(2016-06-24, 16:31)Milhouse Wrote: [ -> ]Argh use pastebin sites for logs...
sorry. do you want me to do it again?
Yes #0622 working fine with Kore, Yatse apps on android and Kodi remote app on ios.
Log
(2016-06-24, 16:10)Milhouse Wrote: [ -> ] (2016-06-24, 15:25)sleuth Wrote: [ -> ]OK i can do debug logs for each version. do you want me to post it here or do you like a pn @Milhouse
Post it here please. And you're sure this problem only started with #0623? Could it be the the app updated recently?
It works fine with #0622! After I could not control my TV with #0623, I reverted back to #0622 and everything is fine again.
(2016-06-24, 16:33)sleuth Wrote: [ -> ] sorry. do you want me to do it again?
No don't worry, I'm able to reproduce with Yatse by deleting an existing connection then trying to reconnect. I'll see what I can discover. The only likely candidate is PR10020, which has broken something, or is now returning results these apps don't like.
(2016-06-24, 16:46)jobisoft Wrote: [ -> ] (2016-06-24, 16:10)Milhouse Wrote: [ -> ] (2016-06-24, 15:25)sleuth Wrote: [ -> ]OK i can do debug logs for each version. do you want me to post it here or do you like a pn @Milhouse
Yes, same thing here with my iPhone app.
The iOS/Yatse issue is caused by PR10023. Looking into a possible fix.
(2016-06-21, 00:20)BobCratchett Wrote: [ -> ] (2016-06-15, 02:35)BobCratchett Wrote: [ -> ]The lirc update (I'm presuming) is causing me issues with my gpio remote. A lot of the important buttons - select and back for example - aren't being recognised and there's no sign of them in the log. The number buttons, volume and arrow buttons all still seem to be working.
It may be there's just been a change to the mapping, but the relevant PR is beyond my ability to decipher. Full debug log is here, and - if it's of any use - my lircd.conf is here. If there's any other info I can provide, let me know.
Just updated from 618 to 620, and am experiencing the same issue again (well almost, this time the back button appears to work) in that some keys on my remote aren't being recognised. I've tried following some of the advice from the x86 builds thread - IRW doesn't show any input for the keys that aren't working, and the output from a few commands requested on the other thread:
systemctl status > http://sprunge.us/NbRV
dmesg > http://sprunge.us/chgE
journalctl -a > http://sprunge.us/UIii
From what I can see, the buttons mapped to the following aren't working:-
KEY_OK, KEY_RED, KEY_BLUE, KEY_YELLOW, KEY_GREEN, KEY_CHANNELUP, KEY_CHANNELDOWN, KEY_INFO, KEY_PVR, KEY_VIDEO, KEY_TITLE, KEY_TEXT, KEY_SUBTITLE
I haven't yet confirmed that this was introduced in 619 (though it seems likely as the lirc bump was re-introduced in that) but am downloading it now and will update the post when it's installed (internet is slow so this will take a while!)
Edit: Can now confirm 619 as the culprit.
@Milhouse: the same issue in #0623.
(2016-06-24, 17:30)TVPL Wrote: [ -> ]@Milhouse: the same issue in #0623.
Thanks, the lirc/gpio button issues are still being investigated.
The iOS/Yatse/etc connection issue will be fixed tonight - thanks all for reporting, and popcornmix for the fix.
New LibreELEC.tv Krypton build #0624:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.2 #1 Fri Jun 24 23:06:15 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 20 2016 18:18:51
Copyright (c) 2012 Broadcom
version 460b39c674ef2ac89360e15331f97a2cb1388a44 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160624230508-#0624-g45f3999 [Build #0624]
# vcdbg log msg 2>&1 | grep DTOK
002476.377: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (45f39993,
changelog) and tip of
XBMC master (d9fd7743,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
- Includes latest bcm2835-driver master (390f53ed, ahead +2)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (d9e75d56, ahead +31)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (5849a194, +7), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (6322a915, +23), inputstream.rtmp (8cebd150, +1), inputstream.smoothstream (a38d40a2, +2), peripheral.joystick (2db8029e), pvr.argustv (e536f32e, +1), pvr.demo (01c68c88, +1), pvr.dvblink (5f9872ca, +1), pvr.dvbviewer (35902f5d, +1), pvr.filmon (efd379b8, +1), pvr.hdhomerun (a71e816d, +1), pvr.hts (ac2e3be6, +5), pvr.iptvsimple (1ea1f36e, +1), pvr.mediaportal.tvserver (369b0189, +1), pvr.mythtv (9141c6fc, +1), pvr.nextpvr (7ed3111c, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1, +1), pvr.stalker (acba9f12, +1), pvr.vbox (b24c3cac, +1), pvr.vdr.vnsi (5d5bb64e, +2), pvr.vuplus (c988f849, +1), pvr.wmc (ef4cf3b1, +1)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: Enable other binary addons
- Include [env] patch: binary-addon: inputstream.rtmp
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Enable pvr and adsp addons, disable pvr/adsp updates
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] PR:432: build: start using .libreelec-unpack
- Include [env] PR:433: libreelec: use build project directory for ccache
- Include [env] PR:477: ffmpeg: rework
- Include [env] PR:485: pulseaudio: update to 9.0
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
- Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
- Fix webserver (iOS, Yatse issues etc.)
Build Details:
- LibreELEC.tv:
- lirc: replace parallel build fix (PR:474, 1 commit, 2 files changed)
- libva/libva-intel-driver: update to 1.7.1 (PR:483, 1 commit, 3 files changed)
- vdr-addon: update satip plugin (PR:484, 1 commit, 1 file changed)
- tvheadend: update to 4.0.9-5 (PR:468, 1 commit, 4 files changed)
- tvheadend42: update to 4.1.2130 (PR:467, 1 commit, 6 files changed)
- XBMC:
- webserver: fixup breakage in #10023 (PR:10029, 1 commit, 1 file changed)
- [PVR] Fix epg tag <-> timer tag association handling. (PR:10024, 4 commits, 7 files changed)
- newclock5:
- New commits in this build:
- VideoPlayer: expose stream player info to GUI (d2165e95)
- remove DataCacheCore from systemGlobals (e12400a5)
- squash me (84bb6072)
- VideoPlayer: Initialise datacache codec info (bcd8fb95)
- rbp: Update to use new processInfo data cache (5bc92c98)
- Updated commits in this build:
- Commits no longer in build:
- squash: mmalcodec: Improve stalls with EOS handling with dvd menus (c7be9ac6)
- Added: [env] PR:485: pulseaudio: update to 9.0
Build #0624x with kernel 4.7-rc4:
RPi /
RPi2
I noticed an issue with some "hard-telecined" DVDs: sometimes de-interlacing does not work.
Sample:
https://docs.google.com/uc?id=0Bw7pv6UJO...t=download
The problem with this particular DVD is that when you select "Play movie with Elvira" - de-interlacing works normally. If you select "Play movie only" - de-interlacing does not work and there is no way to enable it manually (if you manually set it to "On" - nothing happens).
(2016-06-25, 03:22)Milhouse Wrote: [ -> ]Build #0624x with kernel 4.7-rc4: RPi / RPi2
iOS Remote App working perfect again.
lirc/gpio remote 0624 not working
