Milhouse
Assume situation with regard to your providing a downloadable zip of TVheadend backend aligned to every nightly build (With no change to underlying tvheadened build) is deliberate?
Noticed that every night your providing a build, but release version
service.tvheadend42 is not changing in download link. i.e. service.tvheadend42-8.0.102
with underlying version of HTS tvheadend remaining and reported as 4.1.1945 (if downloaded and installed) aligned to service.tvheadend42-8.0.102?
I am aware that in LibreElec forum CvH appears to be maintaining what appears to be a Wetek version of service.tvheadend which is now at 4.1.2104
here
Chance of an update for the RaspberryPi (no real desperate need/requirement, just intrigued, especially as your providing updated zip every night)
(2016-06-01, 19:54)xprozacx Wrote: [ -> ]german language seems only to work with the first profile.
In my second profile I german language is not listed nor it can be set in the guisettings.xml file.
Does this work with a stable build (e.g. LE 7)?
(2016-06-02, 23:05)beertank Wrote: [ -> ]Same problem with #0602, same fix cures it. Will I have to keep copying #0531 rpi-dac.dtbo to keep fixing it?
For now, yes. A fix needs to be applied to the rpi-4.6.y branch which I'm sure popcornmix will do once the issue is identified.
New LibreELEC.tv Krypton build #0602:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.0 #1 Thu Jun 2 21:05:11 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 2 2016 16:05:45
Copyright (c) 2012 Broadcom
version d3cabccc990645d482e723b2c65e3b4b1481afac (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160602210319-#0602-gb4f3545 [Build #0602]
# vcdbg log msg 2>&1 | grep DTOK
002471.611: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (b4f3545f,
changelog) and tip of
XBMC master (91a1cd50,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
- Includes latest bcm2835-driver master (70143fe9, ahead +12)
- Includes latest kodi-platform master (c8188d82, ahead +4)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (65424347, ahead +21)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (01236bbe, +7), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (2db8029e, +32), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (e2b60252, +8), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (fb24eda2, +13), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
- Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Fix SIGTERM patch after PR9748
- Include [env] patch: Fix cmake after PR9750
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Disable -werror as libnfs won't build 32-bit without it
- Include [env] patch: mesa: update to 12.0.0-rc1
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:353: plymouth-lite: add bilinear interpolation patch
- Include [env] PR:405: init: Parse resolution after splash.conf
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
- Include [pkg] patch: Revert "drm/i915: Exit cherryview_irq_handler() after one pass" (BSW fix) (linux)
- Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
- NOTE: DVD ISO/disk playback remains temporarily disabled
- New firmware
Build Details:
- Firmware (Jun 2):
- firmware: Adjust include paths for Linux/BSD. See: link
- firmware: image_fx: Need to preserve flags for generated frames. See: link
- firmware: write_raw_md: Fix assert due to struct size
- firmware: Enable VC_IMAGE_BGR888 support
- firmware: video_splitter add support for YUYV
- firmware: vc_image_copy support for YUYV formats
- firmware: video_splitter: support format conversion on buffers in and out
- firmware: MMAL/IL: Fix retrieving supported encodings for image domain ports
- firmware: RaspiStillYuv: Detect and amend request for RGB pixel ordering. See: link
- XBMC:
- [cmake] Make CMake aware of textfiles that configure the build (PR:9876, 1 commit, 3 files changed)
- [cmake] KodiConfig.cmake is the name (PR:9894, 1 commit, 2 files changed)
- [cmake] Code block termination cleanup (PR:9893, 3 commits, 13 files changed)
- Add a method to retrieve video tags (PR:7369, 1 commit, 6 files changed)
- pvr.stalker:
- vs2015 fixes (PR:63, 1 commit, 2 files changed)
- newclock5:
- New commits in this build:
- mmalffmpeg: Add lock on buffer release and log message (354e6a0a)
(2016-06-02, 19:41)MikeKL Wrote: [ -> ]Noticed that every night your providing a build, but release version service.tvheadend42 is not changing in download link. i.e. service.tvheadend42-8.0.102 with underlying version of HTS tvheadend remaining and reported as 4.1.1945 (if downloaded and installed) aligned to service.tvheadend42-8.0.102?
The addon version number isn't being bumped for tvheadend42 - I had been doing this for tvheadend, but forgot to also do it for tvheadend42. Every addon package is different, some have computable versions, some don't. tvheadend[42] is one of those that does. This will be fixed in the next build (#0603). Underlying source code is correct though, the last build is based on latest master (should be v4.1-2104-g8e637f9).
I just noticed that the fast forward with sound has stopped working in #602 the setting was still there was that function removed or should I go back in build to find where it stopped working?
(2016-06-03, 00:32)Milhouse Wrote: [ -> ] (2016-06-02, 19:41)MikeKL Wrote: [ -> ]Noticed that every night your providing a build, but release version service.tvheadend42 is not changing in download link. i.e. service.tvheadend42-8.0.102 with underlying version of HTS tvheadend remaining and reported as 4.1.1945 (if downloaded and installed) aligned to service.tvheadend42-8.0.102?
Thanks for clarification, I'd been updating latest versions of tvheadend with your builds out of habit, but had stopped updating tvheadend in last month thinking no difference in builds when zips named same and size identical etc.
(2016-06-03, 15:41)Av3nged Wrote: [ -> ]I just noticed that the fast forward with sound has stopped working in #602 the setting was still there was that function removed or should I go back in build to find where it stopped working?
It's not been deliberately removed - so identifying the builds would be useful.
Note that some settings may disable it, such as using omxplayer or passthrough.
(2016-06-03, 16:25)popcornmix Wrote: [ -> ] (2016-06-03, 15:41)Av3nged Wrote: [ -> ]I just noticed that the fast forward with sound has stopped working in #602 the setting was still there was that function removed or should I go back in build to find where it stopped working?
I had omxplayer enabled I don't know when I did that sorry.
Hi Milhouse,
first of all thanks for the great work you've done so far.
I have two problems with my raspberry pi 3 and libreelec. Onboard WiFi is working but can't connect via SSH. Also NTP isn't working with WiFi connection. Cable works fine. Could you please test it and fix it if possible.
Thanks in advance
(2016-05-19, 23:24)Milhouse Wrote: [ -> ]I agree with the reply from the skin maintainer. This is a core issue, and a solution is yet to be identified. See the ongoing discussion in PR9778.
Hi, I thought I'd post again as one of the issues I've encountered since 0508 has still not been resolved. Whatever was done in PR9778 has broken streaming from a popular (but dodgy) addon that I use. Whilst the 'busy' dialog was fixed I cannot stream with any build from 0508 with a number of streaming addons, one in particular. Streams just fail to be found and the UI of the app I'm on about is very slow to find shows.
I appreciate that it's not a legit addon so I anticipate that it's not something that will be looks at, but I've attached a debug log in any case as it may be that the changes that were made in this PR have affected other legit streaming addons adversely. I've tried every build since 0507 and none work, so I'm sure it's something to do with that PR. I've also gone back to Estuary to see is it's a skin issue and that still does not resolve the issue. 0507 works perfectly, anything afterwards does not.
http://pastebin.com/nCguUVPN
(2016-06-03, 20:52)Trixster Wrote: [ -> ]Whatever was done in PR9778 has broken streaming from a popular (but dodgy) addon that I use.
Your best bet for a fix is to find a non-dodgy add-on that is also affected.
Then a bug report can be raised. Otherwise I suspect the issue will be ignored.
I thought that might be the case!
