477.441: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (16479507,
changelog) and tip of
XBMC master (fe51c6b3,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
- Includes latest bcm2835-driver master (3b98f743, ahead +10)
- Includes latest kodi-platform master (c8188d82, ahead +4)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (00d9ba15, ahead +19)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (01236bbe, +7), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (83371862, +30), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (e2b60252, +8), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (4244220f, +12), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
- Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Fix SIGTERM patch after PR9748
- Include [env] patch: Fix cmake after PR9750
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Disable -werror as libnfs won't build 32-bit without it
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:353: plymouth-lite: add bilinear interpolation patch
- Include [env] PR:366: mysql: update to 5.7.12
- Include [env] PR:381: splash: Select splash image based on native resolution
- Include [env] PR:382: systemd: update to 230
- Include [env] PR:388: xf86-video-nvidia: update to xf86-video-nvidia-361.42
- Include [env] PR:393: nvidia: Enable USLEEP to reduce CPU load while rendering
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: drm/i915/ilk: Wait one vblank before enabling audio (link1, link2) (linux)
- Include [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
- Include [pkg] patch: Revert "drm/i915: Exit cherryview_irq_handler() after one pass" (BSW fix) (linux)
- Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:9847: [PVR] Feature: Make instant recording behavior configurable
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- mmal and render fixes
Build Details:
- XBMC:
- Player fixes (PR:9826, 8 commits, 18 files changed)
- VideoPlayer: fix audio for wmapro (and may some other codecs) (PR:9867, 2 commits, 3 files changed)
- [cmake/addons] Make relative ADDON_SRC_PREFIX relative to the build dir (PR:9813, 1 commit, 1 file changed)
- [cmake] Don't run autoreconf as UPDATE_COMMAND (PR:9854, 1 commit, 2 files changed)
- AudioDSP fixes (PR:9870, 3 commits, 3 files changed)
- [adsp] show warning if no modes are present for manager dialog (PR:9835, 3 commits, 6 files changed)
- newclock5:
- New commits in this build:
- RenderMan: Simplify late frame skipping code v2 (eaa440d9)
- mmalcodec: Just return VC_PICTURE when we have more than one picture (1a689a1d)
- rbp: Hard code the number of buffers to improve audio sync (68114b34)
- Commits no longer in build:
- [rbp] Default to double buffered (14222b64)
- VideoPlayer: improve CDVDMessageQueue (e2626789)
- VideoPlayer: fix audio for wmapro (and may some other codecs (b2ab1afa)
- Added: [env] PR:393: nvidia: Enable USLEEP to reduce CPU load while rendering
(2016-05-25, 22:52)Milhouse Wrote: [ -> ][*]RenderMan: Simplify late frame skipping code v2 (eaa440d9)
This is designed to improve the stall that occurs a few seconds after start of playback or seeking. Report if it helps.
Quote:[*]rbp: Hard code the number of buffers to improve audio sync (68114b34)
This should improve audio sync. wesk05 has done some testing with some A/V sync hardware which showed omxplayer was spot on,
but mmal was one frame (41ms) off with default settings (number of buffers=2, sync playback to display disabled)
and two frames (83ms) off with default settings (number of buffers=2, sync playback to display enabled).
(If number of buffers were set to 3 it would be an additional frame off, but that is not the default).
I've removed the "number of buffers" setting and set it in the code to what I suspect is right. We'll need wesk05 to confirm for sure, but please test audio sync seems okay.
(2016-05-25, 23:00)popcornmix Wrote: [ -> ] (2016-05-25, 22:52)Milhouse Wrote: [ -> ][*]RenderMan: Simplify late frame skipping code v2 (eaa440d9)
I had the following behavior until yesterday with Amazon Video-Streams: Stream starts, plays for a couple of seconds and then switches the TV to the target refresh rate (instead of doing this before the stream starts). After the refresh rate got adjusted the video stutters until I use the skip forward/back function one time.
The latest update seems to fix the stuttering. But what about the strange behavior with the refresh rate? It's working fine for local videos (adjustment before the video starts). I only have this issue with Amazon Video at the moment.
Some addons (Youtube, SuperFavourites) aren't working with recent releases (at least #0524 and #0525 ones).
Activating debug log, I have some errors like this :
Youtube Addon 5.2.1 :
23:09:36 12917.675781 T:1962225664 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/channel/UCMkOKU7usWmqcpLDcWG9PtQ/
23:09:36 12917.719727 T:1962225664 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/channel/UCMkOKU7usWmqcpLDcWG9PtQ/) failed
SuperFavourites Addon 1.0.43 :
23:12:00 13061.955078 T:1962225664 ERROR: GetDirectory - Error getting plugin://plugin.program.super.favourites/?fanart=%2Fstorage%2F.kodi%2Faddons%2Fplugin.program.super.favourites%2Ffanart.jpg&image=DefaultFolder.png&label=Explore%20Kodi%20favourites&mode=300
23:12:00 13061.968750 T:1962225664 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.super.favourites/?fanart=%2Fstorage%2F.kodi%2Faddons%2Fplugin.program.super.favourites%2Ffanart.jpg&image=DefaultFolder.png&label=Explore%20Kodi%20favourites&mode=300) failed
I have filtered ERROR lines because kodi.log is awful and contains a lot of messages from really verbose services (PVR...).
Returned back to release #0521 and my addons are working.
Tried release #0524 and latest #0525 and my addons aren't working.
If you really need them, I can reproduce debug log and upload it.
(2016-05-26, 00:10)BmD_Online Wrote: [ -> ]Returned back to release #0521 and my addons are working.
Why go back to #0521 and not #0523 or #0522 - you have skipped these two builds without explaining why. As it happens, #0522 includes a change which could be responsible so if #0522 is the first build with a problem then please post your details on PR9862.
Simply because I'm not upgrading everyday. Once or twice a week.
And, I have this problem since yesterday.
After each upgrade, I keep downloaded file... just in case.
I will try 522 release.
BTW, I'm actually returned back to 521, SuperFavouries and Youtube addons are working... But I have same kind of errors in kodi.log
00:17:29 295.262177 T:1962397696 ERROR: GetDirectory - Error getting plugin://plugin.program.super.favourites/?cmd=ActivateWindow(10025%2C%22plugin%3A%2F%2Fplugin.video.youtube%2Fchannel%2FUCzbGpOW-QXRLKyD6Hsftk-g%2F%22%2Creturn)&image=https%3A%2F%2Fyt3.ggpht.com%2F-gsOL1vi4-rs%2FAAAAAAAAAAI%2FAAAAAAAAAAA%2F1HnU0AjxILM%2Fs240-c-k-no%2Fphoto.jpg&label=Ginger%20Force&mode=650
00:17:29 295.311127 T:1962397696 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.super.favourites/?cmd=ActivateWindow(10025%2C%22plugin%3A%2F%2Fplugin.video.youtube%2Fchannel%2FUCzbGpOW-QXRLKyD6Hsftk-g%2F%22%2Creturn)&image=https%3A%2F%2Fyt3.ggpht.com%2F-gsOL1vi4-rs%2FAAAAAAAAAAI%2FAAAAAAAAAAA%2F1HnU0AjxILM%2Fs240-c-k-no%2Fphoto.jpg&label=Ginger%20Force&mode=650) failed
@Kougami: see above posts. Add a comment on PR9862. Don't add a comment, don't expect a fix.
