(2016-06-12, 04:05)ragedogg69 Wrote: [ -> ]Anyone get the WWE Network Add On to work with these 17.0 builds? It works fine on all of my other 16.1 boxes.
There have been a lot of changes between 16.1 and 17.0 - the add-on may not be Kodi 17 (Krypton) compatible, in which case you should contact the add-on maintainer.
If the add-on is supposed to be Kodi 17 compatible then you'll need to post more details such as a description of the problem, and of course a debug log.
(2016-06-12, 06:06)Gothicawakening Wrote: [ -> ]Can I just update to the current #0610 as normal, or would any other steps be needed?
Just update to #0610 as you would normally.
New LibreELEC.tv Krypton build #0611:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.2 #1 Sat Jun 11 23:05:17 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 8 2016 16:12:00
Copyright (c) 2012 Broadcom
version 1c8638223821fe0ed16e20bd8e948b6cc037fa4a (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160611230409-#0611-gec2a5d2 [Build #0611]
# vcdbg log msg 2>&1 | grep DTOK
002474.924: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (ec2a5d29,
changelog) and tip of
XBMC master (2229bcdb,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
- Includes latest bcm2835-driver master (9cd62e61)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (cdd1643c, ahead +28)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (3ac19c39, +15), inputstream.smoothstream (32275717), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: mesa: update to 12.0.0-rc1
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:412: splash: Stop blanking splash too early in RPi boot sequence
- Include [env] PR:431: Revert "Merge pull request #136 from lrusak/modesetting"
- Include [env] PR:432: build: start using .libreelec-unpack
- Include [env] PR:433: libreelec: use build project directory for ccache
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
- VideoPlayer and DMA fixes
Build Details:
- LibreELEC.tv:
- Fix digital audio crackling when playing music on non Kodi based setups. (PR:408, 1 commit, 1 file changed)
- XBMC:
- added: allow input streams to register for protocol types (PR:9945, 1 commit, 2 files changed)
- VideoPlayer: fixes for refresh rate switching (PR:9942, 2 commits, 6 files changed)
- changed: get rid of FileReaderFile (PR:9940, 1 commit, 8 files changed)
- [android] revert 54f9c50572fe540cc754538f6e93e6a87a8552fd since we no… (PR:9912, 1 commit, 3 files changed)
- [addons] add origin tracking (PR:9910, 1 commit, 9 files changed)
- [cmake/osx] Fix build after renaming 'darwin' to 'osx' (PR:9951, 1 commit, 13 files changed)
- [python-api] - some additions & cleanup (PR:9842, 4 commits, 6 files changed)
- changed: get rid of PlayListPlayer include in Application.h (PR:9947, 1 commit, 12 files changed)
- [cmake] Fix GenerateVersionedFiles (PR:9953, 1 commit, 1 file changed)
- newclock5:
- New commits in this build:
- Fix used input and output buffer sizes inside CActiveAEDSPProcess:rocess(...) (7bb59ca9)
- Use valid speaker layout for output buffer (7d8c77f2)
- TODO fix synchronization with VideoPlayer (eeeb9226)
- Fix --player=omxplayer needs (5f4b116b)
- Revert "VideoPlayer: drop obsolete irFpsScale" (dad25ea5)
- Revert "fixed fps rate on startup" (38fb19da)
- Revert "VideoPlayer: drop remaining rfpsscale hack" (160c68b1)
- rendering: Always call Flip but don't sleep when playing video (005bc83f)
- Commits no longer in build:
- VideoPlayer: Handle lost display with pause/resume (2510fada)
- VideoPlayer: do not calc framerate in stalled state (178e2bb9)
- Revert "VideoPlayer: set 10ms threshold for DISCONT error adjustments" (240c6f57)
- kernel 4.6.y:
- dmaengine: bcm2835: Fix polling for completion of DMA with interrupts masked. (635503ed)
New LibreELEC.tv Krypton build #0612:
RPi /
RPi2
# uname -a
Linux rpi512 4.6.2 #1 Sun Jun 12 22:38:44 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 8 2016 16:12:00
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160612223738-#0612-gec2a5d2 [Build #0612]
002474.452: Kernel trailer DTOK property says yes
Based on tip of
XBMC master (07131a31,
- Include [env] patch: binary-addon: inputstream.rtmp
- Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
- Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
Build Highlights:
- Move RTMP support to inputstream.add-on
- Fix "Save" button when editing network connections LibreELEC Settings addon
- Add support for development updates in LibreELEC Settings add-on - a built-in minimmalist version of Leopold's add-on.
For these builds, enter a URL into a Custom Channel, selecting from the following URLs based on your hardware:
RPi Zero/RPi1: http://milhouse.libreelec.tv/builds/master/RPi
RPi2/RPi3: http://milhouse.libreelec.tv/builds/master/RPi2
Generic (x86): http://milhouse.libreelec.tv/builds/master/Generic
then select "Milhouse-8.0" as the Update Channel.
Build Details:
- XBMC:
- changed: remove internal librtmp support (PR:9946, 1 commit, 20 files changed)
- changed: forward IActionListener in Application.h (PR:9952, 2 commits, 8 files changed)
- improve current code of unused db fields (PR:9923, 1 commit, 2 files changed)
- [cmake] Don't link against libpng (PR:9955, 1 commit, 1 file changed)
- [cleanup] completely remove filereader protocol (PR:9950, 1 commit, 4 files changed)
- Using TagLib for opus file tags. (PR:9930, 2 commits, 4 files changed)
- [depends] update libmicrohttpd to 0.9.50 (PR:9956, 1 commit, 1 file changed)
- [depends][win32] bump libmicrohttpd to 0.9.50 (PR:9959, 1 commit, 1 file changed)
- [depends] tar 1.28 (PR:9941, 1 commit, 1 file changed)
- ActiveAE: Enable display lost callbacks for EGL (PR:8995, 2 commits, 17 files changed)
- [xbmc][fix][pvr] Fix warning class GridItemPtr already seen as struct. (PR:9961, 1 commit, 4 files changed)
- [addons] move changelog to addon.xml (PR:9351, 1 commit, 9 files changed)
- [win32] disable AppVeyor add-ons building (PR:9972, 1 commit, 1 file changed)
- newclock5:
- ActiveAE: Enable display lost callbacks for EGL (fec833c8)
- Added: [env] patch: binary-addon: inputstream.rtmp
- Updated: [env] patch: Enable other binary addons
- Added: [pkg] PR:26: fix save button in network config (service.libreelec.settings)
- Added: [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
Since I am new to the RPi scene, I am unaware if this is a known issue - When I play H265 encoded files, the video stutters constantly. Is this a known issues? Is there a workaround? I am on Milhouse 0611 build.
(2016-06-13, 00:22)the_jaguar Wrote: [ -> ]Since I am new to the RPi scene, I am unaware if this is a known issue - When I play H265 encoded files, the video stutters constantly. Is this a known issues? Is there a workaround? I am on Milhouse 0611 build.
What is your hardware - RPi, RPi2 or RPi3? What are the media info details of the H265 video - bit rate, resolution (720, 1080 etc.)?
H265 video won't work at all on RPi1/RPi0.
Most 720p H265 video should play OK on RPi2 and RPi3. 1080p H265 up to about 3Mbit/s should be OK on RPi3, but may require overclocking on RPi2.
It's an RPi3 and the video resolution is 1080P with a bitrate of ~3Mbit/s (both video & audio included). Would I need to overclock my RPi3 to prevent the stutter? It plays fine on my 2011 mac mini.
Overclock the RAM to at least 550mhz. This helps a lot for some 1080p h.265 files. However, some 1080p files are unwatchable regardless of OC.
(2016-06-13, 00:55)the_jaguar Wrote: [ -> ]It's an RPi3 and the video resolution is 1080P with a bitrate of ~3Mbit/s (both video & audio included). Would I need to overclock my RPi3 to prevent the stutter? It plays fine on my 2011 mac mini.
Overclocking may help, and as @
smp1 states, particularly the SDRAM. Please read and post in the numerous other overclocking threads if you need further help with overclocking and not here, as it's en entire topic in itself.
(2016-06-13, 01:40)the_jaguar Wrote: [ -> ] (2016-06-13, 01:10)smp1 Wrote: [ -> ]Overclock the RAM to at least 550mhz. This helps a lot for some 1080p h.265 files. However, some 1080p files are unwatchable regardless of OC.
(2016-06-13, 01:30)Milhouse Wrote: [ -> ] (2016-06-13, 00:55)the_jaguar Wrote: [ -> ]It's an RPi3 and the video resolution is 1080P with a bitrate of ~3Mbit/s (both video & audio included). Would I need to overclock my RPi3 to prevent the stutter? It plays fine on my 2011 mac mini.
Overclocking may help, and as @smp1 states, particularly the SDRAM. Please read and post in the numerous other overclocking threads if you need further help with overclocking and not here, as it's en entire topic in itself.
will do - thanks much!
Hi, as well as the advice above, be carefull when overclocking to keep the system reliable; note that full rate video, ie 50 to 60Hz will not play reliably, half rate 24 to 30Hz, which is more common anyway, will usually play ok, depending on how it was encoded, also if it is full frame or letterbox (letterbox usually better), the lower the bit rate, the more likely it is to play reasonably, some play perfectly, some not so, it may be worth using someting like handbrake to re-encode it at a lower frame/bitrate.
Regards, Kevin.
Filled in the custom source. I get an error "No build were found for Rpi2" .
Hello,
have some Problems with Addons:
If i update from #610 to #612 all my addons are disappeared.
Go back from #612 to # 610 all Addons are visible.
Have i to make a backup before update each time?
THX
btw: wifi problems from Post: #867 are solved - only channel 1-6 operated with pi3 :-p
(2016-06-13, 15:00)Gregoire Wrote: [ -> ]Filled in the custom source. I get an error "No build were found for Rpi2" .
Set custom channel1 to
Then go to update channel and select Milhouse-8.0
After that the available builds are visible.
