Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-07-05, 23:23)MikeKL Wrote: [ -> ]Once Pi is fully booted up it appears to be stable for long periods and I can use both PVR via live TV option in GUI including EPG information etc.
(been using/testing like this for a while with nightly milhouse builds) .
I don't believe two PVRs is a supported configuration.
Can you disable one and confirm if hang still occurs?
(2016-07-05, 23:24)popcornmix Wrote: [ -> ]
I don't believe two PVRs is a supported configuration. Can you disable one and confirm if hang still occurs?
Sure, disabled fimon.pvr for now and yes clean boot without any hanging, sure it would be same and no hanging if I disable and only use filmon.pvr and not tvheadend backend. Another relevant point to my usage of two PVR's is hanging only occurs on a Pi with the tvheadend backend running on the same Pi
I have a second Pi connected remotely to tvheadend on first that runs both the tvheadend front end and filmon.pvr at same time (arghhh start to understand why as I write this post Blush) shouldn't run two PVR backends on same Kodi installation, hope we can..so apologies if this is unnecessary noise.
Especially as most of time LibreELEC runs just fine with two pvrs active; once up and running BlushBlush
There was a PR to handle more than one PVR client, but it appeared not to be complete and looks abandoned. I'm sure that current code does not support multiple PVR clients.
(2016-07-05, 23:44)popcornmix Wrote: [ -> ]There was a PR to handle more than one PVR client, but it appeared not to be complete and looks abandoned. I'm sure that current code does not support multiple PVR clients.
Just as an overall comment to kodi devs, That's a real shame as honestly in general DVB-T via tvheadend and IPTV (pvr.Filmon) works really very well even if not officially supported. ( Thought I had this cracked Confused )
I don't want to go back to tvheadend and DBV-T Live TV fully integrated withing baseline kodi GUI; and then have to use additional iptv Filmon.TV add-on + TVguide
Here is a user hoping that kodi developers will take another look at PR and full support in kodi for multiple PVR's (i.e Separated and specialized DVB-T and IPTV PVR's)
Thanks for all your continuing support milhouse and popcornmix CoolCool (apologies for this noise in the LibreELEC Testbuilds for RaspberryPi (Kodi 17.0) thread.
New LibreELEC.tv Krypton build #0705: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.0-rc6 #1 Tue Jul 5 21:07:25 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 27 2016 17:27:06
Copyright (c) 2012 Broadcom
version 1e7b8e2c9a7319f7b22869f1334c66e2cfc99f4a (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160705210537-#0705-g17b17dd [Build #0705]
# vcdbg log msg 2>&1 | grep DTOK
002455.534: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (17b17dd0, changelog) and tip of XBMC master (76d92ca5, changelog) with the following modifications: Build Highlights:
  1. libnfs update
  2. RTL8812AU update
Build Details:
  1. LibreELEC.tv:
    • moonlight-embedded: fix dependencies for imx6 project (PR:517, 1 commit, 1 file changed)
    • libamcodec: make source arch-specific, not project-specific (PR:514, 1 commit, 1 file changed)
    • adafruit-libraries: new library addon with python libraries from adafruit (PR:509, 1 commit, 21 files changed)
    • libsndfile: update to libsndfile-1.0.27 (PR:519, 1 commit, 1 file changed)
    • init: Fix updating from img.gz when kernel resides on block device (PR:515, 1 commit, 2 files changed)
    • ffmpeg: rework (PR:477, 1 commit, 1 file changed)
    • kodi: Update RBP commits (PR:506, 2 commits, 6 files changed)
    • WeTek/Kernel: Fix kernel options to make use of 9896 (PR) (#518) (5c880853)
  2. XBMC:
    • [PVR] Timers: Allow to change timer type for existing timers. (PR:10057, 1 commit, 2 files changed)
    • Player.Process info label changes (PR:10069, 6 commits, 3 files changed)
    • [PeripheralCecAdapter] Fix: Slovak language code (slo) considered as Slovenian (slv) (PR:10066, 1 commit, 1 file changed)
  3. libnfs:
    • Update some comment and fix typos (cdbcdfd7)
    • Add seekdir and telldir support (28e01e67)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: RTL8812AU: bump with kernel 4.7 support
#0705 fixed the hard lock issue with the RTL8812AU chipset.
(2016-07-06, 01:14)jarvismeier Wrote: [ -> ]#0705 fixed the hard lock issue with the RTL8812AU chipset.
Terrific. Smile
Guys, since i upgraded to #704 am facing issues playing the addon sports devil, here is the log for trying ibrod/Family guy from within the addon, i am not sure if the problem is with our build, or with the addon.
http://pastebin.com/MXKjThDn
PS: i have Kodi 17 Alpha on OSX and it is working well.
(2016-07-06, 12:27)igenena Wrote: [ -> ]Guys, since i upgraded to #704 am facing issues playing the addon sports devil, here is the log for trying ibrod/Family guy from within the addon, i am not sure if the problem is with our build, or with the addon.
No support for banned add-ons, particularly those such as SportsDevil that constantly break and require frequent updates.
