Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
sorry, have always the same issue with DVDmenue with this #0630 build ...
THX
Harald
btw: there is a icon in Infobar, names "Lesezeichen" in german -> "bookmark" - i'm spacy, because that will show me the Kapitel from the DVD.
is this what you meant to say - be right?
next:
BR menue from "Pink Floyd - The EndlessRiver" is not so smooth like the builds bevor - need more time to switch/run from the choice into playing the content.
...i know - terrible english - hope you understand me.
#0701 fixed the 1080i bug... However, this DVD deinterlacing issue is now even worse. In previous builds it was possible to enable deinterlacing by pressing "Menu" during the movie and then restarting the movie. After the restart the deinterlacing is (usually) enabled. In build #0701 deinterlacing is always disabled, no matter what I do.
hi, its been a while. eden,frodo cant remember. lol
thanks for making this custom bleeding edge build.
I know you have not announced #701 yet, but the stalker pvr client is broken in this version.
it loads channels fine but can not play them back. the 'busy' wheel just keeps spinning in kodi after trying to open a channel, ands I am getting this repeated in the log:
03:04:57 528.633179 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:57 528.633911 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:57 528.673584 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:57 528.674255 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:57 528.710205 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:57 528.710876 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:57 528.824158 T:1960742912   DEBUG: Keyboard: scancode: 0x2d, sym: 0x0078, unicode: 0x0078, modifier: 0x0
03:04:57 529.102722 T:1960742912   DEBUG: OnKey: x (0xf058) pressed, action is Stop
03:04:57 529.103027 T:1960742912  NOTICE: CVideoPlayer::CloseFile()
03:04:57 529.103210 T:1960742912  NOTICE: VideoPlayer: waiting for threads to exit
03:05:07 538.712769 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:05:07 538.713562 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:05:13 544.312744 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:05:13 544.313538 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:05:24 555.471802 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:05:24 555.472595 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:05:27 558.576294 T:1797256096   ERROR: ffmpeg[6B1FF3A0]: [hls,applehttp] Error when loading first segment '
with 630 I get \/ after trying to open the link:
03:31:42 893.317200 T:1594880928    INFO: ffmpeg[5F0FF3A0]: Input #0, hls,applehttp, http://xx.xx.xx
INFO: ffmpeg[5F0FF3A0]:   Duration: N/A, start: 13210.212000, bitrate: N/A
03:31:42 893.317871 T:1594880928    INFO: ffmpeg[5F0FF3A0]:   Program 0
03:31:42 893.318054 T:1594880928    INFO: ffmpeg[5F0FF3A0]:     Metadata:
03:31:42 893.318359 T:1594880928    INFO: ffmpeg[5F0FF3A0]:       variant_bitrate : 0
03:31:42 893.319153 T:1594880928    INFO: ffmpeg[5F0FF3A0]:     Stream #0:0: Data: timed_id3 (ID3  / 0x20334449)
03:31:42 893.320129 T:1594880928    INFO: ffmpeg[5F0FF3A0]:     Stream #0:1: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 720x480 [SAR 10:11 DAR 15:11], 59.94 fps, 29.97 tbr, 90k tbn, 59.94 tbc
03:31:42 893.320923 T:1594880928    INFO: ffmpeg[5F0FF3A0]:     Stream #0:2: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 128 kb/s
03:31:42 893.321167 T:1594880928   DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
03:31:42 893.321350 T:1594880928   DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1
03:31:42 893.321594 T:1594880928   DEBUG: CDVDDemuxFFmpeg::AddStream ID: 2
03:31:42 893.329102 T:1594880928   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x63f3b080
03:31:42 893.330872 T:1594880928   DEBUG: OMXClock::OMXStop
03:31:42 893.331482 T:1594880928   DEBUG: OMXClock::OMXSetSpeed(0.000) pause_resume:1
03:31:42 893.332031 T:1594880928  NOTICE: Opening stream: 1 source: 256
03:31:42 893.332703 T:1594880928   DEBUG: DllBcm: Using omx system library
03:31:42 893.336060 T:1594880928   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131 m_handle 0x6193cd70
03:31:42 893.340027 T:1594880928   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - port(130), nBufferCountMin(1), nBufferCountActual(120), nBufferSize(81920), nBufferAlignmen(16)
03:31:42 893.381897 T:1594880928   DEBUG: COMXVideo::Open - decoder_component(0x0x6193cd70), input_port(0x82), output_port(0x83) deinterlace 1 hdmiclocksync 1
03:31:42 893.382263 T:1594880928    INFO: OMXPlayerVideo::OpenDecoder : Video codec omx-h264 width 720 height 480 profile 77 fps 29.970030
and so forth..i tried swapping between versions many times to rule out a freak incident. :/
I dont know if the above means anything to you, seems to have something todo with ffmpeg.
