Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
If I have no picture, no deinterlace settings may change.
No live TV from DVB-C / S, live TV is completely dead.
It works through the Web Interface.
RPi2 has the same problem.
(2016-06-17, 18:03)popcornmix Wrote: [ -> ]
(2016-06-17, 17:30)Aux_ Wrote: [ -> ]Here the log
And yes Does just affect live TV...
Play video files is normal.
Thanks. Does it occur with deinterlace set to off/auto/on?
Live DVB-T not working in #0616 for me, here is debug log with the Video component switched on in debug options.
---edit-- and to be specific when trying to playback DVB-T channels it's just a blank "black" no audio/video playback screen, with options to pause/play, look at various settings i.e. switch between deinterlace on, off, auto. then stop playback etc.
In my current usage case I have two pvr backends running tvheadened (DVBT) and pvr.filmon, pvr.filmon playback is working fine in #0616
Hi It says throttled=0x0
Omx is a bit more stable. SSH still works if it crashes.
I have a crash log but it includes the add-ons. I will see if I can get one without them.
Also I am running a secondary USB WiFi adapter.
(2016-06-16, 12:45)popcornmix Wrote: [ -> ]
(2016-06-16, 07:03)david1976aus Wrote: [ -> ]Thanks for the direction. It didnt crash but instead just froze
Debug log at the following location http://pastebin.com/TRVjWpGT
Nothing obvious from log except you have some network issues. e.g.:
12:14:36  17.430374 T:1753215904   ERROR: ## LibreELEC Addon ## oe::load_url(http://releases.libreelec.tv/releases.json) ## ERROR: (URLError(gaierror(-3, 'Temporary failure in name resolution'),))
Do you still get the hang if omxplayer is enabled? Does it affect all video files or just that one?
Can you try copying the video to pi (e.g. to sdcard or usb stick) and play from there?
If you ssh in before the hang is the ssh connection still active? What does "vcgencmd get_throttled" return at this point?
I see people having issues with LiveTV on 0616. Just an FYI that LiveTV works for me with 0616. My tuner is on a separate backend running MythTV, if that would make a difference.
LiveTV works for me with OMXplayer but not via mmal
I had tested both omx and mmal, both no reaction. I use TVHeadend 4.2
Returned to # 0615 because everything works well...
Installed and tested #0617 and LiveTV is working again (Although Milhouse has not posted about #0617 release yet, it is available via development build add-ons and new LibreELEC settings development update feature)
Support for development updates in LibreELEC Settings add-on (built-in minimmalist version of Leopold's add-on) For these builds, enter a URL into a Custom Channel, selecting from the following URLs based on your hardware:
Then Select "Milhouse-8.0" as the Update Channel then open Available versions option in order to select and install an available release.
(Note: may need to reboot device in order to refresh/see latest builds)
I also made this update #0617 on LibreELEC add-on. So far, everything works perfectly.
No problems with live TV on RPi3, RPi2 I had not tested.
New LibreELEC.tv Krypton build #0617: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.2 #1 Fri Jun 17 21:06:11 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 13 2016 13:25:19
Copyright (c) 2012 Broadcom
version 625ddc17506de68faffed80e656109b206905fc0 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160617210505-#0617-g2707304 [Build #0617]
# vcdbg log msg 2>&1 | grep DTOK
002459.257: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (27073046, changelog) and tip of XBMC master (9248a823, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
  • Includes latest bcm2835-driver master (fdbca29d, ahead +1)
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (cdd1643c, ahead +28)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (3ac19c39, +15), inputstream.smoothstream (99b9c3c3, +1), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: binary-addon: inputstream.rtmp
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:432: build: start using .libreelec-unpack
  • Include [env] PR:433: libreelec: use build project directory for ccache
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
  • Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
  1. New VideoDB schema v106
Build Details:
  1. LibreELEC.tv:
    • mpd: enable build from clean (PR:459, 1 commit, 1 file changed)
  2. XBMC:
    • Fixes and improvements for ratings (PR:9907, 4 commits, 4 files changed)
    • Swig 3.0.10 (PR:9990, 2 commits, 2 files changed)
    • Use year in label2 when sorting by year (PR:9991, 1 commit, 1 file changed)
  3. inputstream.smoothstream:
    • bandwidth / maxres / remove url (99b9c3c3)
  4. newclock5:
    • New commits in this build:
      • rbp: Update transposed video scaling to match other platforms (a94a1c39)
      • mmalrender: Use computed framerate rather than version from configure (4abfd2b5)
      • fixup! mmal_codec: Use EOS through codec to determine drain is complete (f00db273)
      • fixup! mmal_codec: Use EOS through codec to determine drain is complete (7881c09f)
    • Commits no longer in build:
      • Revert "VideoPlayer: drop obsolete irFpsScale" (8be1c65b)
      • Revert "fixed fps rate on startup" (69d5ee53)
      • Revert "VideoPlayer: drop remaining rfpsscale hack" (7b8e2479)
  5. kernel 4.6.y:
      • Added support for headphones, microphone and bclk_ratio settings. (64843dfd)
      • BCM270X_DT: Add spi-rtc overlay on SPI0.0 (6140217a)
      • rtc: Add SPI alias for pcf2123 driver (35f28092)
i still have the same problem. The Libreelec options -> system page is empty so i cant manually update. No idea where the problem comes from but about maybe 2 of the 10 tries it shows the options there.
after startup/reboot im getting.
addon not ready yet try again later.
hi guys i want to ask why is no longer working frame by frame when you pause video and go forward or back? Long time ago this was working
I've also a little wish ;-)
Is it possible to build in the chapter forward/back for playing DVD?