However if you were to try:
texturecache.py playw "rtmp://185.63.252.131:1935/liveedge/?wmsAuthSign=c2VydmVyX3RpbWU9Ny82LzIwMTYgODowOToxMiBBTSZoYXNoX3ZhbHVlPVIyQTdxei9WRWRwWlJpWGdZK1lmdVE9PSZ2YWxpZG1pbnV0ZXM9MTA=/familyguy_djfrgzu9 swfUrl=http://otronivel.me/jw7/jwplayer.flash.swf flashver=WIN/2021,0,0,242 timeout=15 live=true swfVfy=1 pageUrl=http://miplayer.net/embedplayer.php?width=640&height=480&id=familyguy&autoplay=true&strech=exactfit"
This is working for me, so rtmp streams should be working for you.
(2016-07-05, 13:45)Milhouse Wrote: [ -> ]
(2016-07-05, 12:29)loggio Wrote: [ -> ]it's ever since that commit to Kodi on #0614 that's broken this.
Yes, I've switched to another machine (got kicked out of the living room) haha
The rounded theme in Titan rounds all the textures for the skin, posters, fanart etc...
So it's not specific to pie.
Try build #0704x which has PR9960 reverted: RPi2
@loggio can you re-test #0704x as I've installed Titan myself now, and while I see rounded buttons with #613 (when using "modern_rounded" theme), I don't see rounded buttons with #0614 nor do I do I see rounded buttons with #0704x.
Never mind, there'll be a fix for this (PR10073) in tonight's build - tested and confirmed as working here. Thanks for reporting and locating the regression!
Just updated to #0705 and with only one PVR enabled, had following single kodi crash during 1st boot-up
Kodi Crashlog and then kodi.log after clean boot into kodi after crash.
(2016-07-06, 20:18)MikeKL Wrote: [ -> ]Just updated to #0705 and with only one PVR enabled, had following single kodi crash during 1st boot-up
Which PVR add-on is enabled? Can you enable debug logging as it looks like the add-on is generating bogus queries:
19:05:36 18.286203 T:1741566880 ERROR: SQL: [TV29.db] SQL error or missing database Query: [email protected]`]9r00r 8r:[email protected][9rHC9r<[email protected]@9rf9r(>9r0:r0l9r0d9rD9r^9r^9r8r P9rm9r(f9r:r:rX:[email protected]
and
19:06:09 51.272865 T:1739584416 ERROR: SQL: [TV29.db] SQL error or missing database Query:
19:06:09 51.274044 T:1739584416 ERROR: CommitInsertQueries - failed to execute queries
Tvheadend 4.2 (LibreELEC Tvh-addon v8.0.103-#0703-milhouse-v4.1-2140-gf34fac1)
Have enabled debug log and currently re-booted with no issues kodi debug log (so far)
(2016-07-06, 18:39)Milhouse Wrote: [ -> ]
My pleasure. Thanks for acting swiftly on this, much appreciated.
Cheers,
Loggio.
New LibreELEC.tv Krypton build #0706: RPi / RPi2
# uname -a
Linux rpi512 4.7.0-rc6 #1 Wed Jul 6 22:55:41 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jul  5 2016 21:33:41
version 5a921d051b05efb2ce8abb0874cd44023d080d93 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160706225435-#0706-g42be1ec [Build #0706]
002455.319: Kernel trailer DTOK property says yes
Based on tip of LibreELEC.tv master (42be1ecd, changelog) and tip of XBMC master (261df2d7, changelog) with the following modifications: Build Highlights:
  1. New firmware, link Kodi aginst libbrcmEGL.so/libbrcmGLESv2.so
  2. Fix Titan "modern_rounded" buttons issue
Build Details:
  1. Firmware (Jul 5):
    • firmware: Pushed so files missed from last update
    • firmware: revert: cmake: mark GLESv2 as so version 2 for consistency with mesa lib
    • firmware: makefile: Switch to building and using GL libs with custom names See: link
    • firmware: platform: Fix avoid_lcd=2
    • firmware: dt-blob: Enable pullups on Pi3 SDIO pins
  2. LibreELEC.tv:
    • libbluray: update to 0.9.3 (PR:520, 1 commit, 2 files changed)
    • Revert "lirc: add lircd-uinput service" (PR:511, 1 commit, 2 files changed)
  3. XBMC:
    • CRenderManager: fix GetAspectRatio at playback start (PR:10071, 1 commit, 1 file changed)
    • Added navigation controls for EDL (commercials) in PVR playback (PR:10064, 1 commit, 3 files changed)
    • [android/packaging] Sync rtmp removal (PR:10017, 1 commit, 1 file changed)
  4. libnfs:
    • Make rpc_disconnect() a no-op if the session is already disconnected (fac3a954)
  5. inputstream.mpd:
  6. inputstream.rtmp:
  7. inputstream.smoothstream:
    • Make sure at least 1 stream is selected (ec5ca273)
    • fix linux compile error <math.h> (8dbe3ba4)
  8. newclock5:
    • New commits in this build:
      • rbp: Update the GL libs to new naming scheme (4a82137c)
  9. Additional commits/pull requests/changes not yet merged upstream:
