Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
ill re ask my question why is no longer working frame by frame step foreword when you press pause
(2016-06-22, 17:05)Doktor-X Wrote: [ -> ]ill re ask my question why is no longer working frame by frame step foreword when you press pause
I don't think that's worked since Isengard (or even before). And then it was omxplayer only.
It is not a standard Kodi feature. If you want it back, suggest it in the feature request forum. If it gets added as a standard Kodi feature, I'll support it.
thanks for quick reply, OK ill try to request it
New LibreELEC.tv Krypton build #0622: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.2 #1 Wed Jun 22 21:25:01 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 20 2016 18:18:51
Copyright (c) 2012 Broadcom
version 460b39c674ef2ac89360e15331f97a2cb1388a44 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160622212356-#0622-g0881ed2 [Build #0622]
# vcdbg log msg 2>&1 | grep DTOK
002476.798: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (0881ed2f, changelog) and tip of XBMC master (1a0c596e, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
  • Includes latest bcm2835-driver master (390f53ed, ahead +2)
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (d9e75d56, ahead +31)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (5849a194, +7), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (0a099728, +19), inputstream.rtmp (8cebd150, +1), inputstream.smoothstream (a38d40a2, +2), peripheral.joystick (2db8029e), pvr.argustv (e536f32e, +1), pvr.demo (01c68c88, +1), pvr.dvblink (5f9872ca, +1), pvr.dvbviewer (35902f5d, +1), pvr.filmon (efd379b8, +1), pvr.hdhomerun (a71e816d, +1), pvr.hts (ac2e3be6, +5), pvr.iptvsimple (1ea1f36e, +1), pvr.mediaportal.tvserver (369b0189, +1), pvr.mythtv (9141c6fc, +1), pvr.nextpvr (7ed3111c, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1, +1), pvr.stalker (acba9f12, +1), pvr.vbox (b24c3cac, +1), pvr.vdr.vnsi (5d5bb64e, +2), pvr.vuplus (c988f849, +1), pvr.wmc (ef4cf3b1, +1)
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: Enable other binary addons
  • Include [env] patch: binary-addon: inputstream.rtmp
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Enable pvr and adsp addons, disable pvr/adsp updates
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] PR:432: build: start using .libreelec-unpack
  • Include [env] PR:433: libreelec: use build project directory for ccache
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
  • Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
  1. libnfs updates
Build Details:
  1. XBMC:
    • [Estouchy] update (PR:10021, 1 commit, 19 files changed)
  2. libnfs:
    • nfs_rewinddir: introduce additional nfs_rewinddir() (PR:151, 1 commit, 2 files changed)
    • Fix crash in nfs_truncate due to dereference of uninitialized data (4cc09b97)
    • Add comment that nfs_rewinddir will never block. (d9e75d56)
@popcornmix
Could you take a look at this sample?
https://docs.google.com/uc?id=0Bw7pv6UJO...t=download
I get 1 skipped frame every ~30 seconds or so. No skipped frames if I enable "Sync Playback to Display".
Hey,
I have a problem with the updating process for my pi3. At the time I'm running the official LibreELEC 7.0.1. It's a dualboot rom with recalbox from romlink. After several attempts I always get the error "missing kernel or system" after the extracting process and than it boots into the old system.
I copied the .tar file (without extracting anything) to the Update folder. I realy don't know what i'm doing wrong. Hope you can help me
(2016-06-23, 14:03)KingQuestable Wrote: [ -> ]Hey,
While logged into LibreELEC:
mount | pastebinit
df -hT | pastebinit
(2016-06-23, 18:02)Milhouse Wrote: [ -> ]While logged into LibreELEC:
mount | pastebinit
df -hT | pastebinit
And after that?
KodiRasp3:~ # mount | pastebinit
http://sprunge.us/WESi
KodiRasp3:~ # df -hT | pastebinit
http://sprunge.us/ISWL
It just gives me back a url:
devtmpfs on /dev type devtmpfs (rw,relatime,size=372108k,nr_inodes=93027,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
/dev/mmcblk0p9 on /flash type vfat (ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
/dev/mmcblk0p10 on /storage type ext4 (rw,noatime,data=ordered)
/dev/loop0 on / type squashfs (ro,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
tmpfs on /var type tmpfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/mmcblk0p8 on /var/media/share type ext4 (rw,nosuid,nodev,noexec,noatime,data=ordered)
/dev/mmcblk0p7 on /var/media/root type ext4 (rw,nosuid,nodev,noexec,noatime,data=ordered)
Filesystem           Type            Size      Used Available Use% Mounted on
devtmpfs             devtmpfs      363.4M         0    363.4M   0% /dev
/dev/mmcblk0p9       vfat          511.7M    124.1M    387.6M  24% /flash
/dev/mmcblk0p10      ext4            1.0G      1.0G         0 100% /storage
/dev/loop0           squashfs      113.9M    113.9M         0 100% /
tmpfs                tmpfs         368.5M         0    368.5M   0% /dev/shm
tmpfs                tmpfs         368.5M      5.3M    363.2M   1% /run
tmpfs                tmpfs         368.5M         0    368.5M   0% /sys/fs/cgroup
tmpfs                tmpfs         368.5M    376.0K    368.1M   0% /var
tmpfs                tmpfs         368.5M         0    368.5M   0% /tmp
/dev/mmcblk0p8       ext4           25.2G     44.1M     23.9G   0% /var/media/share
/dev/mmcblk0p7       ext4            1.9G    803.7M   1016.9M  44% /var/media/root
(2016-06-23, 18:47)KingQuestable Wrote: [ -> ]And after that?
Your disk is full:
The upgrade process cannot extract the new files from the tar file to complete the upgrade, so the error message is correct.
You'll need to buy a bigger SD card, clone your existing card and resize to use the remaining available space. Or start afresh with a new card.
your storage partition is completely full so maybe this is the problem, but i'm not sure Sad
2 possibilities fot that
change it with geparted or
fresh install and change the partition.json file because in this image the recalbox share partition got the remaining space of the sdcard
simply edit the NOOBS/os/RecalboxOS-(osmc|libreelec)/partitions.json file.
Change "want_maximised" from false to true on the ext4 partition.
Alternatively you could leave as false and change "partition_size_nominal" to set an exact size.
This has to be done before installing any OS's in NOOBS.
If you change this file, you will need to reinstall OS's in NOOBS to take affect.
(2016-06-23, 20:31)Milhouse Wrote: [ -> ]Your disk is full:
(2016-06-23, 20:36)tilu01 Wrote: [ -> ]your storage partition is completely full so maybe this is the problem, but i'm not sure Sad
Ahh thank you guys! I will try a clean new install with "want_maximised" = true.
Will I be able to restore the backup from libreelec 7 in the new build?
(2016-06-23, 20:49)KingQuestable Wrote: [ -> ]Will I be able to restore the backup from libreelec 7 in the new build?
Yes.
New LibreELEC.tv Krypton build #0623: RPi / RPi2
# uname -a
Linux rpi512 4.6.2 #1 Fri Jun 24 03:38:32 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160624033724-#0623-g9b3d478 [Build #0623]
002477.296: Kernel trailer DTOK property says yes
Based on tip of LibreELEC.tv master (9b3d4784, changelog) and tip of XBMC master (27313111, changelog) with the following modifications:
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (5849a194, +7), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (6322a915, +23), inputstream.rtmp (8cebd150, +1), inputstream.smoothstream (a38d40a2, +2), peripheral.joystick (2db8029e), pvr.argustv (e536f32e, +1), pvr.demo (01c68c88, +1), pvr.dvblink (5f9872ca, +1), pvr.dvbviewer (35902f5d, +1), pvr.filmon (efd379b8, +1), pvr.hdhomerun (a71e816d, +1), pvr.hts (ac2e3be6, +5), pvr.iptvsimple (1ea1f36e, +1), pvr.mediaportal.tvserver (369b0189, +1), pvr.mythtv (9141c6fc, +1), pvr.nextpvr (7ed3111c, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1, +1), pvr.stalker (acba9f12, +1), pvr.vbox (b24c3cac, +1), pvr.vdr.vnsi (5d5bb64e, +2), pvr.vuplus (c988f849, +1), pvr.wmc (ef4cf3b1, +1)
  • Include [env] PR:474: lirc: replace parallel build fix
  • Include [env] PR:477: ffmpeg: rework
Build Highlights:
  1. Bump ffmpeg 3.0.1 -> 3.0.2+HEAD
  2. ffmpeg rework package
  3. Fix JSON IMDB ratings/votes (PR:10020)
  4. Improved stability/resilience of LibreELEC Settings addon "System" page - it shouldn't be blank whenever the network is disconnected, or whenever other errors occurs (please report any further instances of blank pages, along with debug log)
Build Details:
  1. LibreELEC.tv:
    • vdr-addon: update all plugins to latest (PR:475, 1 commit, 8 files changed)
    • ffmpeg: Switch to revision based versioning, not release (PR:479, 1 commit, 1 file changed)
  2. XBMC:
    • Quell some warnings (PR:10023, 2 commits, 2 files changed)
    • Change ratings to reflect json art (and future uniqueid) structure (PR:10020, 2 commits, 8 files changed)
  3. inputstream.mpd:
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:474: lirc: replace parallel build fix
    • Added: [env] PR:477: ffmpeg: rework
Build #0623x is based on 4.7-rc4, the kernel being the only change from #0623. It seems to work fine, although there may be a question over I2S support so users with audio soundcards would be advised to give it a spin in order that we can get early feedback on issues before eventually switching to the 4.7-rcX branch in the near future. Anyone else that wants to test 4.7-rc4 is also welcome.
RPi / RPi2
allen&heath:k2: no crackling with wav and 320kbps mp3. everything looking good
arcam rdac: have to test it when i have the device back :-)
native instruments audio4dj: still not able to select in the menu, but recognized with lsusb and aplay Smile
lsusb
Bus 001 Device 009: ID 1058:1078 Western Digital Technologies, Inc.
Bus 001 Device 010: ID 17cc:0839 Native Instruments Audio 4 DJ
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Audio4DJ
Audio 4 DJ, Audio 4 DJ
Default Audio Device
sysdefault:CARD=Audio4DJ
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: Audio4DJ [Audio 4 DJ], device 0: Audio 4 DJ [Audio 4 DJ]
Subdevices: 2/2
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
(2016-06-24, 07:01)Milhouse Wrote: [ -> ]Build #0623x is based on 4.7-rc4, the kernel being the only change from #0623. It seems to work fine, although there may be a question over I2S support so users with audio soundcards would be advised to give it a spin in order that we can get early feedback on issues before eventually switching to the 4.7-rcX branch in the near future. Anyone else that wants to test 4.7-rc4 is also welcome.
RPi / RPi2