Long, long time ago this was working and always present in Kodi16.
ok - i feel fairly well satisfied with returned reinstate DVD support...
Harald
Yesterday I made the update to #0616. Live-TV works with VDR but 720p channel switching had some issue (had this some time ago, channel switch but after that there is a black screen for 0.5s)
Today I update to #0617 and channel switching is ok again
(2016-06-18, 19:24)Little_Kitty Wrote: [ -> ]i still have the same problem. The Libreelec options -> system page is empty so i cant manually update. No idea where the problem comes from but about maybe 2 of the 10 tries it shows the options there.
Can you upload a debug log?
I have managed to trigger the blank System page by configuring an RPi2 system to use the RPi2 custom url, then later on change the custom url to be the Generic url - at this point the add-on generates various errors and the System page becomes blank. To fix this you need to edit /storage/.kodi/userdata/addon_data/service.libreelec.settings/oe_settings.xml and correct the <CustomChannel1> tag.
Without knowing if this is what you have done I would suggest removing the following tags from your settings file:
<ShowCustomChannels>
<Channel>
<CustomChannel1>
and restarting Kodi.
If that doesn't work, delete /storage/.kodi/userdata/addon_data/service.libreelec.settings/oe_settings.xml and restart Kodi.
New LibreELEC.tv Krypton build #0618: RPi / RPi2
# uname -a
Linux rpi512 4.6.2 #1 Sat Jun 18 21:27:37 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160618212631-#0618-gf481b3d [Build #0618]
002474.471: Kernel trailer DTOK property says yes
Based on tip of LibreELEC.tv master (f481b3d2, changelog) and tip of XBMC master (7a3b106e, changelog) with the following modifications:
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (77af35f9, +18), inputstream.smoothstream (99b9c3c3, +1), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
  • Revert [pkg] PR:9999: [CHG] Settings - Library: groupings (reason: breaks newclock5)
Build Highlights:
  1. ADSP commits added to newclock5 branch
  2. inputstream.mpd updates
Build Details:
  1. LibreELEC.tv:
    • chromium: enable build from clean (PR:460, 1 commit, 1 file changed)
    • hyperion: update to d2f4725 (PR:446, 3 commits, 6 files changed)
    • mono: create addon (PR:404, 5 commits, 14 files changed)
  2. XBMC:
    • [depends] remove libmodplug as it's now a binary add-on (PR:9995, 1 commit, 2 files changed)
    • [lang] handle disabled language addons in migration (PR:9969, 1 commit, 2 files changed)
    • Fix misc compiler warnings. (PR:9998, 1 commit, 4 files changed)
    • [CHG] Settings - Library: groupings (PR:9999, 2 commits, 2 files changed)
  3. inputstream.mpd:
  4. newclock5:
      • Move entire source code from "xbmc/cores/AudioEngine/DSPAddons/" to "xbmc/cores/AudioEngine/Engines/ActiveAE/AudioDSPAddons" (09bd0c5f)
      • Adapt include paths to new structure (e4415afb)
      • Adapt build files (TODO: changes for XCode) (88d0d86b)
      • Remove compiler error (92bfd9c5)
      • Update XCode after move of entire source code (fe172332)
      • - added moved files to ios target in xcode project (fe70613b)
      • Equal placed for AudioDSP settings in video- and music OSD (67b58c80)
      • Use correct output format in ActiveAEBuffer and correct spellings (8552fbe0)
      • Move FFMPEG converter array defines to cpp file and use them in CActiveAEDSPProcess:Tonguerocess(...) (5656aa66)
      • Replace channel flag if's with loops and simplify SetFFMpegDSPProcessorArray(...) (0f75d090)
      • Add optional cout and debug log messages with #ifdef ADSP_COUT_DEBUG_OUTPUT (dbd4b4d2)
      • Delete all buffers when the buffer pool gets recreated (86fbfb24)
      • Use same timestamp and pkt_start_offset as the input buffer (1bd425af)
      • AudioDSP is not allowed to change the audio format without notifying ActiveAE (4da04b3d)
      • Currently AudioDSP has the same amount of input frames as output frames, which results in zero delay (55c19e60)
      • Add input and output AudioDSP format variables (7eff288b)
      • Use one member variable for the output format (398c3e82)
      • Deleting NULL pointer is safe (57ceddf9)
      • Use correct frame sizes for FFMPEG format conversion functions (af13783e)
      • Set FFMPEG converter array to NULL (d3ca8ca6)
      • Use correct array pointers for internal resampler (6fc367a4)
      • Fix FFMPEG channel index mapping (b44d3c5c)
      • Use https://github.com/AchimTuran/repo-binary-addons for binary add-on builds (0fafe28d)
      • Added jom 1.1.0 and ninja 1.7.1 build tools (c1e36ee9)
      • Build add-ons with jom to speed up the windows binary add-ons builds (5496be59)
      • Fix used input and output buffer sizes inside CActiveAEDSPProcess:Tonguerocess(...) (9e203c91)
      • Use valid speaker layout for output buffer (0532f857)
      • TODO fix synchronization with VideoPlayer (7e15cbb0)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Reverted: [pkg] PR:9999: [CHG] Settings - Library: groupings (reason: breaks newclock5)
