Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-04-23, 15:16)Pienoet Wrote: [ -> ]
(2016-04-23, 15:06)nexusle Wrote: [ -> ]Just for interesst:
DVBLink PVR Addon broken with this build
Same for tvheadend client addon
Hopefully the addons will catch up in the next few days. Until then you probably want to avoid new builds until you see your favourite PVR addon has updated to 5.2.0.
(2016-04-23, 15:26)steve1977 Wrote: [ -> ]Any idea what I can do to further trouble-shoot?
The server is a beefy Unraid server (see my siganture for detais).
I'd suggest running a network bandwidth test using iperf, which you might still be able to install from the OpenELEC Unofficial repository (if you still have that repo installed).
Hopefully the LE 8 repository will be populated soon.
Unfortunately, I did a clean install when switching from OE to LE. Can I still install the unofficial OE repo on LE? If so, do you have a download link? Thanks!
(2016-04-23, 14:18)Pienoet Wrote: [ -> ]
(2016-04-22, 23:35)Pienoet Wrote: [ -> ]Hi Milhouse thanks for the LibreELEC testbuilds.
With the latest build #0420 when watching live tv when auto refresrate from 1920x1080p 60 hz to 1920x1080p 50hz videoplayback freezes..
Here is my debug log
I did a test with my local video files and and refreshrate from 60 hz to 24hz no freezes...
Milhouse or popcornmix i don't know what's happening here if you have time can you pls tell me what is wron with my setup?
(2016-04-23, 15:38)Milhouse Wrote: [ -> ]New tvheadend42 addon available from the addons folder - you may need to uninstall your existing version, as apparently it's not possible to upgrade from tvheadend v4.0 to tvheadend v4.2.
when installing tvheadend42 I get the following errors
http://sprunge.us/UJbb
I'm back to oe build service.multimedia.tvheadend-8.0.2-#0324-milhouse-v4.1-1724-g41707e1
Transmission service is also dead with 0423
(2016-04-23, 15:41)Milhouse Wrote: [ -> ]
Thanks Milhouse! I'll jump back into the new builds when MythTV is updated for 5.2.0.
(2016-04-23, 15:51)steve1977 Wrote: [ -> ]Unfortunately, I did a clean install when switching from OE to LE. Can I still install the unofficial OE repo on LE? If so, do you have a download link? Thanks!
No and no. You'd have to go back to OE to install the Unofficial repository.
(2016-04-23, 16:30)polo_joe Wrote: [ -> ]
Can you disable the add-on then run
/bin/sh -c "exec sh /storage/.kodi/addons/service.tvheadend42/bin/tvheadend42.start
and paste the output.
LE has its own the unofficial repository. Is there some difference between?
(2016-04-23, 17:48)MONSTA Wrote: [ -> ]LE has its own the unofficial repository. Is there some difference between?
LE doesn't have an Unofficial repository, with LE there is only the Official repository. And for now it's empty as there are currently no 8.0 addons...
(2016-04-20, 17:30)Milhouse Wrote: [ -> ]Estuary bug thread: 262373 (thread)
We're looking into the SSL issue, thanks.
Build #423 fixed each of the two issues I noticed. Pandoki now accepts my credentials and Yahoo Weather now accepts the location information.
Thanks,
Bill
(2016-04-23, 17:53)Milhouse Wrote: [ -> ]
Strange. Then what is this? I used the transmission addon from there Smile
(2016-04-23, 17:35)Milhouse Wrote: [ -> ]
http://sprunge.us/jgdP
(2016-04-23, 15:46)Milhouse Wrote: [ -> ]
Thanks. I installed the addon on LE successfully. Then used Putty to run it from command line. I just typed iperf, but got the following error message:
** /storage/.kodi/addons/network.testing.iperf/bin/iperf: line 1: syntax error: unexpected ")"