anyway I can provide more info, and test 'test' versions if you need it.
New LibreELEC.tv Krypton build #0701: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.3 #1 Fri Jul 1 21:22:09 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 27 2016 17:27:06
Copyright (c) 2012 Broadcom
version 1e7b8e2c9a7319f7b22869f1334c66e2cfc99f4a (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160701212103-#0701-g0eb99ab [Build #0701]
# vcdbg log msg 2>&1 | grep DTOK
002469.870: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (0eb99ab8, changelog) and tip of XBMC master (5c49da76, changelog) with the following modifications: Build Highlights:
  1. Kodi 17.0alpha3
  2. Partition newclock5 commits into stable/unstable groups
Build Details:
  1. LibreELEC.tv:
    • kodi: 17.0 alpha2 f3ca4eaf9 (PR:503, 2 commits, 4 files changed)
    • ffmpeg: Bump to release/3.1-xbmc (67171c3) (PR:504, 1 commit, 6 files changed)
    • kodi: Fix package version (PR:505, 1 commit, 2 files changed)
  2. XBMC:
    • bump to 17.0 alpha3 (PR:10047, 1 commit, 2 files changed)
    • Keyboard layout: Slovak QWERTZ, QWERTY, ABC (PR:10033, 1 commit, 1 file changed)
    • [depends] bump mDNSResponder to 625.41.2 (PR:10025, 1 commit, 2 files changed)
    • [droid] MediaCodec API21+ buffer handling (PR:9911, 1 commit, 3 files changed)
    • [depends] bump python to 2.7.12 (PR:10041, 1 commit, 6 files changed)
    • [depends] libxslt 1.1.29 (PR:10048, 1 commit, 1 file changed)
    • VideoPlayer: expose stream player info to GUI (PR:9976, 3 commits, 42 files changed)
    • added: FFmpeg-supplied RTMP support (PR:10015, 2 commits, 5 files changed)
    • 3dlut and simple ICC linking support for color correction (PR:9731, 24 commits, 30 files changed)
    • [PVR] Cleanup: Make timer internal terminology consistent, step 2 (PR:10046, 1 commit, 13 files changed)
    • [settings] remove non-existing settings from code (PR:10026, 1 commit, 2 files changed)
  3. inputstream.mpd:
  4. newclock5:
    • New commits in this build:
      • UNSTABLE: This is a placeholder. Commits after this point are considered experimental. (2be4a48f)
      • mmalcodec: Remove deinterlace support (cfaaa84e)
    • Commits no longer in build:
      • - added setting for allowing to hide watched movies/episodes/musicvideos in the recently added lists of the home screen (5a17c2b9)
      • - evaluate the setting for hiding watched movies/episodes/musicvideos in recently added job (should influence homescreen of skins only) (dfd94334)
      • VideoPlayer: expose stream player info to GUI (8f308653)
      • remove DataCacheCore from systemGlobals (4ff45b99)
      • rbp: Update to use new processInfo data cache (69807329)
  5. kernel 4.6.y:
      • enable led support for xpad driver - fixes flashing leds on controller (60d4b89a)
      • bcm2835-sdhost: Improvements to error recovery (d3995c15)
      • Add IQAudIO Digi WM8804 board support (a6cb7d0d)
Good morning Milhouse & pocornmix
#0701:
1) BR The Endless River is not playable, no selection possible with the mouse-cursor.
The selection of the Menue is not on the right place.
Something wrong, because in last build the selection is left over the "circle" on 40" LCD-TV
2) Eagles Hell Freezes over - the selection of sound-setup works now, but there is no Menue visible.
THX
Harald
(2016-07-01, 20:30)MikeKL Wrote: [ -> ]----Edit----- Just watched full match, Wales 3:1 Belgium, what a great game of football and not a single drop/pause in 3.1Mpbs Limelight stream for whole match -----
Yes, I watched this with iPlayer add-on. Great match and great quality. 720p50 works really well for football.
I'm not aware of anything that has changed on Pi/kodi side to explain this. It is possible the BBC have upgraded their servers and can handle more bandwidth now.
(2016-07-02, 05:44)Milhouse Wrote: [ -> ]New LibreELEC.tv Krypton build #0701: RPi / RPi2
# uname -a
# vcgencmd version
# lsb_release
  1. Kodi 17.0alpha3
Build Details:
  1. LibreELEC.tv:
  2. XBMC:
  3. inputstream.mpd:
  4. newclock5:
  5. kernel 4.6.y:
ok. I see no commits to the stalker client, so something in the #701 build must have broke it.
I just tried again, and i'm still (doh) getting the ffmpeg 403 forbidden errors in the log instead of just opening the link as with #630.
it makes no sense?
(2016-07-02, 14:41)tuxen Wrote: [ -> ]ok. I see no commits to the stalker client, so something in the #701 build must have broke it.
it makes no sense?
Do you see the issue on a nightly build on other platforms?
Do you know what protocols stalker uses? What does the URL opened by player look like?
If it uses rtmp then this may be the caause:
(2016-07-02, 15:13)popcornmix Wrote: [ -> ]
it makes no sense?
yeah it uses RTMP or HLS (I have a feeling these are handled somewhat equally?), so that makes sense, where do I/we go from here?
EDIT: could you or milhouse possibly be kind enough to make a test build without those commits, to see if it is really the issue?
best regards.
(2016-07-02, 15:18)tuxen Wrote: [ -> ]yeah it uses RTMP or HLS, so that makes sense, where do I/we go from here?
So the "Opening:" line in log has a filename that starts "rtmp://"?
@Milhouse is it possible to include https://github.com/notspiff/inputstream.rtmp ?
As I understand it kodi now only supports very basic rtmp through ffmpeg and you need inputstream.rtmp for fuller rtmp support.
(2016-07-02, 15:24)popcornmix Wrote: [ -> ]
no actually it looks like it is opening a m3u8, that takes it to a .ts with the protocol HLS.
with #630 everything goes smooth:
03:31:39 890.981995 T:1594880928   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: http://xx.xxxx.xx:8080/redirect/playlist.m3u8
03:31:39 890.982239 T:1594880928  NOTICE: Creating Demuxer
03:31:39 890.984680 T:1594880928   DEBUG: ffmpeg[5F0FF3A0]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
03:31:41 892.411377 T:1594880928   DEBUG: Previous line repeats 4 times.
03:31:41 892.411987 T:1594880928   DEBUG: Open - avformat_find_stream_info starting
03:31:42 893.316406 T:1594880928   DEBUG: Open - av_find_stream_info finished
03:31:42 893.317200 T:1594880928    INFO: ffmpeg[5F0FF3A0]: Input #0, hls,applehttp, http://xx.xxxx.xx:8080/redirect/playlist.m3u
03:31:42 893.317627 T:1594880928    INFO: ffmpeg[5F0FF3A0]:   Duration: N/A, start: 13210.212000, bitrate: N/A
and all the correct data about the file and so on follows, and the file plays.
with #701 it goes bad pretty fast:
03:04:27 498.392761 T:1797256096   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: http://xx.xxxx.xx:8080/redirect/playlist.m3u8
03:04:27 498.392975 T:1797256096  NOTICE: Creating Demuxer
03:04:27 498.542145 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:27 498.542786 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:27 498.578461 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:27 498.579071 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:27 498.615356 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:27 498.616058 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:37 508.619446 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:37 508.620239 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:43 514.218018 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:43 514.218689 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:44 515.370850 T:1659892640   DEBUG: AddOnLog: Stalker Client: GetEvents
03:04:44 515.371155 T:1659892640   DEBUG: AddOnLog: Stalker Client: StalkerCall
03:04:44 515.376221 T:1659892640   DEBUG: CFileCache::Open - opening <http://xx.xxxx.xx/stalker_portal/server/load.php> using cache
03:04:44 515.380554 T:1659892640   DEBUG: CurlFile::Open(0x5a8f9ed0) http://xx.xxxx.xx/stalker_portal/server/load.php?type=watchdog&action=get_events&init=0&cur_play_type=1&event_active_id=0
03:04:44 515.422302 T:1805644704   DEBUG: Thread FileCache start, auto delete: false
03:04:44 515.424316 T:1805644704    INFO: CFileCache::Process - Source read didn't return any data! Hit eof(?)
03:04:44 515.474365 T:1805644704   DEBUG: Thread FileCache 1805644704 terminating
03:04:44 515.475281 T:1659892640   DEBUG: AddOnLog: Stalker Client: Execute: {"js":{"data":{"msgs":0,"additional_services_on":"1"}},"text":"generated in: 0.013s; query counter: 4; cache hits: 0; cache miss: 0; php errors: 0; sql errors: 0;"}
03:04:44 515.475708 T:1659892640   DEBUG: AddOnLog: Stalker Client: UnloadEPG
03:04:53 525.110291 T:1814033312   DEBUG: Thread JobWorker 1814033312 terminating (autodelete)
03:04:54 525.377380 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [http] HTTP error 403 Forbidden
03:04:54 525.378052 T:1797256096   DEBUG: ffmpeg[6B1FF3A0]: [hls,applehttp] Failed to open segment of playlist 0
03:04:57 528.482239 T:1797256096   ERROR: ffmpeg[6B1FF3A0]: [hls,applehttp] Error when loading first segment 'http://xxx.xxx.xxx.xxx:80/media.ts'
03:04:57 528.483459 T:1797256096   DEBUG: Error, could not open file
and it continues. the 'busy' wheel never stops with 'unable to play this item'. I have to manually stop it by pressing x.
EDIT: the urls I unfortunately have to leave out, have trailing parameters after m3u8? like start stop time, token, user, and various other stuff.
Although I stated in previous post that iplayerwww add-on is playing Live streams really well and very smoothly in latest builds #0630+ CoolCool I am also noticing that some skipping of frames is occurring with the catch-up streams, which seems to me to be more noticeable and annoying in #0701.
"o" to bring up additional info in GUI, "skip" steadily increasing in value, which is not occurring with live playback. (3.1 & 5.5Mbps Limelight)
Switched on debug (with additional logging for ffmpeg) to catch some additional info when skipping occurs debug log
For overall reference, I switched on debug around 16:17 then played Celebrity MasterChef Series 11: Episode 4, Part 1 (3.1Mbps Limelight)
Is it OK and useful to keep adding these reports here, when using latest builds or preferable in iplayerwww thread? Blush
(2016-07-02, 17:45)MikeKL Wrote: [ -> ]"o" to bring up additional info in GUI, "skip" steadily increasing in value, which is not occurring with live playback. (3.1 & 5.5Mbps Limelight)
Here is fine - this sounds like a player issue rather than an add-on issue.
Be aware that debug logging (especially with the video component specific logging) is quite verbose and can cause skips when log is flushed to sdcard,
so make sure the problem also occurs without logging enabled.
If you think this is a regression, then identifying the first build with the problem would be very useful.
Any particular reason deinterlace support had been removed?
